Member postings for jim'
Here is a list of all the postings jim' has made in our forums. Click on a thread name to jump to the thread.
Thread: free copy of Model Engineer?
26/03/2016 18:29:41
I thought it was just a catalogue.
I subscribed today. I finally got fed up with looking for WHS's latest location of the mag
26/03/2016 15:15:46
just been to WHS and brought MEW, unusually it was in a sealed clear bag, with a current copy of Model Engineer magazine.
but no mention of a "two" pack?
just curious if its a mistake?
Thread: Spindexer/spin indexer
20/03/2016 07:44:42
Thank you for all the comments.
I think I will go with the Arceurotrade version.
Some good points raised.
Thanks again
Jim
19/03/2016 07:41:33
Hi,
Been thinking about getting spindex thing, (arceurotrade one).**LINK**
Are they solid enough to mill hexagons on bolts, or really just a simple drilling thing?
I only ask because the locking pin does seam a good distance from the action!
I have been using a hex ER collet block, but if these spindexers are ok, I'd be able to check for run out etc easily.
Thank you
Thread: Arceurotrade 000 QCTP
02/02/2016 20:45:04
250-200 would be nice!
Thread: The Workshop Progress Thread (2016)
02/02/2016 19:14:45
Posted by Roderick Jenkins on 02/02/2016 19:10:37:
Bandsaw update: Having proven the concept, I've made a better job of the clamp. The studs are 6mm and the slots in the bar were made with a 1/4" slot drill:
Cheers,
Rod
excellent.
one more for my todo list!
02/02/2016 19:05:17
Treated meself to one of Arceurotrade's new 000 QCTP.
These are the sliding wedge type.
I bought mine for a Sieg C4, i'd had a mini lathe QCTP before, but, they are not very good!
Very impressed! Very precise location, far more positive and accurate than my "piston" type 2 on the Crusader!
Only problem is, I now need to buy more holders.......
Thread: replacement motor brushes WEISS mill (champion 20v)
06/01/2016 17:04:46
Posted by Dave Daniels on 02/01/2016 10:55:30:
IF !! it's the same 600W motor as a Warco WM16 it's these :
I think Warco charge a fair bit more for what appear to be the same brushes.
The new ARC brushes arrived today, fitted straight in.
Happy days.
A big thanks for the heads up on this.
Cheers Jim
02/01/2016 11:04:45
Edited By Dave Daniels on 02/01/2016 10:56:43
Edited By Dave Daniels on 02/01/2016 10:57:52
Edited By Dave Daniels on 02/01/2016 10:58:13
Excellent!!
They look just the job!!
I was just about to order some from ebay!
Thank you for your help!!
02/01/2016 10:44:50
I'll probably get some oversize ones off eBay.
Thanks for advice
02/01/2016 07:15:02
Just discovered my mill is dead. Its a WEISS mill, similar to Chester's "chapion 20v"
Took out brushes and blew out with air and she lives again.
One of the motor brushes is very short, I have looked and can't find the correct size.
They measure 3.4mm wide, 10mm high and I'd guess around 15mm long when new.
Can anyone help, please
Cheers Jim
Thread: Insert
01/01/2016 20:15:32
CCGT inserts are what you need. Ground inserts for ally/plastics etc
Thread: A request
16/12/2015 16:22:20
Posted by Bodger Brian on 16/12/2015 13:41:47:
"I'm can imagine"
I see what you mean....................................
Edited By jim' on 16/12/2015 16:22:58
Thread: Gary Wooding and his Chester 12 x 36 Lathe
05/12/2015 11:59:00
I also drilled and tapped the cross slide. 4 holes on the top and three on the side, (I made an "L" shape plate).
I figured that if I had a crash, it would be better to damage a steel plate than break a cast iron cross slide!
It also means that the load is spread over a far greater area
Thread: M10 socket caps with 6mm Allen hole?
25/11/2015 20:40:34
M10 button head capscrews are 6mm hex.
I have used "low head" cap screws, I think they were 7mm hex
Thread: M1.7 - what is the history behind it?
12/11/2015 05:43:14
all you need to know about metric threads
Thread: Motorcycle General Discussion
30/10/2015 17:13:41
Thread: ER 40 Lathe collet chuck
12/09/2015 19:26:57
pleased to hear its worked ok.
I got similar results!
Thread: ER40 collet chuck
10/09/2015 19:02:53
Posted by pgk pgk on 10/09/2015 18:33:53:
When the penny finally dropped in my brain and I realised that i could shove my mills ER32 MT3 collet holder into the 5-3MT adapter and shove that in my crusader lathe I've been using it quite a bit.
The only downside to the MT holder system is limited insertion distance.
I didn't know ER40 went as big as 1 and 1/2 inches? Can i also ask which collet chuck you sourced to fit the crusader?
1 1/2" is a bit big!!
The job was some 30mm 304 stainless.
I think i got the chuck from Gloster tooling on ebay.
10/09/2015 16:37:46
The bearing type nut is excellent. **LINK**
I have not had to resort to using the spanner yet, even on 1 1/2" stainless bar.
So much better than three jaw
JD Metals
rapid Direct
walker midge
Dreweatts
