Member postings for Daggers
Here is a list of all the postings Daggers has made in our forums. Click on a thread name to jump to the thread.
Thread: Joy valve gear Jeannie Deans
10/12/2021 13:55:24
As a follow up to my previous post i had a quick look in my archive and found a photo of LBSC’s Jeannie in an 1958 ME No.2971. Also in ME 3312 he shows a drawing for an intercepting valve operation lever that his did not show on his original drawings also he discusses the link motion which i assume is used on the middle low pressure cylinder.
10/12/2021 10:28:14
I always understood that LBSC did build a Jeannie Dean and unlike most of his engines was quite detailed. I understood that after his death it was passed to a long time friend of his, Reg Hanks, it was then stolen and has never been seen again.
The above is from memory, i am happy to be corrected.
Thread: Ball Turning Tool
12/10/2021 10:36:59
I had a similar problem on a similar ball turning tool, just drilled two new holes at 90deg to the existing ones.
Would that work for you?
Thread: Chatter/finish problem
27/09/2021 16:53:23
I think the trouble with machines of this age is that they have had many modifications over the years. Mine had a number of mods so its possible that he headstock is not as original, but it seemed to work fine.
Just watched a Zyto rebuild where he rebuilds the headstock, looks like he tightens the locking ring a gentle finger tight then looks the grub screw.
27/09/2021 12:37:48
I rebuilt a machine similar to yours and when i adjusted the collar you show a much more experienced friend instructed me to put a 0.001” feeler gauge between the cast face and the collar face then tighten the locking screw. This allows the spindle to run free but with minimum end float.
Work just fine for me.
Good luck.
Thread: Hello, from Spain
22/09/2021 07:59:22
Welcome Fernando, its always great to have a new member from out of the UK.
Please don’t worry about your english, we will always be pleased to receive posts from you.
Tell us about yourself, where are you in Spain, what interests do you have, will you be making models, tools or other parts? We also like to see photos of your projects and workshop.
Thread: New member from Brussels
26/06/2021 10:18:02
Welcome to the world of model engineering, it’s always great to hear from lone modellers.
Where to start is always a difficult but nothing is impossible, many great models have been built by first time modellers.
One tip is to use metal of a known quality, this help you machine to a consistent and repeatable standard.
Do your research, GLR, Polly Models, Blackgates, Reeves all have online catalogs and ship to europe.
Youtube is a great resource “learn metal turning andrew whale” could be interesting for you, start at the oldest post and work forward. He starts with a small lathe and builds his knowledge from there.
Ask questions on the forum, no question is too basic, all questions deserve a reply.
Good luck
Thread: Moving machines
21/06/2021 13:16:50
Hi,
As a model engineer and a vintage car restorer i have both the lift as shown and a clarke folding engine hoist. Both have there place.
As a model engineer the lift works for me, when my machines were delivered they were placed straight on the lift from the truck and held with ratchet straps. I do have a wide door so the machines can go in sideways, the lift is always set at its lowest whilst it is moving, raising only to slide machine on to bench. I have drilled the sides of the top of the lifting truck and fitted eye bolts to secure loads. It does a great job of moving my 5” loco from bench to bench and bench to car. It also is used as an extra build table and can be rolled outside for steam tests. If you load overhangs the table pad the load overhang on the underside with secured wood blocks so if it does tilt it can only tilt a couple of inches whilst moving.
To be safe you need to carefully balance the load, strap it down, and have a smooth floor surface. And lastly stay clear of the load whilst moving
Thread: 2.5mm thick mystery 'Formica' type sheet. Is it still available?
14/06/2021 15:10:39
A few years back my company needed some blank fibre glass panels 4mm thick 600x300, the order was placed with the firms PCB supplier. He offered blank panels from 1.5 to 5mm thick, no copper, in a couple of different substrate types. I seem to recall they were dark green took a router quite well and drilled fine.
Thread: Steam operated drain cocks
13/06/2021 11:06:49
Hans,
sorry but I don’t recognise that image.
when i was looking for information on this subject I found this website, might be worth a look.
http://nelsonslocomotive.com/Heisler/Engine/CylinderCocks/CylinderCocks.htm
Thread: Crampton Loco Drawings
29/04/2021 11:14:30
The friend who gave me the Crampton build series has just emailed me a advert from 1987 showing B.Arridge selling a set of 14 drawings, cylinder castings, wheels etc. He asks for a sae for detail list from his home at Cottingham North Humberside.
Didn’t realise that he sold castings.
24/04/2021 20:00:28
Just finished going through the mags, unfortunately there is not enough drawing info to complete the loco. The series suddenly finishes whilst building the boiler fittings. There is no drawings for the tender, plate work and many small parts needed for completion.
Without access to the drawing set it would be a very difficult build.
Looks like I too will have to look for a different project, but I will still keep looking for the drawings even if its just to borrow them to get the missing info.
Thread: Boiler lagging
20/04/2021 13:10:30
I need some thin lagging in the end i purchased Kiln Glass Paper which is 1mm thick. I purchased a pack 50 pieces 80mm square for £5 just butted some sheets using double sided tape then brass cladding. Worked really well.
Thread: RR Merlin Scale Models
20/04/2021 11:50:57
I was lucky to see Barrys engine a couple of times and watched it run sometime in the 1980s.
At an much earlier exhibition i viewed his embryo merlin, just a large chunk of alloy with pockets milled out. What a craftsman.
He was always a very private man but still active in 2008 as he exhibited his Eagle 22 in the ME exhibition and came away with a cup.
A picture of him is in issue 4338.
The last time I heard of him was in about 2018 when a someone mentioned the they had spoken to him, but I really can’t confirm that.
I also seem to remember that at one exhibition I attended there were two merlin engines which sat side by side, one built by Barry and another by a different builder.
My father was a Merlin mechanic during the war and when i showed him Barrys engine on the front cover of the ME he was totally in awe of the mans skill.
Thread: Help wanted, How can I use a stepper motor as a table feed.
18/04/2021 17:29:52
One more try.
18/04/2021 17:19:18
Apologies, cant for the life of me post embedded video, old age.
18/04/2021 16:47:13
Looking at something similar, found this youtube, might be of interest to you.
https://youtu.be/stxFDjTuzkA
<iframe width="560" height="315" src="https://www.youtube.com/embed/stxFDjTuzkA" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Edited By Daggers on 18/04/2021 17:16:50
18/04/2021 11:35:26
Hi All,
After reading Mike Sharmans Crampton Loco book I have decided to build the 5” Crampton as sold by Blackgates as my next loco.
When i contacted them they could supply castings but not drawings and have no idea when they could be obtained. A friend has given me the build series but I would really like the drawings if possible. There is always a possibility that they were updated with small changes etc.
It looks like Brian Arridge sold them direct from his home.
Does any out there know if the drawings still exist or available somewhere?
If anyone has built one were there any problems.
Any help, advice or info would be grateful received.
Thread: MEW Stepper Power Cross Feed stops
04/11/2018 10:44:06
Neil,
Thats what I’ve lookin for, stopping the travel the change direction on the handset and press inch until switch is overriden.
Although i can build a project i could have looked at that circuit for a year and still not seen the soultion.
The MEW stepper cross feed has worked great over the years but this addition will just give me piece of mind during a long slow cut.
Many Thanks
04/11/2018 10:16:59
I have looked into Mikes stop system and that is just what i would like to add.
And if my power cross feed was an conventional electric motor it would be fairly straight forward.
Having a controller with stepper motor attached I am not competent with electronics to decide the best way to break into the circuit to achieve a safe solution, i.e a gentle circuit stop with damaging any electronics.
JD Metals
rapid Direct
walker midge
