Here is a list of all the postings Mike Young 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Lang Junior Lathe |
13/02/2016 09:11:41 |
Christopher, i have a Laing lathe and if you want to contact me i'll help out with change wheel information etc. Regards Mike Young |
Thread: Handwheel boss needs reconstructing. |
08/02/2015 20:15:48 |
Well if all else fails send it to me and i will tig weld it for you FOC. I'ts a 15minute job for an experienced welder. Mike Young |
Thread: Engineer for Headstock Overhaul - Pillar Drill/Tapper |
01/04/2014 11:27:41 |
That's about an hours work for John Stevenson, including a couple of tea breaks. |
Thread: Help with this spline |
17/08/2013 18:13:41 |
Another thing just struck me, "shear pin" do Deckel's not have a shear pin in the feed system ? it might be worth checking in case someone has replaced it with a too hard pin.
Mike Young |
17/08/2013 13:11:49 |
If the damage was caused as in the description above it might be worth making it in a "standard steel" so that if it happens again the shaft remains sacrificial. It'll be easier to make that shaft than get a new quill. There are a lot of FP1 owners on PM who could probably give you the exact dimensions and spline type. Mike Young Edited By Mike Young 2 on 17/08/2013 13:14:03 |
Thread: Help please, I have a Herbert |
22/07/2013 19:58:36 |
You could also try Tony at lathes.co.uk for information on the machine ? Mike |
Thread: Silver soldering, I still don't get it. |
15/07/2013 10:21:40 |
Hi Bill, I'm wondering if by your description you had it too hot, silver solder is a low-melting point joining compound. It could be that you had the parent metal too hot which means the solder efectively "boils" on contact forming the "ball" you described. Also brass being the lovely material its is oxidises faster the hotter it gets and also some of its constituent ingredients melt, mainly the zinc, and you get that horrible greyish smoke and "soot" on the job. Again its only my experience, Good Luck ! Mike Young |
