Here is a list of all the postings Lynne has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ML4 cross slide |
14/05/2022 00:45:57 |
What is a ....EDIT...........NOS? You,ve got fingers and a keyboard, spell it out, and use the language. Lynne Edit Preferably not Foul language
Edited By JasonB on 14/05/2022 18:47:20 |
Thread: What Did You Do Today 2021 |
10/12/2021 04:42:45 |
Samsaranda, I have sent you a PM. Regards, Lynne |
Thread: keyless chucks |
24/11/2021 10:40:23 |
Good morning, My thanks to you all for posting you views on the subject. I've been promising myself a drill for a while, so I will go down that route first. If speed is a issue, I'll then try the screwdriver. Regards, Lynne
23/11/2021 11:33:53 |
Good Morning, I am thinking of investing in some form of battery powered drill, principally for power feed to the top slide when machining 2 morse tapers. However, I am aware that when run in reverse, keyless chucks no longer grip drills, etc., so the reverse facility seems on the face of it to be a rather useless feature. All the drills that I have seen so far, are keyless, so maybe I should consider a powered screwdriver instead?. What do other members do?. Regards, Lynne
Thread: china/India - Cop 26 |
15/11/2021 10:33:43 |
Given that China and India have decided not to sign up to any binding agreement to reduce the use of fossil fuel, perhaps we should seriously consider looking at alternative sources for lathes, mills, chucks, and many other products which have their origin in these two countries. There are european sources, I know, our pockets will be hit, but given that there are islands which are going to disappear of the face of the earth, and many coastal regions are already being affected by rising sea level, paying more is perhaps a price worth paying. Regards Lynne
Thread: NVR Switch |
08/11/2021 11:47:59 |
Hi, Bee.M There is a Poundland in Witney, so next time I am in the town, I will pay them a visit and see if I can find the air duster. Thanks for the offer Duncan. I have marked the wires with their location numbers, and have pictures so I don't feel I need the wiring diagram. It's definitely an NVR switch Les. It does all the things you list and does'nt run when power is restored. I suspect that you are correct Nick, and this is a customized unit for Myford. Clive, the pt. no. CA10X A401 ties it down to being part of the CA range, not CG. I think the X denotes latching, and A401 implies a 3 pole motor reversing switch. Building one up from scratch is a bit to challeging for me, but I have e mailed a company up north who stock Kraus, to see if they can help. Thanks though Clive for you input, and going to such lengths to help, and everyone who have posted comment Regards Lynne |
05/11/2021 14:24:38 |
There is a Pt.No. on the switch, but I think it is going to be difficult to source a replacement, since the UK arm of Kraus & Naimer are not aware of a stockist. I would be reluctant to buy 2nd hand, not knowing how much use it had been subjected to. I would certainly give it a blast if I had compressed air. There are no contacts exposed so meth and a brush are out. Thanks again. Regards Lynne |
05/11/2021 10:52:56 |
good morning, Thanks for all your responses. I have opened the unit,& as the switch/coil is an intergrated assy, I am not inclined to dismantle further. I will live with it as it is. I did contact Kraus & Naimer uk, & they say they are not aware of a stockist, as it is a power failure release switch which are direct from the factory, & which to me sounds expensive. BeeM. May be you have'nt picked up on my post @ 12:27:23. I have put some pictures of the switch into the album. Regards Lynne |
04/11/2021 12:27:23 |
Thanks for the responses. Let me try to clarify things. The switch is an integrated unit, made by Kraus & Naimer, and was a factory fit by Myfords, when Myfords was Myfords,so I guess that means its getting on in years, a bit like me. It is operating on mains AC, and has operated fine for years, and it is only recently that it has started not to latch when selecting reverse. This is an intermittent fault, as this morning it held ok. The selector is mounted on the top of the unit, not shrouded. I will take some pictures, but it may be a while before I get them up here, Regards Lynne |
03/11/2021 23:16:38 |
Good evening, The lathe forward/reverse NVR switch latches when forward is selected, but not in reverse. What is the likely reason for this, and can it be fixed' Thanks, Lynne
Thread: Private messages |
11/03/2021 23:19:49 |
I have received a private message from a Jack Marvin making me aware of the golf facilities at Arabella Golf Club. He has no forum posts, photo's or articles, so how has he been able to do this? Poor choice really, as I have never swung a golf club in my life Lynne
Thread: Forum update |
24/02/2021 09:25:20 |
Is there some way that PM's can be saved?. I believe they will be lost when the site has it's re-vamp. Regards, Lynne |
Thread: Replacing Oilite Bushes in ML7 Countershaft bracket |
04/02/2021 22:54:57 |
Have a look at Steve Jordan on u tube. He did a project on replacing counter shaft bushes plus the home made tooling you need to mfg. Lynne |
Thread: Cracked motor mounting plate |
28/01/2021 10:50:51 |
Have a chat with John Smith 'Doubleboost' Regards, Lynne |
Thread: Communication |
18/01/2021 14:23:15 |
Thank's for all your responses. I will not be going down the the length of string and a 'tug' route, and the internet extension,cell phone, and powerline adaptors etc, I would struggle with. I have 'stable door ' access to my shed, lower half can be bolted inside, and the top half kept closed by a strong ball catch, so I am not 'locked in', but my wife suffers severe athritis in the hands and pulling on the door is something she avoids. I do not see using a bell push is demeaning, its used to summon someone to the front door, and in many establishments to obtain counter service. I like Rod's solution, and that is what I will be getting, and when tea and cake is being served, all my wife has to do is push the button and I will come running. Thanks again, regards, Lynne. |
18/01/2021 04:59:29 |
My wife got quite cross last evening, when I did,nt hear her shouting/hammering on my workshop/shed door. I was tool grinding at the time. I am now looking at wireless door bell systems. Those not requiring batteries are attractive,but are they durable in the long term?. What I would really like is a system which has both sound and flashing light. Does anyone know if there is anything out there. along these lines? Any help appreciated. Lynne |
Thread: Threading Wires |
16/12/2020 22:48:14 |
My thanks to you all for your responses. Rob, I will send you a pm with e mail address .Lynne |
16/12/2020 15:21:34 |
I've been looking on line for a chart which gives data to enable one to cut an imperial thread using wires to check pitch dia. Whether it could be downloaded would be another question. There are charts for Amercan and metric, but I have failed to find any for imperial. There are plenty giving general thread data, but not one for wires. Any chance someone can help me on this one? Regards Lynne .. |
Thread: Cutting copper tube square |
14/11/2020 15:20:55 |
Suitable size Jubilee clip,square it on pipe,tighten,hacksaw. Lynne |
Thread: Mitutoyo Caliper |
21/10/2020 23:23:39 |
Thank you all for your posts. Regards, Lynne |
