Here is a list of all the postings Mikelkie has made in our forums. Click on a thread name to jump to the thread.
Thread: Stirling regulator stuck |
16/02/2022 20:07:52 |
Could be that the regulator was left shut when last used, try filling boiler with boiling water and that the expansion might free it. Worked once for me. I always make sure that the reg and all valves are open when cooling.Good luck. |
Thread: Motor protection |
03/02/2022 17:14:41 |
I automated my band saw about a year ago for cutting short pieces from bar stock, it was necessary to stop when things go wrong so i installed a system to stop the motor if the driven wheel does not complete a revolution in a preset time (blade brake. slip off or jamming) This work great and i can do other work while the saw carries on. |
Thread: Three phase reversing |
15/01/2022 22:06:27 |
I revers my lathe by throwing the switch at full speed all the time without any problems. The Herbert preopt turret lathes has a "plugging" switch mounted at the rear of the motor (many people confuses it with a tacho for speed control). This device is driven by the shaft and is arranged so that the motor when running sets up a opposite direction as soon as the motor is stopped through a set of "plugging relays" enabling a quick stop of the motor.This work in both directions. Check schematic drawing for no. 5 and 7 preoptive lathes. The big Herbert drilling machines has a manual reversing switch along with a 4 speed switch and is reversed at any speed without any ill effects. i shall not attempt this with screw on chucks on a lathe, I will post part of the wiring diagram later |
Thread: Hello fromlincoln |
26/12/2021 19:34:42 |
Hi Mike as Howard says age, is no barrier I am in my mid 70's as well and as long as one remember what you went to the bathroom for you'r ok still, misplacing (or rather tools going missing while it is in your hand) or don't remember your wife's birthday one can live with that i think. Another mike |
Thread: The Bistella motorcycle |
24/12/2021 21:02:39 |
Posted by JimmieS on 24/12/2021 16:13:41:
Don't know if this topic has being discussed before. A wonderful achievement, some adventure too well done |
Thread: a little diversion |
10/10/2021 15:59:58 |
I like Macolm's explanation (3) |
Thread: Crankshaft Factory |
02/10/2021 20:31:26 |
Where am I (or us)?. slip guages, dro's, sine bars, cnc, qtp's etc etc will take me a lifetime making on of those as someone said in a James Watt like workshop. Good video though Edited By Mikelkie on 02/10/2021 20:32:23 |
Thread: joy valve gear (Derby 4f) |
10/09/2021 20:19:45 |
Wanted to build a Derby 4f myself experience difficulties with the drawing some 25 years ago, gave it away and did a Simplex instead. I suspect Don Young's drawings had some incorrect measurements
Thread: Electric motor speed |
04/09/2021 21:45:06 |
Commonly called a universal motor, not to be run without load |
Thread: Gas Burners for boiler |
31/08/2021 20:58:33 |
Hi Matt Stevens, check out my photo album for pics of a round gas burner that i made long ago. i'm using it on my vertical boiler also 6 inch in dia. It is quite easy to make in any size and performs well. pm me if more info needed Regards Mike |
Thread: Overheated Drill |
31/08/2021 18:23:58 |
Posted by John Haine on 31/08/2021 16:52:24:
Builders I have spoken to don't expect even quite expensive drills to last much more than a year or two. Correct. the smaller drills and angle grinders became a consumable item i go through 3 each annually and bin them, not worth even opening them. |
Thread: Boiler Fittings |
11/06/2021 17:33:51 |
J Bay regretfully is no longer in business as Mr Heydenrych retired about three years ago. Made wonderful stuff for the ME enthusiasts. |
Thread: Injector LBSC type |
26/05/2021 18:10:19 |
Posted by Speedy Builder5 on 26/05/2021 12:50:26:
I am under way in making one of LBSC's injectors for a 5" SPEEDY loco. It seemed a simpler idea once the body was made to make what was described as a "Slotted Cone" for the combining cone. as detailed in the attached drawing. Can someone explain what the slots in the sides of the cone do and should those slots pierce the Venturi which passes through the cone? |
Thread: Lathe Motor running Lumpy :-) |
15/05/2021 17:56:41 |
Check the function and condition of the centrifugal switch if fitted |
Thread: Long Term Planning or No planning! |
13/05/2021 20:38:07 |
Posted by larry phelan 1 on 13/05/2021 20:02:13:
If that was down my way, I think most of those poles would be long gone by now, and the cable with them. You see, we have what are called "Travellers" over here, who can and do remove anything which is not nailed down, and even then ! Helps to tidy up the place, sort of ! Larry it sounds if you in South Africa somewhere. |
Thread: To gib or not to gib? |
04/05/2021 19:59:39 |
Leave well enough alone, if there is a nylon or bronze wad between the locking screw/s and inner surface i think that will suffice. |
Thread: Safety Switch Wiring |
27/04/2021 18:25:14 |
Check if the coil voltage is for 380 or 220 volt, that may be your problem. |
Thread: New shaft in Oilite bushes? |
27/04/2021 18:11:08 |
Posted by Nick Clarke 3 on 31/08/2020 22:03:28:
Posted by old mart on 31/08/2020 21:32:48:
While you are about it, why not make an extra shaft, then you can be sure that the first one you fitted will last forever. Such cynicism I expect from the young, not someone signing themselves as OLD Mart! 😂😂 Edited By Nick Clarke 3 on 31/08/2020 22:05:05 The "OLD" in Old Mart means he spoke of a lifetime experience |
Thread: Calling all Colchester Bantam owners. |
24/04/2021 21:27:09 |
Very nice and enjoyable machine but you will be buying tooling and things ..but wait until you see what comes with it. |
Thread: What to do when you lose something |
24/04/2021 21:21:33 |
What is ones chance of finding a way to stop small items falling on your foot and always find itself under a machine or table ? I decided one day to remove the work bench and clean the workshop, the list of long gone things will be several pages! |
