Here is a list of all the postings Peter Spink has made in our forums. Click on a thread name to jump to the thread.
Thread: Easy power tailstock feed for your lathe |
09/05/2022 23:44:47 |
Posted by Nigel Graham 2 on 09/05/2022 09:31:15:
Neat idea! I think I'd rather use a tapping-head for that, though - Assuming a lever feed, is it possible to use a tapping head in the tailstock? |
Thread: Lever operated tailstock attachment Myford |
08/03/2022 22:15:05 |
I have the rack version on mine - wouldn't be without it! |
Thread: Smart meter |
22/01/2022 20:03:38 |
Posted by Mark Rand on 22/01/2022 19:41:09
However, I suspect that without legislation, contract terms or a court order, disconnecting a domestic user's supply would be illegal. Quite so. With medical kit and freezers etc. this would never get past first base. Not that I'm inclined to get a not so smart meter. The only advantage would have been the option of low tarif at times of low demand. No chance of that now! |
22/01/2022 19:16:56 |
Quote <firstly a smart meter can disconnect the customer any time that the supplier wishes to reduce the loading on the supply circuit to . . . . . > How? |
Thread: Flexispeed Lathe |
14/10/2021 09:45:33 |
Robert, You have a PM. Regards, |
Thread: Routing |
08/10/2021 19:01:18 |
Posted by JasonB on 08/10/2021 15:56
As for skirting I tend to use the SCMS to do a mitre cut and then follow the line where the mitre cut meets the flat front face with a hand saw for the straight part and a coping saw for the scribed moulded part. Add a little back cut as you do it for a nice tight internal corner Done lots of scribed internal corners on skirting - wish I'd thought of that! 👍 |
Thread: 'Puter upgrade recommendations |
28/07/2021 13:22:53 |
As has been mentioned your setup doesn't look too bad! I'm running F360 on a Win 7 machine with 8GB ram, dual monitors and Intel built in graphics. Even though Autodesk says Win 7 is unsupported, it runs perfectly well, occasionally slow if it has to do something complicated to do. I would be looking elswhere for a bottleneck before buying a new machine. |
Thread: AA batteries |
27/07/2021 13:58:59 |
Posted by Grindstone Cowboy on 26/07/2021 23:11:22:
Some rough measurements using digital calipers . . . Do you now have lots of flat batteries? |
Thread: Flintlock pistol plans |
17/06/2021 19:59:48 |
Posted by Robert Atkinson 2 on 17/06/2021 18:47:56:
You don't actually need a licence for a functioning muzzle loader of "antique" design. I think you'll find you do - any functioning muzzle loader be it of modern design or a modern 'antique' lookalike would be a section 1 firearm. If it were a genuine antique (like a pair of duelling pistols) it would be exempt from licensing - the definition of 'antique' is open to interpretation but think of pre 1850 ish. Firearms law in the UK is a complete can of worms. Edited By Peter Spink on 17/06/2021 20:23:50 |
Thread: Gas Fitting |
11/04/2021 21:02:16 |
Posted by David Noble on 11/04/2021 20:39:03:
Does anyone know if I am 'legally' allowed to disconnect a gas cooker with a bayonet fitted flexible hose? Thanks, David Yes you are - that's what it's there for 👍 You should not, however, install a new cooker in its place as that would involve fitting a hose to the new cooker and commissioning it, which should be done by a Gase Safe registered engineer.
Edited By Peter Spink on 11/04/2021 21:06:54 |
Thread: Myford ML7 Chucks - Which one? |
05/02/2021 16:23:21 |
That looks nice! I was in a similar position a few years ago - inside jaws very worn and belmouthed but outside jaws as new, so now have the luxury of a new (TOS) 3 jaw and an old dedicated chuck with just the outside jaws - saves a lot of faff changing the jaws over! |
Thread: RPi (or something) to connect to VPS over OpenVPN |
02/02/2021 22:54:46 |
Great stuff, glad you're sorted! |
Thread: Have You considered getting a 3D printer |
30/01/2021 08:14:33 |
Posted by Ian Johnson 1 on 29/01/2021 23:59:24:
Out of interest Peter what type of filament did you use for the bracket? I would think it would get hot so close to the engine, maybe hot enough to melt PLA? I'm just getting into the world of 3D printing, my new toy, the Ender 3 V2 can use PLA or ABS, I'm using PLA at the moment because that's all I've got Nice engine by the way IanJ It's PLA Ian, hopfully being water cooled it shouldn't get hot enough to melt it - time will tell! |
29/01/2021 23:35:48 |
Horses for courses! The rest the old fashioned way.
22/01/2021 23:12:47 |
I've been running a Pi with Open VPN for a couple of years. Got all my info from here: **LINK**
Thread: Cura 4.8 |
19/01/2021 20:57:44 |
Many thanks for the input folks - lots to learn! Peter |
19/01/2021 15:01:51 |
Basic problem is that looking at a You Tube video on how to modify supports in Cura, I don't have the icons on my screen that the guy doing the demo has - and I can't find them even though it's supposed to be the same version! Many of us brought up on PCs or Macs can navigate our way around all sorts of different software quite easily and then we come across some software written by someone who's thrown all the standard UIs out of the window!
19/01/2021 12:03:23 |
Finally bit the bullet and bought a printer. Managed to get my head round Fusion 360, downloaded Cura 4.8 and printed a few easy parts to get me started. All good. Now wanting to dive a bit deeper and looking at supporting overhangs etc. Am I alone in finding Cura the most counter intuitive bit of software I have ever come across? |
Thread: Building Robinson Hot Air Engine |
16/01/2021 19:03:17 |
That's very nice, lovely job! |
Thread: Motor for a gyroscope. |
29/12/2020 10:35:23 |
Posted by duncan webster on 28/12/2020 23:42:00:
Absolutely not what you asked for, but how about half round teeth in the rotor periphery and an air jet? Turbine guy who writes in this forum should have some good suggestions Like this?
I always assumed this was intended for a missile where the gyro would be spun up during the launch period and then the nozzle would retract when up to speed.
