Member postings for Steamer1915
Here is a list of all the postings Steamer1915 has made in our forums. Click on a thread name to jump to the thread.
Thread: How much ?
04/04/2015 19:42:22
Posted by Bazyle on 04/04/2015 18:28:
Not so sure about things in a 99p show costing 99 pennies. Don't they cost 240 pennies with 1p back. Can't be bothered to calculate how many actual pennies that is.
Really Bazyle,
This is absolutely intolerable. wink
Steve.
Thread: Square Holes
19/03/2015 06:52:12
Hello Paul,
I don't know if this would suit your purposes, but it's a good method to know anyway...and it works!
Best regards,
Steve.
Square holes
Thread: Toolpost grinder tips?
26/02/2015 21:36:29
Hello Scott,
The first thing to do is lose a nought off the lathe spindle speed. 250 RPM would be a much more realistic work speed for grinding something that diameter.
Best regards,
Steve.
Thread: Myford ML7 Quick change tool post
24/01/2015 21:34:00
Plus one for the A&R holders.
Best regards,
Steve.
Thread: Who is going to Alexandra Palace tomorrow
19/01/2015 10:03:28
Note the date of that report.
By
12:08PM GMT 20 Jan 2014
Best regards,
Steve.
Thread: DRO on a Myford Super 7B
15/01/2015 11:22:14
Hello Martin,
Glad to hear that the handwheel dial is giving good service.
Best regards,
Steve.
Thread: South African Locomotives works drawings.
14/01/2015 15:03:47
Mine arrived this morning. Very pleased following a quick look. A great deal of info for your pound/dollar etc
I was lucky enough to drive a 15F a few times at Vereeniging depot in 1988, so these will make good reading and remind me of great days.
Steve.
Edited By Steamer1915 on 14/01/2015 15:04:19
Thread: No. of divisions
12/01/2015 20:22:37
Hello,
The sleeve gear is 31T 40DP as is the other bronze gear. The steel gears (including the centre shaft) are 29T 40DP. The 29T steel gears are 0.775" dia and the bronze gears are 0.825" dia.
Hope this helps,
Best regards,
Steve.
Thread: Free Plastic
29/12/2014 19:51:45
Hello Graham,
I sent a PM on this subject earlier today.
Best regards,
Steve.
Thread: triple expansion engine
26/12/2014 11:45:08
PM sent.
Steve.
Thread: Stepper Driver Help needed please
28/10/2014 08:48:19
Hello Les,
These are the terms that were placed on the eBay listing. "Returns: 14 days refund. Buyer pays return postage". Not sure how this relates to a faulty component but I think I'm on a bit of a sticky wicket anyway, as this was purchased 2nd September. I have only just got around to fitting it. In hindsight, I should have tried it when it first arrived.
I'm not sure that the output would be at mains potential. The motor is rated at 5.86V DC. I've been running the driver at 110V ac from a site transformer. I made this decision because the 220 volt limit made me think that UK mains voltage might be slightly too much.
Steve.
27/10/2014 20:55:41
Thanks Les,
I'll try to take some photos tomorrow but I don't know how good they will be.
Steve.
27/10/2014 20:13:00
Hello all,
I have been working on a CNC conversion for my Bridgeport Mill. The original idea was to just motorise the X axis and a 6” dia HV table so that the machine could cut gears whilst I got on with more mundane tasks.
The rotary table was done first with a NEMA 23 motor from Arc Euro and a cheap single axis TB6560 driver. BTW, I have found this driver absolutely fine for the NEMA 23 motor, despite hearing and reading many things to the contrary.
The X axis was the next to be undertaken using a Nema 42 motor and a DM2722A driver from Longs motors, again based in China. This was completed successfully and runs very well when driven with Mach3. For the gear cutting, I can live with the backlash on the X axis, but there are hopefully some ball-screws being brought into the UK for me next month.
Work has progressed on the Y axis conversion and I was all set last Friday to run both axis at once and cut a circle, albeit in fresh air. Unfortunately, the Y axis driver has shown an alarm from initial power up and refuses to work. I swapped the drivers over so that the “older” driver drove the Y axis and the motor was fine.
I have contacted the suppliers in China and they pretty much say that I must return the driver to them for testing, despite all my explanations and photos. I feel that they have me over a barrel really and the cost of posting to China and accompanying delays, doesn’t help my situation.
Is it going to be a practical proposition to have this driver repaired and is there anyone on this forum that could undertake such a task? I feel so frustrated because I came so close, even though I can still cut the gears ok.
Best regards,
Steve.
Edited By Steamer1915 on 27/10/2014 20:15:23
Edited By Steamer1915 on 27/10/2014 20:17:42
Thread: poor engineering companys
21/10/2014 16:54:00
PM sent.
21/10/2014 16:46:17
Hi Derek,
I can recommend John Dunn Engineering, he advertises in the Model Engineer magazine.
Best regards,
Steve.
Thread: A Self-Feeding Facing Tool
06/10/2014 20:38:24
The original article was published in 1960, not 2014.
Steve.
Thread: Outstanding Service
19/06/2014 18:30:26
Plus one for Arc Eurotrade. Ordered at Midday yesterday. Arrived today. Free postage as well.
8 items in all.
Usual disclaimer.
Steve
Thread: Myford lathe paint code.
28/05/2014 16:49:28
Thanks Mike,
This was for one of my customers in Germany. I suspect that he can have some mixed a lot cheaper than Myford's prices and also wouldn't have the carriage costs.
Best regards,
Steve.
28/05/2014 08:01:57
Hello all,
Does anyone happen to know the NCS paint code for the Myford Blue (Aqua).
Thanks and best regards,
Steve
Thread: Who's going to Harrogate
26/04/2014 12:04:51
I shall be on the "Yorkshire Model Engineering Supplies" stall all weekend. Please come and say hello.
Best regards,
Steve.
rapid Direct
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
