Member postings for Philip Borland
Here is a list of all the postings Philip Borland has made in our forums. Click on a thread name to jump to the thread.
Thread: Muncaster's Simple Entablature Engine
08/12/2019 12:00:22
John Chappell - you could try these
27/11/2019 13:53:08
Before and after taper
Cutting the taper
Parting off the square stock
To cut the forming tool, I used a 5mm dremmel stone - sold for sharpening chain saw blades - worked perfectly providing a nice curved cut out
Nearly there - not enough weekend days in a week!
Edited By JasonB on 27/11/2019 14:07:27
23/11/2019 21:23:28
Paul,
yes just flexed - as per the advice in the magazine articles.
Phil
23/11/2019 20:55:12
Thought I'd share my build.
Squaring the stock
Cutting out the excess using a scroll saw - saw this on clickspring (youtube) and it works really well.
Centering the rotary table with my new toy -works great
Struggled with clamping this on my small roatary table. I used a woodworking router bit for the roundover and it worked well
Working my way round the edges
PCD was easy with the DRO
Looks good!
I built a live centre for my boring head. 2 quid bearing from ebay, then made an insert to hold the centres from my tailstock live centre. Used a dti to give me 1mm of offset at the tail end.
Thread: Accessing Digital Issues
20/11/2019 17:39:05
Given that flash will stop working in 2020 for all browsers, much of the older content, will become unavailable. Is there a another way of accessing the digital back issues ? how is this going to work once flash is disabled
I see Neil's comment above - please explain
Phil
20/11/2019 12:55:17
I found these on a US site
Anyone else want one ? I have a friend coming over second week of December and I could slip a few in his luggage
18/11/2019 22:47:35
Excellent - Thanks Jason
18/11/2019 15:29:03
Is there a material list anywhere, or do I need to work through all the components to work out what is needed ?
I plan to start this and don't want to have to keep making trips to the metal monger.
EngineDIY
