Member postings for daveb
Here is a list of all the postings daveb has made in our forums. Click on a thread name to jump to the thread.
11/02/2018 16:37:58
Thaiguzzi, Hopper, it's a 91 Evo, fairly standard 1200, will add pics to my photos. Bike was running OK when I stopped using it, only 22K miles but I decided to have the frame powder coated. I got a bit busy with other things so it took 17 years to put it back together. Enjoyed reading about your trip Hopper, may be giving me ideas beyond my ability.
08/02/2018 21:41:01
I've just put my old Harley Sportster back on the road.
Recent TV advert for Coke, old fellow doing bucket list things, final scene, riding motorbike. My wife looked at the old fellow and said, 'That could be you'. I said 'No, he looks a lot younger'.
Depressing!!!
Thread: Dovetail cutter on brass
05/02/2018 21:52:31
As Neil said and the cutter needs to be very sharp.
Thread: Recommend T handle metric key set
01/02/2018 12:13:53
Posted by JasonB on 01/02/2018 07:30:23:
I also like the Eklind tee ones, proper metal tee not a plastic moulding on a L shape.
If you are filing down ends are you mixing metric keys and imperial fixing
If you are filing the ends of Allen keys, you have c**p Allen keys. smiley
Thread: What is a “Coventry die head”?
29/01/2018 20:33:03
Posted by websnail on 29/01/2018 20:16:56:
Posted by Mick B1 on 29/01/2018 09:25:03:
Posted by Hopper on 29/01/2018 09:15:59:
This means that once you have cut your thread, instead of having to reverse the lathe and wind your one-piece die and holder back off again, you simply yank that handle on the Coventry head and the four toothed cutting sections snap outwards, clearing the job and allowing the carriage to be wound back toward the tailstock with the lathe still running. Saves heaps of time on production work but not that essential for home use.
On the ones I've seen and used, 'twas t'other way about. You 'cocked' the diehead by rotating the handle till the 4 chasers clicked into closed position, ran the diehead up the workpiece to a stop, when the chasers sprang open so you could whip back the turret to index to the next tool.
Another very good point, was that the machine did not require reversing.
Who remembers using their right hand winding out the turret after a thread and at the same time using their left to get the tool post nearer the work piece, all in the name of speed.smiley
Sort of, I would spin the capstan handle with my right hand to retract the turret, at the same time operate the slide to part off and chamfer the part with my left, in one continuous motion wind back the turret which had indexed to the stop and the pull the lever to feed the bar. You could make a lot of parts very quickly, provided you didn't get your arms tangled up. It was best if you could work without being interrupted.
Thread: Lorch & Schmidt Tailstock
27/01/2018 12:33:49
It doesn't look like a Lorch part. Possibly made here during the war years when German goods were unavailable. There were British made copies of these lathes due to their utility for instrument making.
Thread: John Stevenson Trophy
26/01/2018 11:40:30
Does it contain a ground Bridgeport? smiley
Thread: Cat Litter Recommendation
21/01/2018 22:20:40
You really need cow poop, cat poop has completely the wrong consistency, if you roll some between your hands you will see what I mean, this is best done at arms length. indecision
Thread: Please help with fitting a Myford Tri Leva
21/01/2018 12:14:44
Posted by choochoo_baloo on 20/01/2018 22:54:15:
Posted by daveb on 20/01/2018 15:28:54:
Thanks for the specific instructions Dave. Do you mind me PM'ing you if I get stuck along the way?
You're welcome, I will help if I can. Daveb
Thread: London model engineering exhibition
20/01/2018 17:14:57
Stueeee, there was a big queue inside but no one else in the entrance foyer where the searcher lurked, we had no idea what was going on. I would strongly resist any attempt to confiscate anything, AP and the exhibition organisers can run the exhibition any way they please but if there are to be intrusive entry restrictions administered by officious twits I want to know about them in advance. Not sure about the number of trade stands but they will probably have to give up if their potential customers are treated like this. Will we all be strip searched next year?
Daveb
20/01/2018 15:28:54
You have to undo the headstock screws, these are usually very tight. Fit the lower belt guide, remove spindle and fit belts, assemble top end and fit belts to countershaft pulley. Adjust belts one at a time until they are just tight enough, if they are too tight the roller frame will distort and cause the belt to ride off and jam. Some patience is required to get it right, I persevered and was happy very with the outcome. There is enough effort involved for many people to look at alternatives, but they would probably prefer a Super7 anyway.
Daveb
20/01/2018 12:59:49
I went to the Alexandra Palace model engineering exhibition yesterday with my wife. As we walked through the doors from the Palm Court a young man dressed in blazer and flannels called after my wife, 'Bag! What's in the bag?' He was most unappreciative of my reply! I understand that the organisers H&S assessment may have considered a baggage search necessary but there was no clear signage of what was going on. It was clumsy and badly organised.
Daveb
Edited By daveb on 20/01/2018 13:10:49
Thread: beryllium copper compression spring needed
18/01/2018 13:37:17
Posted by *.* on 18/01/2018 12:30:55:
Remembering back to my aircraft days the MoD was very cautious and careful with regard to the use and handling of BeCu. So much so those that came into contact with it had the details added to their personal records in case of future claims for industrial related illness.
Same for things like Cadmium and Magnesium Thorium.
Personally I wouldn't have anything to do with it unless you can be sure you can maintain an adequate barrier between it and all points of entry on yourself.
Lofty
Many years ago I was told that a cut from Copper/Beryllium would sooner or later lead to a heart attack. Needless to say we handled the stuff carefully.
Daveb
Thread: Ten Useful Things
17/01/2018 22:20:54
Posted by Neil Wyatt on 17/01/2018 18:42:27:
Posted by daveb on 17/01/2018 16:29:32:
Sounds like a Borrowdale needle, used in surgery, dissection, microscopy and various prodding, cutting and poking jobs.
Never heard one called that before, I've found one reference to the name on Google.
I used to sell a lot of these 50 odd years ago, seem to be referred to as Dissecting needles nowadays. Daveb
17/01/2018 16:29:32
Posted by Neil Wyatt on 15/01/2018 22:40:03:
Posted by Richard Marks on 15/01/2018 22:21:59:
Add a retractable scalpel to your list, good for cutting, picking, scraping and other things.
Edited By Richard Marks on 15/01/2018 22:22:27
Yes, but then it would be eleven, I marginally use a needle more than a scalpel. Strictly it's a dissecting needle too
16/01/2018 14:57:14
17062011004.jpgGinger cat impersonating Rommel in Bridgeport column.
Thread: Kit Cars
15/01/2018 15:17:33
Friend had an XK150 looked like a later version of the XK120, nothing like the D Type.
I had an E Type, I think the best looking car ever. Not the best handling though.
Thread: Couple of things at Lidl
14/01/2018 17:21:59
Boys toys at Lidl.
I bought a furniture mover at Lidl for £9.95, I think the castors would cost more on their own. My wife looked very disapproving and asked what I wanted a skateboard for. I explained what it was, she told me not to play with it with my friend as we'd both finish up with broken hips. I wondered which one of us she thinks is the bad influence, we're both over 70.
Thread: Metal cutting bandsaw
09/01/2018 20:54:56
I bought my saw from APTC, There was a note saying that EEC rules did not allow tables for vertical operation so this item was no longer supplied. There is not much to fit the table to, it fits to the end of the blade guide with 2 screws. I made a table 150mm square X 3mm, used it once, haven't seen it for ages.
03/01/2018 22:47:31
Posted by Clive Hartland on 03/01/2018 16:16:23:
You have not mentioned, 'Sinclair' calculators. They came on the market in the UK also with a little FM radio which you made up from a kit, if it did not work you sent it in and it came back working. It had a little bulb type earphone.
I still have 2 Sinclair calculators, one a Scientific calculator. Very useful in the early days. Of course Clive Sinclair is famous for the C5 trike car ?
I bought one of the early Sinclair scientific calculators, came with a pack of cards to program the thing. Tedious!
Surplus motors for the Sinclair electric car (which actually looked like a childs plastic trike) provided motive power for a whole generation of model locomotives. Why didn't Sinclair just make the model locomotives to begin with?
I still have a Sinclair black box digital multimeter, tiny display but worked OK.
I could be wrong but I believe Clive Sinclair invented the mutiplexer for the digital display which made pocket calculators possible.
Daveb
Ausee.com.au
