Here is a list of all the postings Alan Gordon 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Flux |
04/12/2021 13:15:14 |
Thanks guys for all the excellent advice. |
04/12/2021 08:42:03 |
Hi everyone, Can any one advise ? Rather than mix with water, silver solder flux, is there a ready mixed paste available. If so where I might get it would be helpful. |
Thread: Compressor |
24/11/2021 12:31:45 |
Hi Folks, I am in the market for a small air compressor for general DIY use however it would have to be low noise, any recommendations ? |
Thread: Grinding paste |
07/11/2021 14:45:39 |
Thanks guys
07/11/2021 14:14:06 |
Thanks Andrew, Does this mean the higher the number the courser the paste ? |
07/11/2021 13:13:24 |
Hello everyone, i have obtained a few plastic syringes containing coloured pastes. I assume they are "grinding / lapping" pastes. each one has a number on it ranging from 0.5 - 40, could anyone tell me what these numbers indicate ?
Thread: Vega Carbs |
24/07/2021 14:08:07 |
Not yet Emgee, I made a cock up of the other carb body so I am about to finish a new one !!!, then I will start on the needle valve assembly.
24/07/2021 10:19:08 |
Thread: Vega Twin |
10/07/2021 10:41:25 |
Ah, I see Jason, you know I looked at this and had brain fog, it's an age thing. Many thanks
10/07/2021 08:42:09 |
Good morning everyone, Well, here I go again. This I hope is the last query I have with regards the plan ? The plan shows each carb body having two 8ba holes drilled, again I cannot see what they are for, and like the mountings plates previous any advice would be gratefully received. I will post pics soon of the carb build if of interest. Thank you all in anticipation. Got the stove paint Jason, thanks, |
20/06/2021 14:18:11 |
Hi Jason, Thought about that, but on the assumption that it will run !!!!! I was concerned that the paint would peel off due to heat, However I was thinking about using a car / motorcycle exhaust paint which I assume would be more resistant, If anyone has other alternative ideas ? |
20/06/2021 10:20:26 |
Edited By Alan Gordon 4 on 20/06/2021 10:21:33 |
19/06/2021 18:42:47 |
Hi Buffer, You know it genuinely never occurred to me to do this ! I am attempting the carbs at the moment and if it would be of interest I would be pleased to post a few photos. This build has been (almost) a death by a thousand cuts. but I would be pleased to offer any advice on the build to anyone undertaking this project. |
19/06/2021 11:51:16 |
Good morning chaps This question is really directed at any one who has built this engine. I am slowly but surely working through the construction of my Vega Twin. When I first got the plans I noticed that there was described on the plan "Mounting Plates". measuring 3" x 1.5" x 1/8 with two 2 BA tapped holes 0,375 apart in the centre. There is also shown two cut outs either end of the plate. For the life of me I cannot see what this plate is used for or where it goes. It is probably staring me in the face but any help from Vega builders would be appreciated. |
Thread: Sine bar |
05/06/2021 09:19:31 |
Thanks Guys, Very useful and constantly learning
05/06/2021 08:50:07 |
Hi Guys. I have aquired a set of Imperial Gauge Blocks but I need a Sine Bar. I would like the conventional 5" bar. There are a few on the net but some of them are giving a measurement of 125 mm which is less than the 5".( but is being advertised as 5 " Edited By Alan Gordon 4 on 05/06/2021 08:51:23 Edited By Alan Gordon 4 on 05/06/2021 08:52:14 Edited By Alan Gordon 4 on 05/06/2021 08:52:48 Edited By Alan Gordon 4 on 05/06/2021 08:53:34 |
Thread: Finish |
13/04/2021 08:09:15 |
Thanks Lads, Good advice.
11/04/2021 10:03:24 |
Morning folks, I need some advice: I am presently making the valves for my Vega Twin. The plan recommends making in one piece from Stainless steel I have some 8mm rod which is perfect, my trouble is trying to get a good finish on the stem? ( issue one), however I am contemplating making the valves from 3/32 silver steel and brazing the actual valve head made from SS, could anyone tell me if this is a good idea or helping me get a really smooth finish on the one piece valve. I am using an 8mm collet and cutting a 1/4" at a time and extending the rod through the collet thereby minimising any taper. |
Thread: Dykem |
02/04/2021 09:38:06 |
Wow !!!! all I wanted was to investigate how I might get some ??? anyway Thanks everyone for the invigorating discussion. Thanks Trev I tried Amazon but comes up as unavailable, but again thanks everyone. |
01/04/2021 08:18:35 |
Hi Folks, Any advice on where to buy some "Red" Dychem. (small bottle with brush in cap) I have tried Walters and Walters, Amazon. |
