Here is a list of all the postings dean clarke 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Bristol Hercules 100 |
12/02/2022 12:43:04 |
Have done mate, sorry for the delay, been a bit tied up with work. Dean |
13/01/2022 02:49:19 |
Id Be keen to have/buy them and im fairly certain I have the abilities to finish them. PM me if it works for you. Regards Dean Clarke |
Thread: supercharged V12 2 stroke |
18/08/2021 11:25:16 |
Well we're back in lock down again so maybe I'll get a look in on this engine project and see if I can't get something done on it. Dean Edited By dean clarke 2 on 18/08/2021 11:25:39 |
Thread: Taplin twin |
10/05/2021 23:08:57 |
Hi Mike, I can help with the taplin, PM me for details if your still needing help. Dean |
Thread: model engine world magazine |
05/05/2021 23:19:56 |
Yes tug your correct, model engine world was John Goodalls engine mag, sold it on to some guy whose name escapes me ATM but it is no longer in print, I have almost all of the issues if anyone needs something photocopied, happy to oblige. Dean |
Thread: TALE OF TWO VIPERS |
19/02/2021 21:39:31 |
Still working on this project too lol Dean |
19/02/2021 21:38:14 |
So...........been a little busy over the last few years and sorta sidetracked. I have however stumbled across this engine sitting way back in the workshop languishing in a sad state of neglect and have brought it forward to the front of the que once again. I stripped it down to check out the inside and give it a big clean and found a broken piston so am now in the process of remaking a set of pistons to slightly improved design. I'll update with photos in the next couple of days. Cheers Dean |
Thread: Help Needed to Identify This 5 Cylinder Radial Engine |
28/10/2020 19:26:12 |
Hi Alistair, many thanks for the mags, i'll let you know when they arrive, i've paypal'd the money to you. cheers Dean |
27/10/2020 23:59:39 |
Hi, yes still going on that project, be rather busy of late but will try to update the build threads in the next few days or so. cheers Dean |
27/10/2020 18:41:14 |
Yes please, pm me the total Inc shipping Att Dean 36 Campbell street Leamington Cambridge 3450 NEW ZEALAND Regards Dean |
Thread: Boll-Aero 1.8cc Diesel |
17/08/2020 04:14:59 |
You will find that when you heated the silver steel to solder you hardened it but without the next step of tempering you left the shaft hard, and therefore brittle. The sudden shock of the backfire was enough to fracture the component and the running loads brought to completion the part failure. A simple mistake to make when not understanding the metallurgy of the materials one is working with (from my own experience (lol very nice engine to by the way. Regards Dean |
29/10/2019 01:40:07 |
If at all possible I'd like to beg, borrow, steal or buy a copy of these drawings to please. cheers Dean |
30/05/2019 23:10:47 |
So not quite the naylon viper engines which are still languishing in the back burner but a step in the right direction at least......................... being that they're diesels anyway lol, just completed these two engines as part of the WOHM engine development program i'm involved with. regards Dean |
06/03/2019 20:53:39 |
Yeah I wonder about me too ......... REGULARLY lol Dean |
02/03/2019 05:45:25 |
Well as its been quite some time since my last little model engine confessions and even longer since updating this thread I thought it high time i pulled finger (as they say) and posted a bit more on the V12 project. I decided to do a bit of a rethink with this engine and went ahead and made some sand casting gear and cast up a couple of new cases for the V12. photos below show the depths of insanity that some will sink into if left alone long enough. So hears the end results Yeah I know I said a couple but if I want to end up with at least one good engine I should probably allow for so oopsies, lol cheers for now Dean Edited By dean clarke 2 on 02/03/2019 05:46:20 Edited By dean clarke 2 on 02/03/2019 05:46:38 |
Thread: air cooling options |
11/04/2018 04:27:16 |
You can also set up a gang saw in the milling machine to the correct thickness and gap etc and rotary mill them all in one go, way quicker and easier than turning each fin separately, especially if your making more than one cylinder head. Just a thought. cheers Dean |
Thread: Os Gemini twin glow engine - conrod req'd - no longer made |
07/02/2018 23:12:45 |
No Problem, will pop them in the post this weekend, sorry it took so long mate but we got there in the end. Cheers Dean |
07/02/2018 02:40:56 |
O.k. here is the latest on these rods. below shows the progress And.... all finished You may want to polish the crankshaft mick to ensure a good running surface, also double check the diameter before I post them back to you and let me know, should be a nominal 10mm or 9.98ish. Oh and also don't forget to torque the big ends down to the correct setting, which is 0.35nm cheers Dean |
31/01/2018 18:52:46 |
So here's a quick photo update to show the comparison of the OS Gemini rod to one from my latest Supercharged two stroke V8 project So anyone know the torque settings for an m2 big end bolt or perhaps the torque setting for the 0/80 bolt used on my V8 rods, I generally just use the torque setting of T.E. but not the F.T or E.F.T. and I've found that using the tightening instructions of " tighten till it shears and back off half a turn " doesn't really go to well either. i'm fairly certain that foot pounds and inch pounds torque on either of these bolts would result in the sheared off torque setting and that would be a bit of a waste of time. so anyone got any bright idea's. LOL (i'm kidding of course, no-one torques small model engine bolts, you don't have the same distortion when machining as in full size practice, well nothing that's actually measurable anyway.) cheers Dean
21/01/2018 23:34:07 |
HaHa, well they are in fact fairly big compared to what I normally make, I'll post a photo showing your rods compared to some for the engines I'm currently building. cheers Dean |
