Member postings for Grizzly bear
Here is a list of all the postings Grizzly bear has made in our forums. Click on a thread name to jump to the thread.
Thread: Dremel 4000 motor brush replacement
26/05/2016 20:54:46
Iain,
Google​ and or YouTube.
Regards, Bear..
Thread: electric - measuring the kwh for my workshop
28/04/2016 19:45:18
Frank,
A few months ago I changed the battery, now the first "auto" time does not work in auto (does in manual). Another £50 worth of rubbish.​End quote. If your timer operates in a similar fashion to plug-in timers, try switching it from ON to AUTO, rather than switching it from OFF to AUTO. Good luck.
Regards, Bear..
Thread: Interesting Machines
16/04/2016 20:28:49
Saw these, and thought of you!
I like the WD40 can.
Regards, Bear..
http://www.allaboutcircuits.com/news/three-awesome-maker-tools-that-arent-3d-printers/
Thread: Bridge Rectifiers
16/03/2016 20:07:31
Hi Norm,
Can you compare the old bridge against the new one, with your DVM.
If they are identical, then suspect fault elsewhere.
Regards, Bear..
Thread: chocolate block jumpers
03/03/2016 21:01:12
Duncan,
eBay,
http://www.ebay.co.uk/itm/6A-12-Way-Block-Plug-In-Terminal-Strips-Connector-Blocks-Male-Female-/151974470598
Regards, Bear..
Thread: Advice sought
02/03/2016 19:05:37
Google is your friend, several suggestions on getting access.
Regards, Bear..
Thread: Oil reservoirs
04/12/2015 22:52:13
Hi Chris,
3-4mm thick pressed 100% Wool Felt 60cm wide per 0.5 metre, free post on eBay.
£4.25
Search 'Felt fabric'
Usual disclaimer.
Bear..
03/12/2015 18:01:42
Hi Chris,
Mucho felt on the 'net.
http://www.jaharrison.co.uk/products/felt-products.asp
To name one. Usual disclaimer.
Bear..
Thread: Clearing out a workshop
30/11/2015 18:37:51
Nice lot of well loved machinery, brings a tear to the eye.
I'm filling up, sniff.
Regards, Bear..
Thread: Screw cutting Advice
06/11/2015 21:53:01
Geoff,
Put thermal fuse/cut-out in the freezer, restored it for me!
Bear..
Thread: Knurling Wheel 'Pins'
30/08/2015 18:49:33
Hi HasBean,
How about a 'Roll pin'
Regards, Bear..
Thread: Stainless Steel Pipe
05/05/2015 21:22:35
Neil,
Add a little cement to the sand, no need for a plug.
Bear..
Thread: 5/32 x 40 tpi unions for 1/16 pipe
24/03/2015 20:39:32
Hi Dougie,
Regards, Bear..
Thread: Todays update from Bodgers Lodge
06/03/2015 19:23:06
Hi JS,
Always good to get a glimpse of the real world. Please continue to post.
I'm still chuckling with regard to the Blidgeport.
Regards, Bear..
Thread: Woodwork Router Advice
06/03/2015 19:10:25
Hi Wallace,
Router Handbook, Router Jigs & Techniques. Both by Patrick Spielman (USA).
Regards, Bear..
Thread: Workshop visitors
21/02/2015 16:51:31
Hi Everyone,
Talking of traps, ensure all traps are anchored. Not only will it stop your traps disappearing, but will allow you to despatch any wounded prey.
Regards, Bear..
Thread: Designspark 2.0
20/12/2014 17:57:05
Nice, Ady1
Question for J.S.
John, How did you get the knurls/finger grips on those brush caps. Nice work.
If the answer is a knurling tool, my apologies for a silly question.
I'm not familiar with Corian.
Regards, Bear..
Thread: How to use a turning tool
19/12/2013 18:07:57
Hi Novice,
Picture please.
Regards, Bear..
Thread: need some of these making out of steels
08/12/2013 19:17:49
Hi Bill T1,
What about an half inch socket, as in spanner?
Regards, Bear..
Thread: Picaxe in programmable electronics
07/12/2013 16:52:01
Hi everyone,
Thanks again to all that have replied.
The venetian blind controller, I have two up and running. These are with picaxe 08M2 IC's, they have replaced the previous versions that were built using Cmos IC's.
Picaxe, I was using the Flowchart method, but when you request help from the Picaxe forum, everyone only speaks Basic.
So, I would like to get to grips with Basic, I'm happy with Picaxe, I was asking if there was anything better/easier.
Have downloaded the latest Picaxe Editor Beta. Now my USB programming cable doesn't know that it's connected to Com1, Says Com8 not connected . ( Running Win7).
Regards, Bear..
Ausee.com.au
