Member postings for Grizzly bear
Here is a list of all the postings Grizzly bear has made in our forums. Click on a thread name to jump to the thread.
Thread: What chance have we got?
12/02/2013 14:21:57
Thread: Simple bench grinder mod
22/01/2013 18:48:56
Hi Stuart, Good mod. I won't ask if they are magnetic. I agree, the dresser is a good tool.
Regards, Bear..
Thread: Chinese Lathe Accessories.
16/12/2012 20:41:38
I could murder a witches tit!
Regards, Bear..
Thread: Aircraft General Discussion
15/12/2012 17:09:29
Hello Everyone, Would anyone like to see the two emails, below?
I don't know how to post them. Could forward them to an email address.
Vulcan to the Falklands
B17 survival story
Regards, Bear..
Thread: Screw thread handbook
14/12/2012 21:07:41
Hi Everyone, Some good METRIC info. here. **LINK**
Regards, Bear..
Thread: Free Machining Stainless Steel
14/12/2012 20:53:16
Hi John, I would like to learn more about witches tits.
Regards, Bear..
14/12/2012 14:03:55
"If I can't find either, I usually try Maryland Metrics for threads and tap drill sizes"
Thank you, Andyf. Very comprehensive.
Regards, Bear..
13/12/2012 20:27:02
Hi Alan S 6, Well said.
Regards, Bear..
Thread: Fibre optic clock
13/12/2012 19:48:26
Hi Magpie, Looks like you are a very fast learner. Brilliant workmanship.
Regards, Bear..
Thread: Joining two pieces of 10mm stainless steel bar at right angles.
09/12/2012 19:37:09
Hello Everyone, I have just created my first album, please bear with me. Four pictures of the oven rods (Shelf supports). The job didn't turn out as good as Ians', but my customer was very pleased with the results.
Regards, Bear..
04/12/2012 22:54:27
Hi Everyone, Thank you all for your input, Coalburner,Grade 304, the other details are in the O.P.
I haven't got welding equip.
Ian, that look like a nice job, that is the way I'll go.
I didn't think I could get a tight enough bend on it without it cracking, not got enough to experiment with.
Regards, Bear..
Edited By Grizzly bear on 04/12/2012 22:55:20
04/12/2012 17:48:38
Help please, Joining two pieces of 10mm stainless steel bar at right angles.
Before you ask, its for a Neff oven. Extra shelf supports, 4 off. They are £35 each plus post & packing. So its a DIY job.
One length is 410mm, and at right angles at one end is a 30mm length.
The original rods have a real sharp 90° bend. I intend to bolt them together using a M4 bolt.
I'm after the neatest configuration. Tools; ML7 & vert slide + it will not beat me.
Regards, Bear..
Thread: Help for beginner
04/12/2012 17:28:34
Hi Jarek, Where are you from, Poland? Come back on the forum, you will get good help. (I have typed this slowly, so it will be easier to read).
Regards, Bear..
Thread: Upgrade to windows 8 ?
04/12/2012 17:19:04
Hello Everyone, A bit of info. regarding upgrading to Win8. There is an upgrade assistant to help you. **LINK** This info is from the Computeractive magazine. I'm sticking with Win7.
Regards, Bear..
Thread: pillar drill advice
30/11/2012 18:45:02
Hi David,
For £60 there is a number of drills that would fit the bill. I've just purchased a Clarke Metalmaster S/H for £40 & happy. Saw a Draper, similar spec. in our local tool store Abran Tools @ £59.99 Looked Good. (After I had purchased of course).
Regards, Bear..
Thread: Tool Post for Myford ML7
30/11/2012 18:33:11
Hi Phil,
Nice photo, you sorted that.
I have a ML7 too, sounds like good advice to remove the ratchet, mine has never lined up square. I will remove mine. It can't be a bad thing, the toolpost moving away from the work (Under extreme circumstances). Better than a hole in your head!
Regards, Bear..
29/11/2012 20:06:16
Hi Phil, Paperweights! Can you modify them so that they function? If you are able to cheat, turn the top slide a little until your toolpost is square mit the chuck, simples.
Tool height, pack them up with shims (washers, coins folded £20 note etc).
Regards, Bear..
Thread: Gratton Model Engineering, Derbys
28/11/2012 22:04:44
A Weihrauch HW100 is a nicely machined PCP air rifle.
Regards, Bear (Hunter gatherer)..
Thread: Its not Mickey Mouse
28/11/2012 21:47:24
A cheapish car / lawnmower 12volt battery could be the answer, it would last years, topped up with a battery charger. Plenty of smooth amps at your finger tips.
Regards Bear..
26/11/2012 20:27:36
Siddley, Interesting that you are a gunsmith. Do you work on PCP's as well. I live close to Daystate Ltd.
Regards, Bear..
Ausee.com.au
