Here is a list of all the postings Grizzly bear has made in our forums. Click on a thread name to jump to the thread.
Thread: Junior hacksaw blades |
07/03/2021 22:09:48 |
Roy, Make the blades from broken bandsaw blades. I doubt there are any wood blades, they wouldn't be accurate enough. Having said that: Irwin 14tpi Wood Junior Hacksaw Blades 6" (150mm) 10 Pack | Hand Saw Blades | Screwfix.com Bear.. |
06/03/2021 18:41:18 |
While on the subject of junior hacksaws, they make very good pruning saws. Use a woodworking bandsaw blade, cut to length and drilled for small self tappers. Used on the pull, watch your fingers. Bear.. |
Thread: water level sensor |
04/03/2021 18:46:41 |
Hi Duncan, "That would be neat, but what would I make it from bearing in mind it will be 4mm diameter or less." Make it from anything that floats. If your liquid is water, oil based liquid will float, I was thinking polystyrene or similar. You are a man of many talents, think outside of the box, or in your case, tube. If I'm talking rubbish, I haven't read all your posting. Defence rests.......... Bear.. |
03/03/2021 18:22:36 |
Duncan, Would a solid float work, sitting on top of the water? Good luck, Bear.. |
Thread: Last Night's Astro Image |
23/02/2021 18:25:19 |
Very good Neil, Pictures to be proud of. Bear.. |
Thread: You think you have trouble starting your car on a cold morning? |
16/02/2021 18:35:52 |
Not much thought for the batteries and starter motor. Typical driver! |
Thread: Drone Photography : Art meets Engineering |
16/02/2021 18:19:14 |
Thanks Michael, Very good.
Thread: Grinding out a small crack for welding with Dremel |
12/02/2021 18:38:42 |
9 inch 230 mm dia. if its a dinner plate. I blame the lockdown. Regards, Bear.. |
Thread: Driving Trolley |
26/01/2021 20:51:19 |
Impressive, I like it! |
Thread: Look out, here comes a woodturner |
04/01/2021 21:45:17 |
Hi Calum, Interesting Scots name. Regards, Bear.. |
Thread: Myford ml7 strange serial number |
18/12/2020 17:34:33 |
If it's any help, it does say 'Made in Poland'. Regards, Bear........... |
Thread: Pea shooters illegal |
12/12/2020 17:16:07 |
What about my RPG? Bear.. |
Thread: Myford Lathe Identification |
29/11/2020 18:23:10 |
Where in the world are you? Don't give your exact location, just a clue will do. Good luck, Bear.. P.S., Nice carpet too! Edited By Grizzly bear on 29/11/2020 18:24:48 |
Thread: Hall effect sensor |
26/11/2020 20:30:55 |
Any use? Introduction Hall Effect Switches Sensors Circuits Tutorial (bristolwatch.com) Bear.. |
Thread: Dremel 358-5 |
26/11/2020 20:13:53 |
Hi peak4, Please keep us posted. Mine is a 300 series, willing to help, if required. Bear.. |
Thread: Bushnell camera problem |
16/11/2020 18:29:41 |
https://www.thestalkingdirectory.co.uk/threads/bushnell-trail-cam-problem-repairs.62689/
Good luck, Bear.. |
Thread: Manual |
16/11/2020 18:19:50 |
http://www.lathes.co.uk/webster-bennett-d-dh-m-eh/
http://www.wigglesworth.com/display.cfm?p=811 Until you get a proper answer. Good luck, Bear.. |
Thread: C0 Lathe Blowing Fuses. Control board short? |
08/11/2020 17:09:28 |
Thanks for the update. I'm really pleased you fixed it, I was holding my breath. Bear.. |
Thread: unknown object |
21/10/2020 20:05:04 |
Looks like a Viking tooth pick to me! Regards, Bear.. |
Thread: Home Automation Technique |
10/10/2020 13:15:22 |
Phuket weather. Regards, Bear.. Edited By Grizzly bear on 10/10/2020 13:16:08 |
