Member postings for Chris Shelton
Here is a list of all the postings Chris Shelton has made in our forums. Click on a thread name to jump to the thread.
Thread: How can I fix this LCD display?
20/08/2020 17:53:26
Have you looked on the back of the printed circuit, look for dry joints on the pins to the lcd display.
Thread: Bulbs Electric Life of
25/07/2020 12:19:06
There is a MBC 12v halogen lamp which is 6W, number is HW6/Bax95, used on some of the more exotic cars, as front sidelight bulbs, under-run at 6V should last a very long time.
Edited By Chris Shelton on 25/07/2020 12:24:34
Thread: Death of a PSU
25/07/2020 12:08:13
The space made by the missing pin is for isolation.
Thread: Contacts in a Parkside Charger from Lidl's.
23/05/2020 12:30:45
Hi, techguru, does a teardown of Parkside batteries on youtube, the electronics for control of the battery and charging control is housed in the battery.
Thread: Help identifying thread
20/05/2020 14:40:41
Thank you,
To all who took the time to answer this query, 8-36 tap arrived today, and the threads do match.
Edited By Chris Shelton on 20/05/2020 14:41:00
17/05/2020 12:32:49
Thank you Jason for the explanation, and Tony P will let you know the outcome when my tap arrives at the end of next week.
16/05/2020 17:23:33
A local friend came to my rescue with a 5/32 BSW tap, after tapping the part it screwed onto the probe about half a turn, so have now ordered, an 8-32 tap, can someone tell me what the 8 in the 8-32 stands for?
Tony I will not hold you to your promise of a refund, after all I could tap some Meccano parts now.
16/05/2020 13:24:56
Thank you all for taking the time to reply, I have ordered a 5/32 BSW set of taps, as Tony P said it will work.
16/05/2020 12:21:47
Hi, Thank you for the replies, just found my engineers Black Book, and it looks as if it could be 5/32 BSW, which is not listed in Zeus
16/05/2020 11:32:38
Hi I have a thread on an American made car diagnostic probe, which I am having trouble identifying, the major diameter is 4mm or .1580" it is 32tpi. can anyone help, I need to purchase a tap to suit, have looked on the internet, but cannot match the details.
Thank you
Thread: Hobbymat lathe - couple of questions
28/12/2019 12:32:05
Hi Chris,
The gears are plastic, it might be possible to get some 3D printed, if you can find out the data on the gears needed.
Thread: I just added 50 mm of daylight...
27/10/2019 11:00:34
Hi John, after you said the Novamill was never available with an R8 Spindle, I had to go and check to make sure I was not having a senior moment, the mill is not being used at the moment, but yes it is an R8 spindle.
Photo included of the Coventry Easy Change/ R8 adaptor.img_0619.jpg
25/10/2019 11:33:39
Hi John,
I have the same milling machine, and on mine the BT30 holder was an adaptor, into an R8 spindle taper.
So on my mill the actual spindle is R8, removing the adaptor gave a lot more headroom.
HTH
Thread: What are these pliers for
15/10/2019 15:12:53
I have a pair of the pliers shown in the first photo, and have always thought they are used to crimp scotch lock connectors on wires, if that's not what they are designed for, they do this job admirably.
Edited By Chris Shelton on 15/10/2019 15:14:55
Thread: Battery charger problem
03/10/2019 09:58:47
Hi most of Parkside items are warranted for 3 years, but you have to have the original till receipt.
I do not know if this includes batteries.
Thread: This weeks offer at Lidl
22/11/2018 15:39:08
Hi All, some useful items coming up at Lidl on 29th November, Die grinder with 6 and 3.2mm collets £19.99, variable speed would make an ideal tool post grinder, and a pair of pump up airbags rated at 135Kg, ideal for lifting and holding things in place.
Edited By Chris Shelton on 22/11/2018 15:41:21
Thread: Kennedy Power Hacksaw Gaiter
08/09/2018 13:52:02
img_0399.jpgPhoto's of gaiter fitted to saw and spare one I found, img_0398.jpg which would be suitable, is from a clutch slave cylinder.
I also have some pdf files of the original manual, if anyone would like a copy, I don't think I can upload pdf to this posting.
07/09/2018 23:01:15
The gaiters from car steering racks would be suitable.
Thread: Micro-Weld carbon torch 1A
04/07/2018 14:00:48
Thank you all for taking the time to reply, I will not use it for the case, instead will look at fitting a foot switch to control it, but did not like the idea of switching the mains with a foot switch.
And I think it would have to be quite a substantial relay, to switch the output from the transformer.
Michael G. Thank you for the link, it looks as if the one shown has an extra din plug fitted to the front of it, probably for a foot switch.
Thread: Centre punch
04/07/2018 13:54:24
Hi Mark
This is the type you require, item No. on ebay 273308471022 £3.65 inc P&P
HTH
EngineDIY
