| Wolfie | 10/08/2012 17:24:21 |
Moderator 445 forum posts | I ordered a white grinding wheel from my local engineering supplier and when I went for it he'd come up with a usual grey one (although he called it green!) Now he says that will do so what if any is the difference of a white wheel? |
| jason udall | 10/08/2012 17:33:53 |
| 421 forum posts 8 photos | "green" wheels are "soft" for use on hard materials like carbide and tungsten carbide.. Soft in this case means the "grit" is held in with a soft binder so that it sheds and gives new cutting faces as you work..( otherwise the grit particles get blunt).. The White wheel is probably ali-oxide.. hard grit , hard binder... Both will "cut" carbide but the green wheel will require more frequent dressing . sorry cant help futher...Dave C seems well informed..
| David Clark 1 | 10/08/2012 17:57:51 |
Moderator 2760 forum posts 100 photos 18 articles | Hi Wolfie What is the code on the wheel? regards David
| David Littlewood | 10/08/2012 18:03:51 |
| 497 forum posts | The most common abrasive in grinding wheels is alumina (aluminium oxide), and the wheels made of this are most commonly white, sometimes pink, and possibly other colours. This is fine for grinding steel as alumina is harder than steel. It is not though hard enough for grinding tungsten carbide. The only commonly available materials for grinding this are silicon carbide and diamond. Green grit wheels are silicon carbide in a soft matrix. They do grind tugsten carbide, but slowly and with rapid wheel wear; they are really old hat, and diamond wheels are cheap enough, longer lasting and faster working. Stick to alumina wheels for HSS and diamond wheels for tungsten carbide. You supplier should be able to guide you as to the best grade, but a middling grade alumina in a vitreous medium should be fine. I don't know what the grey wheel signifies, you need to get him to be more precise. If it really is grey I doubt it is silicon carbide, but he must be able to tell you precisely what it is - he has no business to be selling grinding wheels if he can't. David Edit - DC's post appeared while I was composing this - he has asked the most sensible question of all! Edited By David Littlewood on 10/08/2012 18:05:44 |
| David Littlewood | 10/08/2012 18:11:08 |
| 497 forum posts | I think this reference **LINK** is fairly clear - and tells us that grey is commonly used for alumina wheels for fairly rough grinding. Now I come to think of it, my original bench grinder had coarse grey wheel on one end and a fine white one on the other. David |
| David Clark 1 | 10/08/2012 18:16:36 |
Moderator 2760 forum posts 100 photos 18 articles | Hi There The first thing I did with the grey wheels that came with the grinder was... throw them away. I expect you could have bought a new grinder with two cheap grey wheels for what they charged you for the single grey wheel. regards David
| JasonB | 10/08/2012 18:34:52 |
Moderator 2991 forum posts 355 photos | Grey wheels are usually carborundum, OK for general rough grinding.
J |
| David Littlewood | 10/08/2012 19:11:22 |
| 497 forum posts | Jason, I think you are cofusing carborundum (silicon carbide) with corundum (aluminium oxide). Grey wheels, AFAIK, are aluminium oxide, not silicon carbide. David |
| macmarch | 10/08/2012 19:40:48 |
| 132 forum posts 1 photos | Now that many of us are making our own cutter grinders pehaps David could persuade one of the grinding suppliers to produce a series in MEW regarding what does what and which types to use.
ray |
| Harold Hall 1 | 10/08/2012 19:48:18 |
| 241 forum posts | David asks what is the code on the wheel and I agree but we should also ask, What did you order, was it just the size and the colour White. Did you not quote a specification or at least what you intended to use it for. What do you intend to use it for, high speed steel, tungsten carbide or mild steel? You ask what is the differnce between a grey and a white wheel. Of the cuff I could not explain, but I do know that wheels intended for sharpening HSS tooling are invariably white, occasionally pink i think. In my experiance the white wheels I have are much superior for grinding HSS compared to the grey wheels on my general purpose grinder. Harold |
| JasonB | 10/08/2012 20:04:37 |
Moderator 2991 forum posts 355 photos | Dacid L Carborundum wheels here |
| David Littlewood | 10/08/2012 22:36:07 |
| 497 forum posts | Jason, If you expect retailers to always use the right word, you are obviously more of an optimist than I am. David |
| merlin | 10/08/2012 23:56:16 |
| 62 forum posts | I am pleased to see this conversation. I have given up phoning and emailing suppliers to try to locate a 125mm diameter x 16mm wide x 13mm bore wheel suitable for fine hand grinding HSS lathe tools. Only one supplier could help me but he could only sell me two wheels at about £18 each, which was too much. I have now put my old grey coarse wheel back on and resolved that one day, probably never, I will make sure that I can buy suitable 'special' wheels at the same time as buying a new bench grinder. I would be pleased to learn more about these new-fangled (to me) diamond wheels: speeds, temperatures, grit equivalents, good and bad treatment, etc., but I don't know where to find the information. Has there been an MEW article? |
| David Littlewood | 10/08/2012 23:58:24 |
| 497 forum posts | Merlin, Diamond wheels are, in general, totally unsuited to grinding steel of any description; have a look at the link I posted above. You should get a decent white alumina wheel. David |
| Martin W | 11/08/2012 00:00:32 |
| 398 forum posts 5 photos | Hi Interestingly, well maybe, is some of the grinding wheels listed as 'Green' shown on the site, as linked to by Jason, and being suitable for TCT tools are actually 'Grey' in the illustration. Maybe a illustrator's error or perhaps they are 'Grey' but 'Green' wheels. As David says and others have concurred with get the code for the wheel and then check for suitable uses. Cheers Martin |
| jason udall | 11/08/2012 00:10:57 |
| 421 forum posts 8 photos | I like merlin..have struggled to source good wheels ...for work.. three ..go clunk..returned four ..out off round..2-5 mm...returned one ..badly miss balanced...even if bore concentric to 0.1mm and "round"..returned... finally one fit to spin.....thats 1 in 9.. still too course (same grit/binder/ grade but defo not same wheel) after much dressing (thought I would run out of wheel!) passable results..drills still look like the have chip breakers though!
Best of luck.. Btw our centerless grinder wheels are blue/grey carborundum...
| merlin | 11/08/2012 00:29:50 |
| 62 forum posts | Not much point in saying this, but I am surprised that it is so difficult to buy a wheel for grinding HSS -lathe tools - surely a very common requirement in the ME world? Perhaps the small 125mm diameter requirement is the problem. I would have taken Geoge Thomas's advice and bought a white 80 or 100 grit wheel 30 years ago but I couldn't afford it then. In one of my recent phone calls a supplier told me that I needed green grit for HSS. |
| _Paul_ | 11/08/2012 01:55:27 |
330 forum posts 28 photos | Wheel info:
Paul |
| Michael Gilligan | 11/08/2012 06:53:29 |
| 1053 forum posts 60 photos | A very handy reference ... Thanks Paul Is this standard across all [reputable] manufacturers ? MichaelG. |
| _Paul_ | 11/08/2012 13:14:45 |
Posted by Michael Gilligan on 11/08/2012 06:53:29:
A very handy reference ... Thanks Paul Is this standard across all [reputable] manufacturers ? MichaelG. Not sure about all manufacturers but AFAIK most of the major ones. I normally buy my wheels from Abtec either through their site or on occasion when they have a sale on eBay. Just bought 2x PA 54 JV wheels from their eBay auction for less than a tenner with shipping. Regards
Paul |
Visit The New
Model Engineer
Exhibition Website.
