| Ady1 | 07/08/2012 23:31:17 |
| 692 forum posts 43 photos | On fleabay, but it's the interchangability of composite sections which makes it interesting Almost like a Transformers Toy Remove the X at the beginning of the www.Xebay link to view |
| David Littlewood | 08/08/2012 00:01:54 |
| 510 forum posts | Link didn't work for me. David |
| John Stevenson | 08/08/2012 00:11:20 |
| Moderator 1780 forum posts 2 photos | For some reason he put an X infront of Ebay ?
| Alistair Grant 3 | 08/08/2012 00:14:35 |
| 5 forum posts | David, Just go to ebay site and search for 330767741825. This is the item number |
| Michael Gilligan | 08/08/2012 00:21:29 |
| 1121 forum posts 62 photos | Here is Cool Tool website and there is a promotional video on You Tube, dated 04-Dec-2007 [not for me, thanks] MichaelG. |
| Ady1 | 08/08/2012 01:02:32 |
| 692 forum posts 43 photos | For some reason he put an X infront of Ebay ? fleabay links are verboten in here |
| Sid Herbage | 08/08/2012 01:43:40 |
| 556 forum posts 9 photos |
Posted by Ady1 on 08/08/2012 01:02:32:
Are they? When did that happen? .... seems to me there have been plenty in the past |
| Springbok | 08/08/2012 05:12:23 |
698 forum posts 34 photos | Ve haf vays of makeing you talk so you had better explain vy das ist verbotten!!
Bob |
| Michael Gilligan | 08/08/2012 07:41:22 |
| 1121 forum posts 62 photos | One interesting point ... mentioned in the text under that You Tube Video
The availability of [very] long beds and cross-slides. That's a significant advantage of using extrusions ... I wonder if they are available individually ? MichaelG.
______________________________________________
The availability of [very] long beds and cross-slides. With a nod to Michael Williams' comments on the Metalmaster thread ... obviously there would be terrific problems with alignment at those distances ... but it would be very useful raw material.
Edited By Michael Gilligan on 08/08/2012 07:43:16 |
| Michael Gilligan | 08/08/2012 07:58:01 |
| 1121 forum posts 62 photos | O.K. "Cool Tool" suddenly gets very interesting. Would this install and run on a Raspberry Pi ??? MichaelG.
First thoughts are here GPIO looks the way to go Edited By Michael Gilligan on 08/08/2012 08:15:40 |
| David Clark 1 | 08/08/2012 09:05:02 |
Moderator 2763 forum posts 100 photos 18 articles | Who banned Fleabay links then? We might delete them if somone consistently posted links to their own auctions otherwise we leave them alone. They are obsolete in a few weeks anyway so not a good idea. regards David Edited By David Clark 1 on 08/08/2012 10:13:14 |
| DerryUK | 08/08/2012 10:06:25 |
| 101 forum posts | <Would this install and run on a Raspberry Pi ???> There is a caveat in LinuxCNC requirements that video and system memory should be separate ie not shared in system memory. The way things are going with RasPi though someone will crack it. |
| Michael Gilligan | 08/08/2012 10:33:44 |
| 1121 forum posts 62 photos | Thanks Derry, I will sit back and wait for the Geeks to do something amazing. MichaelG. |
| Peter G. Shaw | 08/08/2012 12:46:44 |
518 forum posts 29 photos | This is the metal version of the original Unimat 1 which is a very low power machine using plastic & aluminium. Peter G. Shaw
| Kevin Bennett | 08/08/2012 18:40:54 |
78 forum posts 11 photos | hi all you can do anything with this type of aluminium extrusion if you want to be creative you can get all types of aluminium extrusion from Flex link i am having a go at using it for a cutter grinder using the 40 x 40 mm section. i am lucky as i have a contact at my old work place so i can get hold of small off cuts TY Kevin |
Visit The New
Model Engineer
Exhibition Website.
