| Cornish Jack | 02/08/2012 11:54:59 |
| 259 forum posts 20 photos | G'day all - again. Does anyone have any idea what happens to drill chuck keys? They seem to disappear like chinagraph pencils and ball point pens. Presumably there is a place where they congregate. I have two or three chucks which need keys and the combination 4 way jobs are not suitable. Is there a supplier with a comprehensive listing or, alternatively, can anyone point me towards a method of making my own - they look simple but I can foresee considerable difficulties, particularly with the bevel pinions? TIA Rgds Bill |
| David Clark 1 | 02/08/2012 12:01:56 |
Moderator 2763 forum posts 100 photos 18 articles | Hi There Buy new chuck keys, buy some pot magnets, screw pot magnets to drill, put chuck key on magnet. Stand back and admire your work. regards david
| KWIL | 02/08/2012 12:08:12 |
| 1436 forum posts 41 photos | Small spring tool clips work as well, never put a key down, always put it back!! |
| Bazyle | 02/08/2012 12:16:10 |
| 657 forum posts 30 photos | As with the outside jaws for lathe chucks they will appear eventually on ebay with absolutely no information as to origin or even size most of the time, Then the idiot wondetrs why nobody bids and just bins them. It would be an idea for this and other auction fodder to have a guide on this site that explains the pertinent data to be provided. Then people could be pointed to it. |
| Cornish Jack | 02/08/2012 14:41:21 |
| 259 forum posts 20 photos | Helpful tips so far for KEEPING them safe!! What I need is info on OBTAINING them!! I assume that there must be a) a standard to which the things are manufactured and b) firms which manufacture/sell/distribute them. If so, they are notable by their absence from all my searches, so far. Obviously, the stem and 'T' bar are straightforward - it's the bevelled gear/pinion which is the tricky bit - making or buying. Rgds Bill |
| David Clark 1 | 02/08/2012 15:02:14 |
Moderator 2763 forum posts 100 photos 18 articles | Hi There A Jacobs no 31 chuck has a K31 chuck key. Does that help? regards David
Edited By David Clark 1 on 02/08/2012 15:02:33 |
| David Clark 1 | 02/08/2012 15:05:38 |
Moderator 2763 forum posts 100 photos 18 articles | A quick search on Google bought up loads of chuck keys for 2 or 3 quid each including postage. Search Surprise, surprise, Jacobs Chuck key. You could of course search Jacob's chuck key but the first search was fine. regards David |
| Niloch | 02/08/2012 15:10:21 |
| 298 forum posts | Buy a keyless chuck
Edited By Niloch on 02/08/2012 15:12:26 |
| Springbok | 02/08/2012 15:28:12 |
698 forum posts 34 photos |
I as a habit I hang back up a tool whenever I have used it, it saves so much time and swearing. Bob
| Stub Mandrel | 02/08/2012 21:08:13 |
3229 forum posts 262 photos | I'm with springbok. those tools with cases or that I have made hooks or holders for always go back in place as it's sort of rewarding to put them 'back to bed'. Neil |
| Cornish Jack | 03/08/2012 11:11:30 |
| 259 forum posts 20 photos | Thanks all for the suggestions for bolting stable doors etc. Thank you David - yes, lots of chuck keys, given that it is a recognised manufacturer or one of those awful multi-function things. What is totally absent is ANYTHING on first principles of making same. For anyone in a similar position the only useful inputs, so far, are a couple of Youtube items, one demonstrating the use of drill bit and flat blade screwdriver and the other, drill bit and pipe grips. Both methods quite effective and less damaging than the ill-fitting multi jobs. Ultimately, of course, the answer is replace them all with keyless. Rgds Bill |
| Ian S C | 04/08/2012 11:41:37 |
2727 forum posts 93 photos |
A Jacobs 34 chuck (1/2" I think every workshop in the world has a colony of little folk who come and borrow things, and hide things, then when your not looking for that tool etc they bring them back, and put them just where you left them. Ian S C |
| Cornish Jack | 04/08/2012 12:07:33 |
| 259 forum posts 20 photos | Absolutely right, Ian - and, unfortunately, I encourage the little %$**"+s by maintaining the untidiest workshop imaginable!! NOT, I hasten to add, a matter of pride - just a practical acceptance that I'm naturally untidy - for those who might consider offering appropriate advice for the 'condition' , Thank you, but no thank you. At 78, new tricks are beyond the reach of this particular old dog! Rgds Bill |
| Bazyle | 04/08/2012 12:09:29 |
| 657 forum posts 30 photos | The key is in effect just a bevel gear. Diameter determined from position of hole in chuck, tooth pitch and angle again measured off chuck. It would then be useful if keys were defined in those terms, plus size of arbour. |
| Michael Poole | 04/08/2012 12:11:10 |
51 forum posts 1 photos |
I think this link covers jacobs chucks find the size you want then google Mike |
| thomas oliver 2 | 04/08/2012 16:05:41 |
| 35 forum posts | I once bought 4 brand new Jacobs keyless chucks. I have never overtightened or abused them. Nevertheless each one in turn stripped the locking sleeve or the front sleeve. These are simply force fitted onto a fairly fine and very short spline, and do not stand up. I have managed to make and fit alloy sleeves on two and they have stood up OK up to now. I would be cautious about these chucks, and feel it would be best to buy all metal types. |
| Steve Garnett | 04/08/2012 16:49:39 |
| 837 forum posts 27 photos |
Posted by Cornish Jack on 02/08/2012 11:54:59:
Does anyone have any idea what happens to drill chuck keys? They seem to disappear like chinagraph pencils and ball point pens. Presumably there is a place where they congregate. Yeah, usually the outer reaches of your workshop. They generally get there when you forget, leave them in the machine, and then start it! Okay, okay, I'm only joking - I'm sure you don't do that (do you?) We have a scissor vortex; they're always disappearing. And I'm sure that there's some sort of vortex operating on my bank account too... |
| Sid Herbage | 04/08/2012 17:17:41 |
| 556 forum posts 9 photos | I rather liked this solution from the Polytech forum:
| Trevor Drabble | 04/08/2012 23:58:37 |
53 forum posts 3 photos | Bill, The only readily available information I know of relating to chucks and their keys, is that shown within 2 tables of a Cromwell Tools catalogue ( page 750 of 2010 issue). There are no technical details, only correlations between Jacobs/Rohm chucks and various chuck keys, the model numbers of which I assume are universal within the trade. If you feel it would help, I can take a snap and email it to you. Trevor |
| Ian S C | 05/08/2012 09:26:29 |
2727 forum posts 93 photos | Just google jacobs chucks. Bill, your workshop and mine, theres even a bit of a veiw of one of my benches in my album with my Ross Yoke hot air engine. Often its not the subject of the photo, but all the other bits. Ian S C |
Visit The New
Model Engineer
Exhibition Website.
