Forum sponsored by Arc Euro Trade
Foot pump type suds supply?
Need a hands free design
John Coates09/07/2012 21:37:06
432 forum posts
12 photos
Hi all
I was parting off some stainless steel tonight and it's proving a tough job to get a good finish. But I am progressing so that's not the issue. What is is the inconvenience of having to work cack handed, turning the cross slide with my left hand so I can apply cutting fluid with my right hand. I have more feel with my right hand to avoid digging in. So I need an option to let me use my natural hand on the cross slide but apply cutting fluid to the job.
I've seen ideas in MEW to use a tank above the lathe but mine stands in the middle of the garage. I think that using a foot pump, like the sort used to pump up airbeds, to push fluid up via a tub to a positionable nozzle mounted on the lathe could be a solution.
What do folks think?
Michael Gilligan09/07/2012 22:26:21
1052 forum posts
60 photos
Sounds worth a try, John
Only two [related] problems I can foresee
1. Because you are pumping air, the flow will vary with the pressure
2. ... and fluid will continue to flow until the pressure subsides.
These may be perfectly acceptable to you. Alternatively, some sort of pressure regulator in the air-line would solve (1).
Dave Tointon09/07/2012 22:27:40
49 forum posts
G'Day John,
Why not do as the professionals and fit a proper electric suds pump and tank. The chinese ones are not expensive and give good service.
Dave Tointon
Andyf09/07/2012 22:29:06
332 forum posts
Why not? Maybe use a tyre pump to force air into the top of a sealed vessel containing suds, to act as a low-pressure reservoir so the flow doesn't stop when you lift your foot ready for the next push.
Your idea reminds me of an advert in a prewar Army and Navy Store catalogue: a portable shower for explorers etc to take into the jungle. It comprised a footpump with a long rubber hose leading to a ring of rubber tubing with holes in it. You stood in a bowl of water with the ring round your neck and pumped away, no doubt wearing your solar topee for the further amusement of the local tribesmen. Best to wash your face in the water first, I suppose.
Andy
Michael Cox 109/07/2012 23:01:08
199 forum posts
7 photos
You can use a windscreen washer pump to pump the cooolant/cutting fluid to the workpiece. The motor speed can be varied from drops to a jet by regulating the motor voltage. An article on this was published in MEW No 181 page 20.
John Coates10/07/2012 07:09:01
432 forum posts
12 photos
Thanks guys
Michael - must admit my idea was to have fluid in the pump reservoir (imagine one of those round cylinder type foot pumps) so when I stepped on it the cutting fluid would be forced up a tube and out of the nozzle. Maybe I would rig up a supply with a one way valve to keep the reservoir full
Dave - I'll have a look for some chinese options (ooer madam! can just see the missus being really impressed by me Googling for chinese + lubricant)
Mike - I'll dig out MEW 181
Onward and erm, well onwards anyway cheeky
Michael Horner10/07/2012 07:30:13
49 forum posts
8 photos
If you only want small amount of lubricant at a time I have used hand soap bottle that I have fitted a metal tube into the exit orrifice so that I can attache a plastic tube too. They have a built in one way valve.
Michael
Michael Gilligan10/07/2012 08:31:00
1052 forum posts
60 photos
John,
My misunderstanding ... When you said "like the sort used to pump up airbeds" I presumed that you meant the rubberised fabric "bellows" pump.
Now that I understand your intention, I would agree with Mike regarding the Windscreen Washer pump.
I do have some reservations about life expectancy [ of the pump components ] because of contact with chemicals that are outside its design specification ... but hopefully all should be well.
Ian S C10/07/2012 09:51:54
2642 forum posts
93 photos
I use a little squeeze bottle (ex PVA glue), butyou could hang a container above the lathe with a length of plastic tube with a nozzle of some sort, and a clamp (similar to a medical IV drip system). Ian S C
Neil Greenaway10/07/2012 09:55:35
39 forum posts
Hi There,
As a child we used to have a caravan that was fitted with a foot operated pump for the sink unit in the kitchen area - I think it was a diaphram pump probably made by whale and was quite effective - was self priming from the water barrel outside and with gentle pumping you could carefully control the water flow.
This could be a simple alternative if they are still available and if you wanted to look into it. I used a windscreen washer pump for a number of years on my power hacksaw with the original car reservoir fitted under the saw frame for recirculating the coolant - worked ok for years until it sat dry for a while and gummed up - but it was obtained from a breakers yard anyway so easily replaced.
Bogstandard210/07/2012 10:11:29
186 forum posts
Why do people always make life difficult for themselves.
If you lot came to a ditch you could jump across, someone here would want to replicate the Forth road bridge over it.
It has already been mentioned that a plastic bottle hanging upside down with it's bottom end cut off ( yes, you have to top it up now and again ) and a bit of tube with a simple fish tank type valve controlling the flow, and a straightened out coat hanger wire to guide it where it is wanted.
Gravity is free, and is always there.
Most probably a fiver at most.
Edited By Bogstandard2 on 10/07/2012 10:12:03
Bogstandard210/07/2012 10:13:17
186 forum posts
Richard Parsons10/07/2012 12:22:06
645 forum posts
33 photos
Mine cost me nowt. I took a washed out bean tin. pinched two holes in it. I soldered a bit of broken clothes hanger into it. sharpened a bit of fire wood to a point which I poked into the other hole.
The wood is adjusted so the cutting oil oozes down the wood onto the wire and drips off the end onto the work piece.
Cost 2 pence for the soap and 1 penny for the solder.
Stub Mandrel10/07/2012 21:27:00
3073 forum posts
255 photos
I just dip an old toothbrush in cutting oil and hold its bristles to the work with my left hand.
Michael Gilligan10/07/2012 22:42:37
1052 forum posts
60 photos
Posted by Bogstandard2 on 10/07/2012 10:13:17:
< etc. >
A. Sometimes just for the fun of it ... the intellectual challenge ... the ingenuity ... the adventure
B. Years ago, I heard this lovely Liverpudlian description: "Using a Rolls Royce to kill a pig"
... OK it's wasteful; but it has a certain elegance
Now ... Has anyone tried using a Peristaltic Pump for Coolant?
Edited By Michael Gilligan on 10/07/2012 22:49:01
Michael Cox 110/07/2012 22:50:21
199 forum posts
7 photos
The benefits of using a windscreen washer pump are twofold. Firstly with any sort of drip system then sooner or later the drip tray or catch container becomes full of coolant that has to be removed and cleaned up. This is not always easy and a pump enables the fluid to be recirculated. The second benefit is that the feedrate is readily adjusted by varying the motor voltage. This is not always easy using the sort of pinch vales used on plastic tubes.
_Paul_11/07/2012 08:00:11
330 forum posts
28 photos
@ Michael Cox
Mike, do you have a particular washer pump you could recommend? as I am quietly leaning to towards trying a washer pump setup out it would be nice to start with a "known value".
Do you suffer from corrosion and if so how do you cope with it the reason I ask is that I have a built in suds pump on one of my donkey saws and it always seems to rust the machine no matter how diligently I mop it up.
Paul
Michael Cox 111/07/2012 09:10:57
199 forum posts
7 photos
Hi Paul,
I had two windscreen wash pumps in my scrap box. One was marked SEIM and was made in France. It was a gear pump with plastic gears. The other one was marked Linwood and it had a rubber impeller. I was not sure of the compatability of rubber with oil based coolants so I opted for the SEIM pump.
The SEIM pump has been in contact with neat mineral oil for over 4 years and it still works well.
I avoid the use of aqueous coolants whereever possible because of the rust problem (and staining of metal surfaces that slide together). I generally use a 50/50 mixture of engine oil and white spirite as coolant.
Gordon W11/07/2012 11:03:03
602 forum posts
Washer fluid seems to be alcohol based so pumps should be ok with oil, I've never had a problem. Hand water pumps are still available, but may be rubber based. Another way is to use an old car fuel pump, mechanical usually cam driven but will work with just a "bump" on a shaft, depending on dia. and speed. Means you don't need a power supply.
Paul Lousick06/08/2012 11:19:38
88 forum posts
24 photos
I have been using a windscreen washer pump on my mill for the last 6 months and has been great. Power is from a small 12V battery via a variable resistor to adjust the speed and an old plugpack charger to top up the battery. Got the pump from a car parts supplier for about $10, an old 4 litre plastic bottle as a tank and a plastic water strainer from the local hardware.
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
ArcEuro Trade
RDG Tools
Diamond Engineering
TRANSWAVE Converters
Advertise With Us
Drives Direct Ltd
G and M tools
Avanquest
