Sieg SX2+ Tramming
| Nyrup Boegh | 10/06/2012 14:07:07 |
| 10 forum posts | Hi I have now done some milling on my SX2+ milling machine that I bought lately. I have done some measurements to. Using a Dial Indicator I can measure that the "noding" (Y-axis allignment) is about 0.119 degree, calculated using trigonometry from the deflection of the DI (0.25mm over a distance of 120mm travel of the Y axis). The question is: Should I try to fix this. The column is bolted to the base. If I have to adjust it I must try to insert some shims between the base and the column. I anticipate it will be difficult to do and to get it right. Has anybody any experience in doing this kind of tramming work on a SX2+ or similar machine? Kind regard, Nyrup |
| David Clark 1 | 10/06/2012 14:30:59 |
Moderator 2760 forum posts 100 photos 18 articles | Hi There Are you sure the column is out? Could the quill be out of alignment with the column? I would put a square against the column from the table and check with feeler gauges. I have not done this mill but did a Dore Westbury a few years ago with no problems. regards David
| Tony Pratt 1 | 10/06/2012 15:55:42 |
| 228 forum posts | Hi, are you actually tramming the head, ie swinging a DTI on the end of an L shaped bar through 360 degrees? If the spindle is at 90 degrees to the table the DTI reading will be constant in any position. Tony |
| Nyrup Boegh | 11/06/2012 07:55:58 |
| 10 forum posts | Hi
Thank you for you answers. When I get the time (hopefully in the weekend) I must try both the square method and the L-bar method. I think I can unscrew the bar-pillar system from my magnetic base and use that in a collet or the drill-chuck. I'm not sure that I have shims that is thin enough. I have a roll of 0,1mm shim. Perhaps I could use thin paper as shim? Would that feasible?
Kind regard, |
| Roger Woollett | 11/06/2012 09:04:40 |
| 41 forum posts | Another thing to check is the adjustment of the gib strip for the milling head. If this is slack the head may well nod forward. Also make shure that the head is locked when you make your measurements. Roger Woollett |
| David Clark 1 | 11/06/2012 09:18:59 |
Moderator 2760 forum posts 100 photos 18 articles | Hi there That sounds like the table is out in the Y axis, not necessarily the column or spindle alignment.You need to put a parallel onto the table in the Y axis and shim up one end until the indicator reads true while traversing across the Y axis and then check the spindle by rotating an indicator at 180 degrees from the front to the back of the parallel. Then you will know if the spindle is square to the head. regards David
| Nyrup Boegh | 18/06/2012 08:25:13 |
| 10 forum posts | Hi
I have now investigated the tramming further.
I'm not done with all your recommended tests, but partly so, my conclusion is that the surface of the x-table were at an right angle to the column but the y-axis motion or traverse were not at at an right angle to the column. The result were that the distance from the tool in the spindle to the work piece were not constant when traversing the y-axis. I wonder if every small from Sieg is this inaccurate or I am expecting to much - or perhaps overlooking something or misinterpreting something.
Yesterday I was milling some steel in the process of making some more T-nuts.
Kind regard, |
| blowlamp | 18/06/2012 08:44:33 |
521 forum posts 8 photos | Is this machine new? If it is, then get in touch with the supplier and get them to exchange it for a better one. If you have to repair this for yourself, then you will need to work through the alignments in a methodical way and try and stay away from shimming (ugh, horrible way to fix something!), as much as you can. Martin. |
| David Clark 1 | 18/06/2012 08:50:44 |
Moderator 2760 forum posts 100 photos 18 articles | Hi There I would machine a plate on the table to sit the vice on. Only needs to be about 1/2 inch think. Aluminium would do. regards david
| Steambuff | 18/06/2012 09:43:34 |
268 forum posts 1 photos | Nyrup, Since the Sieg SX2 is fairly new ..... when you got the machine did you strip it down, to clean out all the shipping gunge, casting sand etc? (Arc have instructions for this process for several of their machines on there Website)
| Nyrup Boegh | 18/06/2012 13:01:08 |
| 10 forum posts | Hi
Once again, thank you for your answers.
I bought from Arc because even with postage included money was saved compared to fx. Rothwerk and the SX2 with R8 spindle is not available at all.
I have already dismantled, cleaned and lubricated the complete X/Y table.
The machine was, as you might already have guessed, bought new. But as the fright is expensive and troublesome the possibility of returning the machine is not an option.
Kind regard,
| KWIL | 18/06/2012 15:19:12 |
| 1423 forum posts 41 photos | If you bought it from ArcEuro, email Ketan for his comments before you go any further. |
| Bazyle | 18/06/2012 21:44:36 |
| 598 forum posts 30 photos | No fewer than 7 potential errors exist in the Y axis. 1 The y axis slide on the base must be 90 degrees to tthe column 2 the table x slides must be parallel wrt the y axis slides 3 the x axis slides must be parallel to the table top 4 the head slides must be parallel to the column 5 the quill slide must be parallel to the head slides 6 the spindle must be parallel to the quill 7 the spindle taper must be aligned to the spindle. On average positive errors cancel the negative ones but on probability sometimes they will all add up in the wrong direction. No wonder the top machines cost a bundle. |
| jason udall | 18/06/2012 23:48:02 |
| 420 forum posts 8 photos | "2 the table x slides must be parallel wrt the y axis slides"
perpendicular is more traditional
Though I have seen CNC mills based on "Hexapod" ...but these rely on machine computing to allow orthogonal input...not really mill ..more robot arm with mill spindle end effectors...
| Stub Mandrel | 19/06/2012 20:52:12 |
3067 forum posts 255 photos | I am worried that you say you shimmed the column to keep the spindle to table distance constant. If you need to do that it can only meanteh table is not of cosistent thickness - this is an unlikely error. How are you checking things? Can you post a picture or diagram to show exactly what you are measuring and the size of the errors? Neii |
| Nyrup Boegh | 20/06/2012 15:54:38 |
| 10 forum posts | Hi Thank you for your concern and your comments.
I have thought more about this tramming business and come to the conclusion that "Stub Mandrel" mention: I can't shim the column to remedy the problem that I have.
So the problem must be in the remaining assembly somewhere.
Kind regard,
| Russell Eberhardt | 22/06/2012 15:16:14 |
413 forum posts 13 photos | If you look about halfway down this thread you will see a good description of how to tram the head/column. Russell.
| Nyrup Boegh | 25/06/2012 09:10:05 |
| 10 forum posts | Hi Russell
Thank you for your tip. I will surly remember the tip. I have been thinking of something similar but had not thought about removing the head- column assembly from the base and how much easyer that would be compared to lifting the head off the column and replacing it to measure. Also I have read about the method of averaging the measurements readings of the bar and gaining accuracy in that way. But I had forgotten the method. Surely it was good to get the memory refreshed!
By the way. I have been tinkering with the tramming since my last post and somehow I have slowly
Now I will continue to use my mill and check how good or bad it performs.
Kind regard, |
Visit The New
Model Engineer
Exhibition Website.
