Forum sponsored by Arc Euro Trade
Silver Solder case hardened steel.
can you without destroying the case?
Rob Manley09/06/2012 21:03:09
70 forum posts
14 photos
So, can you silver solder two steel parts together, one case hardened and one soft, without destroying the case on the first part? I am creating half of a thrust race and need to solder a shaped arm to the outer diameter. There is no other way of joining the two.
Any idea? Rob.
Stub Mandrel09/06/2012 21:27:27
3073 forum posts
255 photos
My understanding is that the silver soldering process anneals the case, so you have to quench it from red hot to restore the hardness then temper. This could be difficult if using a silver solder that melts below or at red heat!
What about making it then hardening it?
Jeff Dayman09/06/2012 21:40:44
522 forum posts
7 photos
"can you silver solder two steel parts together, one case hardened and one soft, without destroying the case on the first part?"
Not likely, only way is try it and see to what degree hardness is lost. A hot torch and fastest water quench possible afterward will give best chances of least lost hardness.
TIG welding may give better results but disctortion and some loss of local hardening would still happen.
For best results if a hardened race is needed with an extended arm, the whole thing should probably cut from tool steel or gauge stock and heat treated as a single piece afterward.
In an industrial application I would try and design a non hardened race-carrier piece with the arm as part of it, and press in the case hardened thrust race. That way a worn race could be removed and replaced without having to make and heat treat a costly one-piece arm and race.
JD
John Ockleshaw 110/06/2012 02:33:24
10 forum posts
Rob, You may like to remake the thrust race in a steel suitable for nitriding.
Silver solder the arm, made of any steel, to it then have the assembly nitrided.
At 510 deg.C the silver solder will not become plastic and the atmosphere will prevent scaling of your job.
Graham
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
ArcEuro Trade
RDG Tools
Diamond Engineering
Drives Direct Ltd
G and M tools
Avanquest
Advertise With Us
TRANSWAVE Converters
