Forum sponsored by Arc Euro Trade
Converting a Vernier Height Gage to Digital?
Pete08/06/2012 22:32:38
32 forum posts
I had to think really hard before posting about this since many will disagree with me. But the artical in the July issue of MEW does require some additional information that wasn't properly covered.
It's not my place to say what anyone should or shouldn't do with anything they happen to own or buy. But due to inexperience, People following that artical may end up with far less than they started with. Starret and Mitutoyo to name just 2 manufactures today still produce high quality vernier height gages. And there were litterly dozens more in the past. All those very well made vernier height gages are in fact a lot more accurate (but slower to read) than most high cost and barely affordable dial and digital models built today. There's not enough information around, But it really should be closer to comman knowlege. You should search for what the terms actually mean when buying accurate metrology equipment. Accuracy and resolution are not properly understood and confused by far too many.
If you were to spend less than an hour learning the proper way to read a vernier scale, And a bit of time checking the accuracys obtainable with them against what the much higher priced dial and digital ones are capable of? Then personaly I don't think I'd be all that quick to convert a well made but older vernier gage over to digital. And I'm saying that because I bought a brand new digital height gage built by Mitutoyo. Both Mitutoyo and Starrett built very high quality equipment with the prices to match. So if they build far in excess of $1,000.00 height gages with all the technology they have avalible, Yet they state the repeatable accuracys are only within a couple of .001?
Personaly I fail to see where adapting a rather cheaply made Chinese digital scale will give you anything approaching what the original vernier scale does for repeatable accuracy on a tool that was well made and accurate to begin with. Yes it's faster, But a tape measure is also much faster and much cheaper than a height gage.
If the accuracys avalible from those cheaper built digital height gages are good enough for what your doing? Then I'd just buy one of those and refrain from making irreversable modifications to an old tool that will be mostly worthless to anyone else once your done with it.
Pete
Nicholas Farr09/06/2012 07:09:46
815 forum posts
223 photos
Hi Pete, to be fair to the author of the article, he hasn't suggested converting an expensive highly accurate height gauge. One advantage as mentioned, is that the digital readout can be zeroed at any point along the scale. The original readout has not been made useless, as it is written in the text that should the battery fail in the digital readout the analogue scale can still be used. As far as I can see, there is no clam that this is of any higher accuracy than a high quality vernier height gauge.
I see this article as taking a relatively cheap height gauge and a reasonable priced digital readout to make an inexpensive height gauge to ones preference, which should have a reasonable amount of accuracy, providing some thought and care is taken during the conversion.
Regards Nick.
Bogstandard209/06/2012 07:31:21
186 forum posts
Pete,
I have to agree with you wholeheartedly, purely because a height gauge is is not as accurate as people think they are.
The normal use of a height gauge is for laying out, and then usually machining to 'split the scribed line'.
When you consider the width of an accurately scribed line is on average about 0.002" (0.05mm) wide when using a height gauge scribing attachment, then that will be your expected accuracy.
A few years ago, I myself considered converting over from my vernier one to a digital, but common sense kicked in, and so I didn't bother.
The vernier one I have now needs no batteries, is very accurate, and has served me well for over 20 years, so I can see it lasting me for the time I have left quite admirably.
John Stevenson09/06/2012 09:34:40
1717 forum posts
Devils advocate here.
If the vernier ones are so accurate and so reliable why don't they exist in industry any more ?
Two local companies i visit, one an aerospace company and one that actually makes CMM measuring machines only have digital hight gauges in their inspection labs.
John S.
Ian Phillips09/06/2012 09:51:20
571 forum posts
11 photos
Posted by John Stevenson on 09/06/2012 09:34:40:
John S.
Probably several complex reasons,
Because its cheaper to make a digital one
Digital is easier and quicker to read,
It makes the company metrology lab look high tech and up to date.
I think manufacturing cost is the main driving force
Ian
NJH09/06/2012 10:51:37
1021 forum posts
81 photos
Well I didn't have a height gauge and a couple of years ago I got a 18" digital version ( from our friends at Machine DRO) as a Christmas present from my wife.   ( How did she know that I would like that I wonder?) It is a very solid, well made and finished item. It does have a couple of advantages over the normal vernier :-
1. It is MUCH easier to read without the need for magnifying glasses (for failing eyes)
2. It reads in either metric or imperial and converts between them at the touch of a button.
3. A zero point can be set at any point. This is very useful as a centre line can be set out at the appropriate distance from the surface plate and scribed, the gauge zeroed then plus and minus dimensions easily entered and scribed.
4. It is relatively cheap - about 1/6 of the cost of a Mitutoyo vernier (which would thus be way out of my league.)
In all I find it very useful.
If I had a good quality vernier would I butcher it to add a digital facility?
NO - I hate messing with good equipment - but I might still buy the digital version for the convenience and flexibility of its operation.
Norman
Edited By NJH on 09/06/2012 10:52:06
Edited By NJH on 09/06/2012 10:52:55
Edited By NJH on 09/06/2012 11:12:08
Bogstandard209/06/2012 11:02:14
186 forum posts
John,
Having worked in a metrology lab myself for six months, we never had the need for such a low accuracy item as a height gauge, either digital or vernier.
We did use digital height measuring, but nothing like a height gauge, they were probes set into a very rigid measuring upstand that fed their readings to a display box, all being calibrated to the super accurate surface plate they sat upon, all contained inside a dustproof plastic case.
I did state that my height gauge is used for marking out, but now that I have accurate DRO's on my machines, the marking out is limited to double checking my machining with a DRO, and very rarely do I split the line any more, unless it is on some not too accurate job.
Martin W09/06/2012 11:25:03
398 forum posts
5 photos
Hi
While I would not advocate destroying/converting a quality measuring instrument the article does, in my opinion, have merit in showing what can be done to make life easier in the 'Amateur's' workshop.
The comments about the accuracy of the old vernier instruments compared to the modern digital instruments doesn't really hold water. Modern digital measuring instruments are now offering resolutions to 0.001mm, 1 micron, with an accuracy better than + 0.002mm. They also have the capability of setting the '0' at any point, making relative measurements, measure in metric or imperial units, are easily read and come at a reasonable price. No wonder they are finding their way into everyday engineering situations.
No I am not a youngster looking for an easy way out but well into retirement and still ready to accept new ideas when they have merit. That said I still have and treasure my father's vernier calliper made by P Roch, Rolle, Switzerland complete with its purple lined case, circa 1939. Do I use it, no, would I ever butcher it, of course not.
Modern WELL MADE measuring instruments are every bit as good or even better than the items they replace.
Just my penny worth wink 2.
Martin W
 PS
Hi Norm
Looks like I was cogitating about my post when you submitted yours, sorry about the repeats but at least we are coming from a similar direction.
Cheers
Edited By Martin W on 09/06/2012 11:31:11
NJH09/06/2012 11:49:59
1021 forum posts
81 photos
Hi Martin
Well having clocked up 68 years a couple of days ago I too do a lot of "cogitating" these days - I guess I am an "Old Cogitater" - or is that Old Codger ??
I do all this for fun and think myself very lucky to have found an interest which is wholly absorbing and seems to offer limitless possibilities for further discovery and enjoyment.
Cheers
Norman
Tony Pratt 109/06/2012 13:11:59
232 forum posts
Digital readouts/calipers/height gauges etc are so much easier to read and extremely convenient. To the unwary they also give the impression of greater accuracy but in reality the machine or instruments precision or otherwise is unchanged.
Tony
John Stevenson09/06/2012 16:19:15
1717 forum posts
Posted by Ian Phillips on 09/06/2012 09:51:20:
Ian
That only works if the fancy gear is up to spec and these places are checked out regulary.
I have two or three vernier high gauges but none have been checked, how do I know 12" is 12" ?
Ok for smaller measurements you could use slip gauges for the crunch is who's checked them ad i mean truthfully ?
John S.
Pete09/06/2012 19:43:06
32 forum posts
Yes,I do know what the artical says, But it also doesn't say what accuracys you can resonablly expect. And as I mentioned, Far too many think because there's all those zeros after the decimal point, Then anything digital has to be really accurate no matter how cheap it is to buy. And nowhere does it mention or warn against destroying any value that's left on all those finely built Vernier Gages. There's a lot of those older height gages around now at fairly cheap prices, And yes a cheap one was used in that artical. Personaly I'd hate to see that type of work done on some of these old but fine tools due to inexperience and thinking it's a great idea to do so. If you do know your going to destroy a tools value and still chose to do so? That's fine, But a bit illogical to me.
And I'd also agree that very accurate digital equipment can be bought today that is extremly accurate. But not normaly at a price most of us would be happy to pay. I know exactly how much it hurt to buy my 12" digital Mitutoyo, And it's repeatable accuracy. But I also have a very good set of gage blocks that do allow accurate checks to be done. So if and when it's rarely required, I can use my height gage for accurate measurements beyond the inaccuracys of the tool itself.
Industry has gone to digital equipment for many reasons, Less mistakes, speed of measurements, ease of usage would be just 3.That's also why I've bought some digital equipment. LOL, Due to age and not needing that magnifying glass is really nice too.
I guess the main reason I started this thread was it cost me far too much to lean the little I do know the hard way. I wouldn't like to see anyone else have to do the same. Maybe I'm wrong, But I still happen to think forums like these are or should be where the more experienced can help to educate the less experienced. And since this sub forum is for anything in MEW. I figured this was the correct place to add what I thought was missed in that artical. Overall I do think it was well done. It's just that it missed those important points.
And as usual, John Stevenson is 100% correct, But that's another reason I bought good gage blocks. I can calibrate and check my own equipment so they all agree with each other. Maybe not to National recognised standards. But my gage blocks are my standards. Yearly metrology lab recertification probably isn't needed by the vast majority here either. Being within a few thou is more than good enough for almost anything most including myself will normaly need to do.
But If this thread helps even one person to understand the value of some of the older tooling and the difference between resolution and accuracy, Then it will have been worth it IMO.
Pete
Stub Mandrel09/06/2012 21:42:11
3073 forum posts
255 photos
I have a mid-price vernier and several digital ones. I never use the manual one, not least because it took me an evening to adjust the vernier so it reads zero at zero and I therefore don't wholly trust it. That said it does now agree with my digitral callipers when applied to the 1" standard test bar supplied with my (digital) 2" mike.
Some years ago, someone wrote an article about restoring an original first-generation Mitutoyo digital micrometer!
But I wopuldn't advocate buthchering a nice piece of kit to 'digitise' it. Why not just take the jaw off the end of a digital calliper, grind the other jaw to shape or fit a gauge plate scriber, and fit the whole shebang to a base? It should be easy to get the scale within a fraction of a degree of vertical, and a basic trig will tell you that any remaining error will be vanishingly small.
Edit - quick check, if the caliper is a 6" model and its 1 degree out (easily seen to be out by eye) the error at 6" will be just less than 0.001" Half a degree out (still visible to the eye) and the error would be less than a quarter of a thou.
Neil.
Edited By Stub Mandrel on 09/06/2012 21:45:59
Martin W09/06/2012 22:07:11
398 forum posts
5 photos
Pete
I totally agree with the sentiments of your last post. There is much made of the number of zeros after the decimal point with scant regard or little understanding as to resolution, accuracy and repeatability which can lead the unwary and over eager into problems. That said the price of electronic/digital devices is constantly being reduced and good quality kit is becoming affordable for the non-professional user, even if some of the 'Branded' makes still charge inflated prices probably put down to traceability, inspection, calibration etc which is to a degree valid.
However there are companies that offer what appears to be high specification instruments at reasonable prices as well as their top of the line kit, usual exclusion clause, such as this one.
Keep posting as its good to have new blood on the forums.
Cheers
Martin
John Stevenson09/06/2012 23:41:00
1717 forum posts
I do agree with some of the sentiment here, just because it's digital doesn't mean to say it's the dogs bollocks.
Some things are best left manual, I bought these some while ago and whilst they work fine I cannot see how they are better that the other manual set i have, both are good for a thou.
John S.
Pete09/06/2012 23:51:36
32 forum posts
Hi Martin,
Thanks for the encouragement to post more often. Norman will know me and my thoughts, John Stevenson will also know me from the HSM forum.LOL,Then again they may not freely admit to that fact. There's a few others I can place due to their user names.
There is, And thankfully it is very uncomman, The very rare person who gets a weird perverse satisfaction from knowingly posting incorrect information. I'm not the type who tollerates games like that at the expence of the inexperienced. So far I've yet to see one of those on this forum. So I guess I should post or at least spend more time here. Overall there is much less argueing, And it seems much more actual logic used on this forum, So that's a nice refreshing change.
Well except for that last picture of Sir Johns that is. I do have to laugh every time I see it.
Pete
Edited By Pete on 09/06/2012 23:57:05
Stub Mandrel10/06/2012 17:49:40
3073 forum posts
255 photos
I thought it was a CNC machine tool - I know they can round hexagons into cylinders faster than any lathe.
jason udall11/06/2012 10:49:35
421 forum posts
8 photos
Not arguing with the "accuracy vs resolution" warning but the article in MEW shows a , {to me}, sympathetic ADDITION of a digital scale to an existing instrument.
Agreed , strapping a digital scale to a base and using a out of square arm and column will not achieve the expected (or advertised ) level of accuracy , but again that’s not what was done.
Using a height gage (sic) as a marking out tool is more of a "sin" {to me} but then I am new to home engineering.
but hey , I come to this from electronics....component tolerances 0.1 to 20 % ,device parameters (for same device ) of 10 to 1,000 ...it all had to work within spec. first to 1000 th off the line.
btw
Always wonder why no tolerances shown on MEW drawings ,It seems in Mechanical engineering that production drawings are often tolerance in "strange" ways ..I have seen features tolerenced such that other features entirely disapear..if dimensions exert to limits. Seems to be getting worst too...are they relying on 3sigma?
Rdgs
David Clark 111/06/2012 11:23:18
2760 forum posts
100 photos
18 articles
Hi Jason U
No tolerences because model engineers make one part to fit the next and so on.
Rarely do they need to be interchangeable.
regards David
jason udall11/06/2012 11:33:15
421 forum posts
8 photos
Thanks...Fits might help in some cases....I all ways seem to try for too "nice" a fit...learning that this is not always desirable...friction vs sealing...oh well another engineering comomise compromise....
Edited By jason udall on 11/06/2012 11:36:58
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
ArcEuro Trade
Diamond Engineering
RDG Tools
Advertise With Us
Drives Direct Ltd
G and M tools
Avanquest
TRANSWAVE Converters
