Harrison lathe accuracy ?
RICHARD GREEN 230/05/2012 22:17:06
108 forum posts
45 photos
Hello everyone,
I've got a Harrison M500 lathe, I bought it from a dealer last year , and after proprely levelling it up with a Moore and Wright machine level, it was turning about 30 thou tapered over about 6",
I have discovered that the headstock is not adjustable like the two Colchesters that I've also got,
It was suggested by a machine tool fitter that I might be able to shim the headstock to get better acuracy,
The headstock is clamped down firnly on the rear "V" of the bed,
After several evenings experimenting with shims and taking many trial cuts I have an accuracy of 1 thou tapered over 4 inches, on both boring and turning, also betwen centres is the same,
Is this accuracy about what can be expected from a lathe pushing 30 years old ?
Am I having a mid life crisis, or have I got a lathe thats OK ?
It seems unrealistic to expect a lathe to keep It's accuracy for it's entire life with a non adjustable headstock,
What sort of accuracy do you men get with the Harrison "square head" M250 or M400 lathes ? I presume they are also non adjustable as well,
Or am Imissing something ?
Apart from this It's a nice machine.
Richard.
blowlamp30/05/2012 22:41:23
530 forum posts
8 photos
If you have leveled the bed and were getting 30 thou, what have you done to reduce the error to 1 thou?
I have an M250 and it turns as near parallel as I could want - I can get the taper to go either way, depending on the material and the tool combination, so if your machine is with little wear and abuse, then I don't see why you shouldn't get similar results.
Martin.
David Littlewood30/05/2012 23:16:04
510 forum posts
Richard,
I have an M300, and the accuracy is a lot better than that! I got it down to a thou or two per foot, but I haven't finished fine tuning it yet.
The fixing of the headstock to the bed is definitely not something I would recommend fiddling with, and neither (in the case of the M300 at least) would I want to mess with the fixing of the lathe bed to the stand. What I did was to fit some jacking feet to the bottom of the stand, and to adjust them to remove any wind in the bed. It is perhaps surprising to the uninitiated that something so rigid, and weighing over 2/3 of a tonne, that there is enough flexibility to do that, but there is.
Levelling the bed is, in my opinion at least, a delusion; you will never get it spot on by this method. The only method to do this is to keep taking small test cuts while adjusting one pair of feet to remove wind. If it cuts small at the headstock, raise the front foot at the tailstock, and vice-versa. Do this with a very stout bar of MS, not supported by the tailstock, and take very small cuts to avoid bending the test piece.
David
Edited By David Littlewood on 30/05/2012 23:17:41
Jon31/05/2012 00:04:29
261 forum posts
Probably looking at a thou last year on my M300 and dependant upon material turned.
What feet are you using David? Supplied M20 bolts i think they are sink in to the concrete. Ideally need something to spread the load.
Agree Harrison went to great lengths scrapingand checking everything in tolerance before leaving factory. Whether machines been picked up by the head or disturbed in any way would affect, they have mentioned it some where.
David Littlewood31/05/2012 02:13:56
510 forum posts
Jon,
My M300 stand has threaded M12 holes in its feet. I used adjustable feet like these:
- not these exact ones, I got mine from Key, but can't find them now on their website. Thread them into the holes and then adjust with a spanner.
David
MICHAEL WILLIAMS31/05/2012 08:24:14
896 forum posts
11 photos
Hi Richard ,
For a Harrison lathe headstock to have moved enough to generate 30 thou in 6 inches taper is beyond credibility even after thirty years hard use . I really suggest that you put the headstock back in its original position and look elsewere for problem source .
David has suggested bed twist already .Other favourites are :
Severe bed wear especialy at heastock end .
Worn out , damaged or out of adjustment spindle bearings .
A common difficulty on old machines is that the bearings have lost all their preload leaving spindle loose to move in any direction .
Seen sometimes on machines which have had rough useage is a spindle bearing which has worn off to one side and then been tightened up again to take up clearance .
The headstock is not the original one supplied with the lathe when new .
Regards ,
Michael Williams .
Edited By MICHAEL WILLIAMS on 31/05/2012 08:39:43
RICHARD GREEN 231/05/2012 08:54:18
108 forum posts
45 photos
I put a piece of 1 1/2" silver steel in the chuck and it ran concentrically, but was high on the outer end, so I've raised the rear of the headstock to compensate for it, thats how I got it from 30 thou to 1 thou.
The bed looks to be in very good condition, so I think my real trouble is possibly in the main spindle bearings, possibly being worn.
There is no movement in the main spindle when I check it with a dial gauge, but whats happening at 300rpm I dont know.
Richard.
mick31/05/2012 09:27:06
187 forum posts
14 photos
The one way of reducing error is to introduce a slight degree of twist into the bedway, this is not scientific as you need to jack up one of the tailstock leveling screws, take a test cut and occording to the direction of any taper, slacken or tighten either or both of the clamping screws untill the reading is papallel. That's the only real way of adjusting an older machine and is a proven method in industrial workshops. Good luck
Harold Hall 131/05/2012 09:45:47
243 forum posts
Unfortunately Richard I have no experience with a Harrison M500, I have to manage with a Myford series seven. Before Myford owners take that the wrong way its a fine machine.
As I cannot add much to the thread, my main reason is to agree with David as it is good to see someone adding some common sense to the subject levelling the lathe. So often we are given here, or in the magazines, the impression that this is the be all and and all of the subject. For me, if you do not have a level do not worry, turning a test piece and adjusting the lathes mounting is the all important requirement.
When I placed my workshop in a new garden the only suitable position required a large area of the space to have the soil built up by around 1 metre. It is still settling after 30 years and if I were paranoid about the lathe being level I would probably be resetting it every few months. As a result the bed of my lathe is far from level but still turns parallel within very acceptable limits. That is achieved by turning a test piece and making the adjustments to the lathe's mounting as the results indicate.
Harold
blowlamp31/05/2012 09:48:48
530 forum posts
8 photos
Posted by RICHARD GREEN 2 on 31/05/2012 08:54:18:
Richard.
You don't mean that you have unbolted the headstock and shimmed it do you?
If there is no play in the headstock bearings, then you'll gain nothing by touching them - you certainly won't want to buy any when you find out the price either!
So with no wear in the bed and no play in the bearings, it would seem we are down to an alignment problem. First thing to do is be 100% sure that the bed is without twist, i.e. it is 'level' when gauged against the working surfaces of the bed.
Once this is done, the lathe should turn to close limits of parallelism that are similar to those obtained by the manufacturer. If the results are still unacceptable then you need to find out why the headstock is not properly aligned to the bed, which would probably involve separating the two and checking for signs of tampering.
Martin.
David Littlewood31/05/2012 12:06:08
510 forum posts
I should add to my answer about the jacking feet by saying that the M12 nut shown in the link is redundant, at least on my M300 cabinet; the M12 stud screws into the threaded hole in the feet, and a spanner on the bottom nut (which is actually fixed to the stud) will adjust the height. I guess the M12 nut is for use when there is only a plain hole to use, or as a locknut.
Harold, thanks for the comment, glad to see I'm not the only one who thinks levelling is unnecessary. In fact I do try to keep the bed of my lathes reasonably level, but only so I can use it as a reference if needed - and I can't remember actually so needing!
David
Edited By David Littlewood on 31/05/2012 12:06:52
KWIL31/05/2012 12:27:31
1436 forum posts
41 photos
"Spare" nut is for locking against machine base to prevent movement should your machine vibrate.
The preload on the main bearings is measured with the machine at running temperature. Best advice, do not touch unless you know what you are doing and have the right tools. As Blowlamp says Super Gamet bearings are very "pricey"
David Littlewood31/05/2012 12:52:23
510 forum posts
KWIL,
I did suggest the locknut use - though just how much vibration it would need to cause a foot to rotate under 1/4 tonne of compressive load must be left to the imagination.
David
KWIL31/05/2012 14:12:33
1436 forum posts
41 photos
There are however some machine mounts which do not have a fixed foot and a ball ended threaded shaft bears in the centre of a cup. This type could be affected by vibration. The fixed foot types are more stable but perhaps more difficult to adjust accurately because you are trying to rotate the foot on the floor under your 1/4 tonne compressive load, hence perhaps the two nuts?
RICHARD GREEN 231/05/2012 14:57:20
108 forum posts
45 photos
Hello Blowlamp,
I've done all things that you suggest last year,
The bed is level, the bearings seem to be OK, the bed looks to be in good condition, so the only option left was to shim the headstock, which I've done , at least it's made the lathe usable, although I'm not really happy with it, I didn't have much choice, I had jobs to do with it and had to do something.
Who dares wins ?
It's a big lathe, 10" centre height and 80" between centres, it's probably done some heavy work in it's life, but as Michael says it shouldn't move much in 30 years of hard work
Richard.
David Clark 131/05/2012 15:06:34
2763 forum posts
100 photos
18 articles
Hi There
The feet I use are supplied by J&L industrial. They are quite solid with rubber on the base.
They really work well even on wooden shed floors (I know that is not perfect).
The ones used by the old Myford company (no idea what RDG use) are awful.
Like standing the machine on a bit of rubber.
regards David
David Littlewood31/05/2012 15:29:15
510 forum posts
KWIL,
The feet I use (and the ones in the link I posted) are made so that the steel stud rotates independently of the black foot, so it is easy to rotate the hex nut at the base - well, it's a bit stiff, but definitely do-able by normal spanner/hand power.
David
Les Jones 131/05/2012 17:58:09
802 forum posts
48 photos
Hi Richard,
I Agree with David Littlewood's first reply. Here are some more thoughts on the problem. The bed will be machined all the way along from the tailstock end to the headstock end so the surface that the headstock aligns to has got to be in line with the rest of the bed. The spindle axis of the headstock will have originally been machined in line with the surface that mates with the bed. I can not see how this alignment can have changed unless the lathe has been dropped. If this had happened I think there would be visible damage. Even if the headstock was from a different lathe The spindle axis would still be aligned with the bed. ( The spindle height or front to back alignment could be different to the original but that would not cause a taper on something mounted in the chuck. I would cause a taper turning between centres as the headstock would not line up with the tailstock.) I think these points show shimming the headstock is not the correct approach to the problem.
Les,
John McNamara01/06/2012 02:44:42
350 forum posts
20 photos
Hi Richard
I wonder if the bed is an issue?
One way for a quick test, although not completely accurate (the tail stock ways may be worn) is to attach a dial indicator to the saddle, setting it to bear on the face of the tail stock v sides and flat. then run the saddle along the bed. If the bed is in good order there should be very little change. If not the bed is worn. The tail stock ways near the head stock are not likely to be very worn. They tend to wear further away as the tail stock is not normally needed as much to support short work that is held in the chuck alone.
This test is a very good indicator of bed condition.
Another point to check carefully is the back and front saddle retaining strips particularly the back one, Speaking from experience my lathe a VDF RO80 has a very heavy geared saddle apron. if the back strip is not set correctly the saddle can lift at the back. Causing strange cutting errors.
MICHAEL WILLIAMS01/06/2012 09:40:52
896 forum posts
11 photos
Hi Richard ,
I've just read this again :
If I understand you correctly the misalignment error is in the VERTICAL sense - ie up and down . That's seriously weird and I don't understand it at all . The error is both in a very unusual direction and very big . If bed is ok I can only suggest that you look for a something on bed / headstock joint which is stopping them mating properly .
All :
It is unfortunate that in Model Engineering circles the term 'levelling' has always been used indescriminately to describe two different and almost unrelated activities :
(1) Levelling in the sense of just setting a machine bed to be reasonably level both ways . This is good practice and has practical advantages but it is not a precision process . Can be done perfectly well with a builders level .
(2) Levelling in the sense of setting a machine bed to be dead true - ie aligned with machine axis and free of any distortion . This is a precision process . Needs a super precision Engineers level to do it properly
In the home workshop with limited facilities setting up a machine with test bars and trial cutting is far more practical .
Michael Williams
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
Myford
ArcEuro Trade
Diamond Engineering
Advertise With Us
TRANSWAVE Converters
Avanquest
G and M tools
Model Engineer Digital Back Issues
Model Engineers' Workshop Digital Back Issues
