Tool angles terminology
| David Clark 1 | 28/05/2012 19:41:49 |
Moderator 2760 forum posts 100 photos 18 articles | Hi There Can anyone confirm the correct terminology for tool angles. It seems to vary in different books and possibly between the UK and USA. regards David
| The Merry Miller | 28/05/2012 20:46:48 |
394 forum posts 49 photos |
David, here is an extract from my apprentice bible "Engineering Workshop Data" published in 1956 by Caxton. Hope it helps. Len.
| Sid Herbage | 29/05/2012 01:01:45 |
| 536 forum posts 9 photos | US (North America actually) terminology is probably best illustrated by the entry in Machinery's Handbook .... there are differences from both David's and Len's definitions. For instance, "Top Rake" is called "Back Rake" and "Side Relief" is what in David's illustration is called "Side Clearance". I have the 28th Edition of MH (desk edition now to go with the eyesight). However, I also have the facsimile copy of the original (1914) edition which uses such terms as "back slope" and "side slope" |
| Don Brymer | 29/05/2012 05:25:31 |
| 9 forum posts | David, The generally accepted terminology used in Australia; side rake, side clearance & front clearance are the same as in your sketch, with top rake referred to as back rake, front relief referred to as trail angle & side relief being approach angle. The approach angle in the sketch being negative. Possitive approach angle, angled toward the right when viewed from the top of the tool. Regards, Don. |
| David Clark 1 | 29/05/2012 08:06:45 |
Moderator 2760 forum posts 100 photos 18 articles | Hi All That is the problem, not standard terminology and I need to get it right as it is for a book. regards David
| Tel | 29/05/2012 10:30:24 |
157 forum posts 28 photos |
Certainly what you show in your original post will be understood in the UK and Oz, probably even in NZ |
| Terryd | 29/05/2012 10:47:54 |
| 1935 forum posts 179 photos | Hi David, That would be correct as far as the UK is concerned and would be understood by any engineer. This is the terminology from my venerable Chapman, 'Workshop Technology' Vol 1:
Regards Terry Edited By Terryd on 29/05/2012 10:49:36 |
| David Clark 1 | 29/05/2012 10:58:39 |
Moderator 2760 forum posts 100 photos 18 articles | Thank you all, that looks like it will do, suitably redrawn. I have been grinding tools for years but never bothered about what the angles were called. regards David
| Russell Eberhardt | 29/05/2012 11:08:37 |
415 forum posts 13 photos |
Due to laziness I often use the same knife tool for turning and facing. Should I keep swapping the names of the faces? Russell. |
| David Clark 1 | 29/05/2012 11:14:21 |
Moderator 2760 forum posts 100 photos 18 articles | Hi Russell Only if you swap the tool around by 90 degrees in the tool post. regards David
| colin hawes | 29/05/2012 12:24:47 |
| 134 forum posts 6 photos | I agree with Terry and the Chapman version but would like to add "cutting edge" for clarity to beginners. Colin |
Visit The New
Model Engineer
Exhibition Website.
