| Kenneth Deighton | 06/05/2012 19:48:59 |
| 13 forum posts | I am restoring a pair of garden lamps, the alloy castings are very corroded, what treatment should I give them before I paint them? Ken. |
| CoalBurner | 06/05/2012 20:33:24 |
415 forum posts 36 photos | depends on how bad the corrosion is, but, if you want to restore a smooth finish, then I would suggest using a flexible car body filler such as P38 or U-Pol. Both are easy to sand to shape and will bond well to alloy castings. CB |
| Stub Mandrel | 07/05/2012 13:20:50 |
3073 forum posts 255 photos | Hi Ken, If they are whitemetal castings with a white powdery bloom, this could be tin oxide. Tin oxide catalyses its own spread so it's a good idea to get as much off as you can with a stiff wire brush then use zinc oxide primer before painting. Neil |
| Kenneth Deighton | 07/05/2012 13:41:17 |
| 13 forum posts | Thankyou for your thoughts , it is a "chemical " solution that I was looking for such as Jenolite, as the finnish need not be as good as body work etc as they will only be in the garden. |
| KWIL | 07/05/2012 13:56:27 |
| 1424 forum posts 41 photos | Shot blast them and paint immediately before the dreaded white powder comes back. |
| Peter Tucker | 07/05/2012 19:26:09 |
| 86 forum posts | Hi Kenneth, If the corrosion is bad I would recommend you whip up a model and re cast the fittings. Peter.
| thomas oliver 2 | 07/05/2012 20:23:00 |
| 35 forum posts | I would be interested to know how tin oxide would form on alloy castings. Alloy cleaner for car wheels can be obtained at autospare shops. I have a 6in powered wire wheel which is very efficient for such work. It is good on paint jobs as well. Tomol. |
| Stub Mandrel | 07/05/2012 21:54:16 |
3073 forum posts 255 photos | Hi Thomas, 'alloy' mean any mixture of metals, not just aluminium and magnesium alloys isued for car parts. I have some garden 'coach style' lamps and they appear to be 'white metal' - name for a wide range of low melting point alloys that are mostly tin with varying amounts of lead, copper antimony and other metals. Think Dinky/Matchbox cars (at least the old ones, I expect the new ones are lead free). As Peter suggest the melting point is usually low enough that they can be easily melted with a blowlamp. Neil |
| Deltic007 | 07/05/2012 22:09:37 |
| 73 forum posts 8 photos | I would lightly blast off and apply a good etch primer straightaway then either powder coat of wet spray and make sure you get over 300 microns of paint or powder on.
Mike |
| Deltic007 | 07/05/2012 22:09:42 |
Mike |
Visit The New
Model Engineer
Exhibition Website.
