| Con Nicoll | 26/03/2012 23:40:23 |
| 2 forum posts | I am trying to positively identify the spindle nose thread form for my Murad Antarctica lathe. It's 1 3/8'' diameter x 10 tpi. I have tried Measuring the angle with both 55° and 60° thread cutting tools but without grinding the tip of the tool off it's difficult to judge the angle accurately. I first thought it to be 55° whitworth form however this does not seem to be a standard size. Can anyone advise? |
| Bogstandard2 | 27/03/2012 10:22:16 |
| 186 forum posts | I would almost guarantee that being a UK based manufacturer, it would be 55 degrees. At the sort of sizes you are talking about, almost anything goes, they would use whatever size and thread combination that would get the job done, no thought about interchangeability with other makes at all. But to put your mind at rest, Boxford threaded items, at 55 degrees angle, fitted perfectly well on my Atlas (US built) lathe spindle at the same size and pitch, but cut at 60 degrees.
John |
| Russell Eberhardt | 27/03/2012 10:48:30 |
415 forum posts 13 photos | But to put your mind at rest, Boxford threaded items, at 55 degrees angle, fitted perfectly well on my Atlas (US built) lathe spindle at the same size and pitch, but cut at 60 degrees. Mine too but I did give the thread on the backplate a light skim to make sure the chuck is located on the register and not the thread. Russell. |
| Ady1 | 27/03/2012 10:55:31 |
| 656 forum posts 39 photos | Cut an internal thread using a lump of Delrin or Aluminium and see how well it fits Using the 55 and the 60 tools
Only takes about 5 mins with a soft material
Had a quick look at one on lathes.co.uk and it just screams "atlas lathe!" Edited By Ady1 on 27/03/2012 11:04:33 |
| Bazyle | 27/03/2012 12:53:07 |
| 604 forum posts 30 photos | How about filing a bit of aluminium sheet to 55 and holding it against the thread. Although the wrong thread may fit it will be stressing the tips of the thread and may not ragiter correctly. |
| S.D.L. | 27/03/2012 12:55:24 |
| 45 forum posts |
Posted by Con Nicoll on 26/03/2012 23:40:23:
Hi several points
Steve Larner |
| Con Nicoll | 31/03/2012 12:12:26 |
| 2 forum posts | Thanks to you all for the responses. After further careful measuring under a magnifying glass and a strong light it does seem to be a 55° thread form. I shall be machining a test thread on a piece of aluminium before I machine the face plate I have obtained for the lathe. |
Visit The New
Model Engineer
Exhibition Website.
