Forum sponsored by Arc Euro Trade
Portable Engine Model Engineer Article by Tony Webster
David Clark 107/03/2012 11:26:33
2760 forum posts
100 photos
18 articles
I have started this thread to publish any questions, errors found and corrections in Tony Webster's Portable Engine series. Some of the content from this thread may be used in Model Engineer.
regards David
PS Any unsigned posts by me will be replies from Tony Webster.
Edited By David Clark 1 on 07/03/2012 14:00:39
David Clark 107/03/2012 11:27:35
2760 forum posts
100 photos
18 articles
The boiler barrel is eight inches long, with 3/8in. cut off the firebox end for one third of the circumference.
I advised not to try squaring up the ends of the boiler barrel in the lathe because it is difficult to hold in the chuck.
Edited By David Clark 1 on 07/03/2012 11:47:51
David Clark 107/03/2012 11:27:53
2760 forum posts
100 photos
18 articles
There are five bushes in the boiler, there is one each side of the barrel at the front so there is a spare for a hand pump.
The holes for the eight corner stays for fixing the horns should be 7/32in. dia. ie. the 1/4in. dia. is reduced slightly in diameter to provide a 'head' to stop them falling through when silver soldering. Head on the outside which makes it a two operation job. Reduce to 7/32in. dia. part off, chuck the other way round to centre, drill and tap 4BA. (It also cleans the bronze surface for silver soldering.)
Edited By David Clark 1 on 07/03/2012 11:48:07
David Clark 107/03/2012 11:56:50
2760 forum posts
100 photos
18 articles
The 7/16in. tube should be 20 swg, standard thickness from your friendly model engineer's stockist. Jason B should be assured that if too thin a wall section tube is fitted, the tube is likely to collapse inwards, in other words flatten. The pressure is on the outside in this case and copper is less strong in compression. This would not cause a catastrophic collapse and would most likely happen when the boiler is tested to twice boiler pressure. This is why boilers are tested to twice boiler pressure. Subsequent tests are to one and a half times boiler pressure.
In typesetting my hand written dimensions for publication, in the end section to the right of the drawing on page 364, the 11/16in. dimension to the first row of stays should be from the top of the foundation ring as shown in the door plate drawing to the left. Also the 1/4in. should be for the foundation ring only and not include the firebox wrapper plate.
The front to back location of the water gauge bush and manifold will be detailed in a further instalment of the series. There is no harm in having a static connection to the water gauge, ie a pressure gauge where there is no movement of steam or water through the manifold. I agree that there must not be a connection to the blower or injector etc. from the water gauge. This would have a misleading effect on the water level in the water gauge.
JasonB07/03/2012 13:14:35
2984 forum posts
354 photos
Thanks David good to try and keep all these things in one place.
A few more questions regarding the boiler drawing in 4425.
1. Depth of flanges to inner firebox and throat plate
2. How far does inner firebox protrude below foundation ring
3. Drawing says 2off regulator bush, where does the second one fit
4. Should there be any thickening pad inside the boiler to mount the crankshaft bearings
5. Should there be blind bushes to mount the firedoor Hinge
6 Confirmation of an available thickness for copper in substitution for the 3/32" and 1/8" thicknesses shown on drawing.
Thanks, Jason
Edited By JasonB on 07/03/2012 13:15:54
JasonB17/03/2012 09:59:14
2984 forum posts
354 photos
Cylinder drawing issue 4426.
1. No setting out positions for the 10No valve chest stud holes or will they be detailed with the valve chest.
2. Text says machine valve face back to lines 1 & 2 but drawing shows it at least 1/32 away from them.
3.Length of cylinder and protrusion of end faces not shown on drawing but can be found in text.
4. No depth for steam port slots
5. Brass tube, I'll wait to see what teh text says before commenting.
From the comments in about the last issue I got the impression there was going to be another boiler drawing has this been missed or is it to follow out of sequence? In 4426 it would seem the boiler is "complete " and tested yet the details mentioned two posts above have not been covered??
J
JasonB30/03/2012 20:52:04
2984 forum posts
354 photos
Errors & Ommisions 4427
1. Width of Valve chest given as 3/8" but should be more like 1.5"
2. No length given for piston rod
3. Crosshead, no thickness given, probaly 5/16" to suite the slidebars but the 3/8" spigot is not shown to suit that.
David there are now three issues worth of queries, any chance of some answers?? as you did say this thread would be for corrections!!
Jason
JasonB30/03/2012 21:42:26
2984 forum posts
354 photos
more 4427
1. No depth for piston ring groove
2. No length of 1/4x40 thread on piston rod
3. No depth for cut out in cross head, looks about 1/2"
David Clark 130/03/2012 22:33:56
2760 forum posts
100 photos
18 articles
Hi There
Tony Webster has been away.
I will chase him up Monday but I don't know when he is back.
regards David
Adam Gregory 102/04/2012 08:03:26
20 forum posts
11 photos
Hi all
Any chance of a few more pictures of finished components or close ups of the finished model, to make it easier to understand some of the text and diagrams.
David Clark 102/04/2012 09:01:13
2760 forum posts
100 photos
18 articles
Hi There
I have a few photos to publish but most are pretty poor quality.
regards David
JasonB02/04/2012 09:16:07
2984 forum posts
354 photos
David if they are a bit too poor for actual printing what about just adding to this thread so those that need the reference have access to them.
Another thing that would help would be to try and syncronise the drawings with the text for example the description of the cylinder covers in the latest issue is very hard to follow but I'm sure once the drawings appear hopefully in the following issue the text will make a lot more sense.
J
David Clark 102/04/2012 09:46:43
2760 forum posts
100 photos
18 articles
Hi There
We don't have rights to put unpublished photos on the websites.
Rear cylinder cover drawing is in 4428, front cover in 4429.
regards David
JasonB02/04/2012 10:08:16
2984 forum posts
354 photos
Why can't it be done like the Darjeeling ref photos, none of them have been published, You would only need to Ask Tony if it was OK.
Failing that if I see it at another exhibition I could take a load of photos and stick them in an album
J
David Clark 102/04/2012 10:36:29
2760 forum posts
100 photos
18 articles
Hi Jason
I took the Darjeeling photos.
They are my copyright. That is why they are on here.
regards David
JasonB02/04/2012 13:03:10
2984 forum posts
354 photos
Fair enough.
This wil take anyone interested to the only pic I have of the engine, there is another one on the net that I will dig out the link for when I have a bit more time
Edited By JasonB on 02/04/2012 13:04:00
David Clark 102/04/2012 13:29:48
2760 forum posts
100 photos
18 articles
Hi There
I do have some photos that I took at exhibitions.
I will dig them out.
regards David
Nicholas Farr02/04/2012 20:39:16
814 forum posts
219 photos
Hi, I have put a photo that I took of Tony's engine when on display at Sandown, in my album named Portatable Engine, if anyone is interested in viewing it.
It is similar to JasonB's link, but at a slightly different angle.
Regards Nick
Edited By Nicholas Farr on 02/04/2012 20:55:43
Mike Wainwright07/04/2012 07:26:29
101 forum posts
Is there a full set of drawinging available to go with this series that will have all corrections included.
JasonB07/04/2012 07:44:33
2984 forum posts
354 photos
Posted by Mike Wainwright on 07/04/2012 07:26:29:
laughlaughlaugh
Sorry could not resist.
It would be nice if a lot of the newer models being published in the mag could be added to the MHS range of plans but somehow I don't see it happening, though most people contemplating a build in the future would likely track down the back issues anyway which would have the drawings in so why pay twice unless they had all revisions.
J
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
ArcEuro Trade
Diamond Engineering
RDG Tools
Advertise With Us
G and M tools
Avanquest
TRANSWAVE Converters
Drives Direct Ltd
