Forum sponsored by allandale
Screw cutting gears
Andy Freeman 115/10/2011 13:09:14
40 forum posts
26 photos
I Have a Myford Super 7 with a gearbox. As I have never tried screw cutting before I could do with a little help.
I want to cut some metric threads so bought a set of 33 and 34 tooth gears. The notes said you just have to replace the 24 tooth i/p gear on the tumbler reverse with one of these gears - depending on what pitch you want.
My question is, on the tumbler reverse, there are two gears. Am I correct in thinking that I just replace the gear that is engaged when its running forward.
or is it the gear that these two tumbler gears mesh with I should be replacing?
Thanks for your help
NJH15/10/2011 14:58:26
2298 forum posts
139 photos
Hi Andy
I too have bought 33 & 34 tooth gears but have not yet used them .
I understood that they replace the gear shown - but maybe some knowledgeable gent will confirm this.
( Looks as if I should do a bit of cleaning up!)
Norman
colin hawes15/10/2011 16:47:08
450 forum posts
18 photos
I don't have a Myford lathe but I would like to advise that on most imperial lathes you need to keep the leadscrew engaged and reverse the motor to return to your thread start when cutting metric threads as it won't pick up the thread again if you try to use the thread indicator.
Nicholas Farr15/10/2011 20:13:00
1624 forum posts
831 photos
Hi Andy, I believe Norman's yellow arrow is pointing to the correct gear to replace, the other three you can see are never normally removed on most lathes with this type of arrangement.
Regards Nick.
ady15/10/2011 22:47:37
612 forum posts
50 photos
I think it might be better if you actually understand whats going on before you replace anything.
Part of the skills set, so you know exactly what you're doing.
Nobby15/10/2011 23:28:21
587 forum posts
113 photos
Hi
That is the correct gear to change.
On the Myford chart for metric pitches The 21 gear tooth gear is a good one to get.
For 1, 1.25 , 1..5 & 2 mm combined with standard gears.
ie for lets say 1.5 driver 21 1st stud 50-45 2nd stud idle35 wheel leadscrew 40 set up 2
Take Colins advice and leave half nut closed etc thereby not getting split threads
Regards Nobby
John Stevenson15/10/2011 23:30:06
5068 forum posts
Yes it is the one Norman posted.
You need to select either 33 or 34 depending on the pitch, the chart gives which one and what lever in the gearbox to select.
Also as Colin says you need to keep the halfnuts engaged and wind back, either by hand or under power.
Ignore the screwcutting dial when doing metric.
John S.
Nobby17/10/2011 17:50:46
587 forum posts
113 photos
Whoops talking Myford S7 with a gearbox
Nobby
Andy Freeman 130/10/2011 20:47:43
40 forum posts
26 photos
Just a quick posting to say thanks to everyone that helped me out here.
I fitted the 'new' 33T gear and set the gearbox to 28 TPI (I think) as per the instuctions.
Trying to cut a thread resulted in just a parallel turned bar! The feed seemed way to slow.
Having just aquired this Super 7 with gearbox I assumed that everything was 'in its correct place' - if there can be such a place.
This was the mistake as I found that the 2nd stud gear had been reversed on its shaft. I turned this around and got a lot faster feed rate on the lead screw.
Trying not to forget the sequence of events, set to zero on the cross slide, advance the top slide, stop the motor, reverse the direction etc. etc., I ended up with my first M8 x 1.25mm thread. It was only about 10mm long but I was pleased - and so was my Dad and its his lathe!
John Stevenson30/10/2011 21:16:28
5068 forum posts
Second stud gear as you call it is made to easily reverse, one way is fine feed [ as you found out <g> ] and the other way is screw cutting.
John S.
NJH30/10/2011 21:22:38
2298 forum posts
139 photos
Hi Andy
Yes this gear is reversible - one way round for fine feeds the other way for screw threads. You will see from the chart on top of the gearbox there is a box corresponding to the positions of the two gearbox " levers" There are two numbers in the box - one refers to the TPI with the composite gear on stud 'A' in one position, the other to the feed rate( fine feed) with the composite gear reversed.
eg . Top L on chart either 8 TPI or 0.0139 in per revolution feed depending on the gear position on stud 'A'.
I suggest that you get hold of the Myford Quick change Gearbox manual if you can also a copy of the Myford series 7 Manual by Ian Bradley would be of use.
Norman
Edited By NJH on 30/10/2011 21:23:21
Chris Martin 202/10/2014 16:40:04
3 forum posts
Posted by John Stevenson on 15/10/2011 23:30:06:
John S.
I know it's an old post but can anyone tell me where I can buy these gears and also get a copy of the chart please
Chris M
Roderick Jenkins06/10/2014 23:38:45
1533 forum posts
371 photos
Chris,
I put a chart together using Excel.
I got my 33 and 34 gears from John Stevenson. It might be worth sending him a personal message.  I see that Myford have them in stock as well.
HTH
Rod
Edited By Roderick Jenkins on 06/10/2014 23:46:48
Chris Martin 207/10/2014 07:40:12
3 forum posts
Thanks, that's a useful chart.
Don't think Myford have the 34T in stock at the moment.
Chris M
Roderick Jenkins07/10/2014 17:53:14
1533 forum posts
371 photos
You're welcome. I'm not sure why anybody would want to cut (rather than use a die) for the small pitch threads, especially the BA ones, but the option is there if they do.
Rod
Chris Martin 208/10/2014 11:33:40
3 forum posts
Rod,
Myford contacted me yesterday to say gears are now in stock, delivered today! So I'm sorted thanks.
I agree with your comment regarding the finer threads.
Chris
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
SPG Tools October Seventeen
Shapiro
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
