Forum sponsored by Arc Euro Trade
No. of divisions
Nobby11/09/2011 00:21:35
350 forum posts
91 photos
Hi.
How is the dial divided up please. I want to add one to my s7 Mk1 Mine looks about 7/8" per rev.
Regards Nobby
John Stevenson11/09/2011 00:41:58
1717 forum posts
Nobby,
Can't answer 100% correctly on how many divisions but I do know it has internal gearing so the dial move a set length per turn and not once per turn.
Robin has more info than I have.
John S.
ady11/09/2011 02:05:54
615 forum posts
50 photos
Is that a wee brush on the handle side of the dial to keep the gremlins out?
I just put a digital vernier on my cross slide.
Doesn't look as nice but backlash is eliminated and cuts are good for 1-200ths of a mm
Edited By ady on 11/09/2011 02:08:13
JasonB11/09/2011 13:21:41
2984 forum posts
354 photos
I think its a straight knurl not a brush seal
J
Nobby13/09/2011 22:37:44
350 forum posts
91 photos
Hi Ady
Thank you for reply .I know I can use the the handwheel on the leadscrew 125 divisions but you have to turn the gears as well . I suppose I could go digital? some how
Regards Nobby
Anthony Rhodes18/09/2011 05:08:40
80 forum posts
27 photos
Posted by Nobby on 11/09/2011 00:21:35:
Hi.
Regards Nobby
Nobby,
It would probably be useful if you were to mention the article published in the latest issue of Home Shop MAchinist, September-October 2011, p. 26 - 35. There was also an earlier version of the article published in Engineering in Miniature but I don't know the daye or issue number for that release.
This is an article by Graham Meek. It tells how to build a micrometer dial for the carriage handwheel. The example discussed specifically was for a Myford Auper7 but he points out that the principles can be applied to any lathe.
The special feature of this design is that, since the carriage traverses an inconvenient distance for each revolution of the hand wheel. ther is an internal gear system which makes the micrometer dial rotate at a differen rate than does the handwheel so tha it reads actual distance traversed instead of a decimal value of the rotation of the hand wheel.
Per Gray's article the carriage travel per revolution of the hand wheel is .866". It would be inconvenient to have a micrometer dial marked out in 86.6 divisions to indicate 0.01" units. The internal gearing makes the dial rotate more slowly than the hand wheel so that when the handwheel has rotated one full revolution the dial will have rotated .866 revolutions by which means it reads the actual distance traversed rather than parts of a revolution of the hand wheel.
The picture at the start of this thread is straight out of the article and is marked with 100 divisions with each 5th mark a bit longer than the singles and each 10th mark noted with numbers for tenths of an inch. Gray gives the gearing to accomplish the reduced rotation of the dial for correct decimal inches and also provides the same information to read out in millimeters with divisions down to 1/4 mm.
In the article Gray states that the the gearing has an error of 0.43% (actually 4.35/1000 on a dial marked in hundreths). It would be possible to get that down to 0.17% error but it would require very special gears which can only be cut by hobbing. (J.S. original gearing 26/28 x 26/28, better 26/28 x 27/29. 27 on 26 pitch circle, 29 on 28 pitch circle.) This would actually fit because the gears would be the same size as the ones Gray specifies, I can generat numbers which can get he error down to .077% but I don't know if the gears could be fitted within the mechanism as designed.
So, to recap, 100 divisions indicating .01" or 100 divisons indicating .25 mm used with alternative gearing.
Anthony
Edited By Anthony Rhodes on 18/09/2011 05:10:36
Anthony Rhodes18/09/2011 07:20:12
80 forum posts
27 photos
Did some more thinking about this. It turns out that almost ideal gearing is 26/30 x 28/28 (the extra 28/28 is necessary to return the same axis as the original drive). Results in an error of .077%. The question is whether the 30 will fit?
I believe the original gear train for the metric dial was 29/31 x 29/31 which had an error of 0.54%. Alternative gearing 33/29 x 31/31 results in an error of 0.012%. Same question, will the 33 fit?
Anthony
John Stevenson18/09/2011 09:18:09
1717 forum posts
What DP are the gears ?
You can just get a 30T on a 28 blank, not a pretty tooth form but still an involute and workable.
This has been draw in in 20 DP just for reference, on the right is a big standard 28T gear, on the left is a corrected gear with 30 teeth on the same blank.
Click on picture to enlarge.
John S.
Edited By John Stevenson on 18/09/2011 09:18:57
Nobby18/09/2011 16:16:00
350 forum posts
91 photos
Hi Tony & John
Thank you for info on this . I wont be able to change gearing on the apron . I will give it some more thought. Meanwhile i will try and upgrade the adjustable carriage stop to indicate .001" I have a platform under the stop with fixed rule & for loading home made gauges to save using my best slips. Posted in one of my albums.
What's .866 " in metric ? that's a thought
Regards Nobby
Anthony Rhodes18/09/2011 16:22:54
80 forum posts
27 photos
Posted by John Stevenson on 18/09/2011 09:18:09:
John S.
John,
That was my first thought but it probably isn't necessary.
The inch version of the micrometer dial uses 36 DP gears. The first and last gears in the train are coaxial with the hand wheel shaft. Original train is 26/28 x 26/28. New train would be 28/28 x 26/30. Increases the radius occupied by the train by one tooth depth (0.027777777"). I expect it would fit within thedesign as is but I haven't actually checked.
Same story with the metric version which uses 40 DP gears. Original train is 29/31 x 29/31. New train would be 31/31 x 29/33. Again increases the radius occupied by one tooth depth (0.025").
There is some benefit for amateur construction to not have to deal with special form gears.
Anthony
Anthony Rhodes18/09/2011 16:28:52
80 forum posts
27 photos
Posted by Nobby on 18/09/2011 16:16:00:
Hi Tony & John
Regards Nobby
Nobby,
.866" x 25.4 = 21.9964 mm but the rotation you want to deal with is related to 25 mm, not 1". The new factor is 0.879856 of 25 mm.
Anthony
John Stevenson18/09/2011 17:14:08
1717 forum posts
Nobby,
You don't have to change gears in the apron, the gears in question are inside the handwheel.
John S.
John Stevenson18/09/2011 17:32:35
1717 forum posts
You can get 0.866 with a 13/15 setup, or multiples of.
John S.
Anthony Rhodes18/09/2011 23:38:20
80 forum posts
27 photos
As John says, the gears are inside the handwheel. The mechanism is a variation on the concept used to provide both inch and metric micrometer dials on the cross feed screw. Not common on inexpensive lathes but not at all unusual on machines such as Hardinge, Nonarch, Clausing, Nardini (I believe), etc.
John, your correct of course about the 13/15, just half the tooth counts of the 26/30, but many people aren't happy with very low tooth counts and two of the gears are coaxial to the hand wheel shaft. On the other hand, it occurs to me, the drive could be from A to 15 followed by 13 to B where A and B are the same tooth count and the 13 and 15 are both cut to a 14 pitch circle, or A, 13, and 15 are all cut to standard pitch circles and B is cut to a -2 pitch circle.
Aside from needing the coaxial gears to be large enough to fit over the center shaft, there's no preference for large or small DP. Looking at the drawings in the article it appears to me as if two 20 tooth 24 DP gears axial to the hand wheel shaft and and a cluster of 24 DP 15 and 13 tooth gears both cut to a pitch circle of 0.700" would be an ideal solution. This gives 28/15 x 13/28 = 0.86666666666666 = perfect result.
Your thoughts?
Anthony
John Stevenson18/09/2011 23:57:52
1717 forum posts
Anthony PM sent
Nobby19/09/2011 17:32:53
350 forum posts
91 photos
Hi John
Cheers mate .
Regard Nobby
Robin Woodward20/09/2011 20:12:50
142 forum posts
Hi Nobby,
I must apologise for not responding sooner, but until this afternoon I thought this thread was related to a Dividing Head query and did not bother to open it.
However Gray told me about this thread and that my name was mentioned by JS, yes I could have given you more information but John and Anthony have described the Dial very well and improved upon it, which is something I know Gray likes to see. He considers his designs as his way of solving a problem, it is not the only way and neither does he consider it the best way, he is always happy to see someone take his design as a basis and improve upon it.
He has said that if you require the pdf's of the drawings he will send them to you, just let me have your email address via PM and I will pass it on.
Rob
Nobby21/09/2011 23:39:38
350 forum posts
91 photos
Hi Rob
I misunderstood the from the start .I just wanted to put a dial direct on the standard handwheel on my S7 Mk. 1
I have another problem now with Srewcutting 10 TPI on my 1912 Drummond .
I will post thread & see if you our anybody can help Its driving me mad ????
Regards Nobby
ady21/09/2011 23:46:45
615 forum posts
50 photos
10tpi
8tpi leadscrew? 8 x 1.25 = 10tpi
so.
20/25
or
40 headstock 50 leadscrew?
Anthony Rhodes22/09/2011 02:12:29
80 forum posts
27 photos
Posted by ady on 21/09/2011 23:46:45:
10tpi
so.
20/25
or
ady,
I started to respond to this but suddenly realized I'd confused theissue and you had it correct in the first place.
20/25 x .125" = .10" = 10 TPI. Any 4/5 ratio will do.
Edited By Anthony Rhodes on 22/09/2011 02:13:30
Edited By Anthony Rhodes on 22/09/2011 03:23:50
Login/Create Account
Email address
Password
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Subscription Offers
ME & MEW Digital Archive Subscription
Social Networking
Model Engineer Exhibition
Visit The New
Model Engineer
Exhibition Website
ArcEuro Trade
RDG Tools
Diamond Engineering
Drives Direct Ltd
G and M tools
Avanquest
Advertise With Us
TRANSWAVE Converters
