Bending steel tube
Search for:  in  in
Mike Hibbins 107/02/2010 21:58:49
2 forum posts
I need to bend some 16mm X 1mm wall steel tube to make an
exhaust for a model aircraft.
I've looked at commercial benders but can't find anything 16mm.
Has anyone got any ideas??
Edited By David Clark 1 on 22/02/2010 15:00:18
Alan Worland07/02/2010 22:38:52
68 forum posts
Hi Mike,
I have bent smaller steel tube by filling it with copper wires
from cable - it seemed to work quite well.
Used also to be done in the old days by filling with sand
Alan
Edited By David Clark 1 on 22/02/2010 15:00:38
mgj08/02/2010 01:17:44
629 forum posts
10 photos
I have one idea- use ali instead. Used to do a lot of tuned
pipe headers in ali - softer than steel, and with these
ali-weld kits, pretty easy to join. If you are going to use ali,
make sure its not heat treated to 1/2 hard. If you want to
 use steel, anneal. (Why steel - isn't weight a problem?)
However the basic procedure is tolerably simple.
Make a "blank" in soft wire first as a gauge.
Plug one end with solder or epoxy. Fill with sand.
Plug the other end and bend over formers.
Ideally the former wants to have a groove at least 50% of the
pipe dia in it to stop wall collapse.
Unwise, I'm told to use copper by the way.
Something in my mind says copper and ali pistons don't
go too well, but maybe that is only in petrol engines.
Edited By David Clark 1 on 22/02/2010 15:05:46
Gordon W08/02/2010 11:09:28
128 forum posts
I use lead as a filler if at all pos., sand is messy, and if heat
is needed must be very dry.
Cheap plumbers benders with ally formers are made for std.
15mm o/d pipe and are easy to file out  to 16mm if required.
For one offs formers from wood are OK.
Copper exausts make a nice noise, and should be easy to
keep away from the piston.
Edited By David Clark 1 on 22/02/2010 15:06:31
Peter Gain08/02/2010 12:30:19
72 forum posts
Try using "Wood's metal". It has a very low temp melting
point of 100c.
Use as for lead, plug one end, fill with Wood's & bend.
Easy to melt out.
Available from Alec Tiranti.
I have not checked to see how competitive they are price wise.
Edited By David Clark 1 on 22/02/2010 15:06:56
mgj08/02/2010 14:05:41
629 forum posts
10 photos
Copper - yes it does make a nice noise, but its not the copper
in contact with the ali - its the products of combustion, copper
and ali. Get a lot of pitting on the top of the piston crown etc,
as I recall, but quite willing to be corrected..
May not apply to engines running on methanol.
I agree - sand is messy, but a 16mm tube full of solid lead or
woods metal is going to take a bit of force bending?
All you have to do is drill a small hole in each plug to let the
steam out (if any). Best to dry your sand in the oven in a tray - or
one of those big sweet tins. ( Or a few holes in the end bits you
are going to saw off.) At least with sand you can just pour it in,
without worrying about molten lead, so one might define messy
as relative?
16mm, if you anneal or normalise it'll bend cold with the right
former. Might be worth choosing the right grade of steel at that.
Cold Drawn Seamless is not going to help anything!
Edited By David Clark 1 on 22/02/2010 15:09:16
D.C.Clark08/02/2010 14:51:52
16 forum posts
8 photos
Fill the pipe with water.  Freeze it, bend it, thaw it.
Lower melting temperature than lead or Cerro alloys, safer
 and easier to work with, much cheaper.
This time of year, in most of the Northern Hemisphere, you
don't even need a freezer.
David Clark in Southern Maryland, USA
Edited By David Clark 1 on 22/02/2010 15:08:56
JasonB08/02/2010 14:55:48
521 forum posts
You can get 16mm conduit benders,
may even be able to hire one for a day.
Jason
Edited By David Clark 1 on 22/02/2010 15:14:14
Tony Martyr08/02/2010 16:42:05
63 forum posts
16 photos
I spent a happy year of my apprenticeship bending steel
and nickel-copper-iron tube into complex shapes and fitting
them to Admiralty turbines. For steel tubes we always used
fine dry sand thus - wooden plug in the tube and pour in
sand, tapped the tube over its full length, pour in more sand
and repeat until the level drops no more then drive in top
wooden plug - heat the tube in the area of the bend and pull
into shape when bright red. Now the fun bit; cut off the 'spare
end' complete with plug and pour sand into dry container then
heat the other end just before the pug until red hot then turn off
oxygen and blow acetylene up the tube until it explodes and
blows the plug out as a smoking projectile far down the
pipe-shop - highly satisfying!
I feel obliged to say = 'Don't try this at home'
For exotic (seawater resistant) and thin walled pipes we always
used lead which was much hotter work and far less fun.
Tony
Edited By David Clark 1 on 22/02/2010 15:10:12
Stick08/02/2010 17:47:05
47 forum posts
You could maybe get a suitable sized bending spring to fit
the tube, and give that a try, used with a simple wood former
it may do the job.
Edited By David Clark 1 on 22/02/2010 15:10:47
Ian S C09/02/2010 09:46:18
710 forum posts
7 photos
Mike,what radius is the bend?
Mike Hibbins 109/02/2010 10:34:52
2 forum posts
Thanks for all the advice.
To answer one or two questions:-
The weight of steel over aluminium is not a problem, with a
70cc twin turning a 23in prop a few grams won't make any
difference.
I'm not totally sure of the radius yet, I haven't finished the
design of the silencer. I guess somewhere around 80mm.
I'm going to start experimenting with some of the techniques
suggested, I'll let you know how I get on.
Edited By David Clark 1 on 22/02/2010 15:11:12
Circlip09/02/2010 11:56:12
482 forum posts
At that radius, you can almst bend it over your knee.
Seriously, by using a grooved wooden former and a grooved
wiper roller you could probably bend it in a vise.
 Used a "Cheap" conduit bender to form a Stainless airline
system without kinks.
  Regards  Ian.
Edited By David Clark 1 on 22/02/2010 15:11:39
Ian S C09/02/2010 23:54:58
710 forum posts
7 photos
I used 16mm steel tube(its proberbly 1.5MM), when I built
a trailer for my bike,it had the the bends built in.I use an
old tubular folding chair,saved a lot of work,and looks good.
Ian S C
Edited By David Clark 1 on 22/02/2010 15:12:06
The Craftsman13/02/2010 19:58:03
6 forum posts
Use a plumbers bender with a 22mm former.
Cut 6in. pieces of 22mm copper tube in half - 'lengthwise',
(enough to pack out the former and slide) .
Anneal the steel tube. in way of bend,  insert 15mm. bending
spring and away you go.
Edited By David Clark 1 on 22/02/2010 15:39:23
Login/Create Account
Email address
Password
 Remember me
 Forgotten Login?
Not got an account?
Why join?
Latest Posts
Model Engineer Offers
Subscribe to
Model Engineer or Model Engineers' Workshop and receive a FREE gift
ME & MEW Digital Archive Subscription
Competitions
MyHobbyStore.co.uk Competitions
TRANSWAVE Converters
Drives Direct Ltd
MyHobbyStore
M-machine
MyHobbyStore
MyHobbyStore
Only £29.95
Buy Now
Only £16.99
Buy Now
Only £44.95
Buy Now
RRP £489.99
Now Only £449.99
Buy Now
Only £14.95
Buy Now
RRP £294.99
Now Only £279.99
Buy Now
