Forum sponsored by allandale
Emcomat 7 button switches 220V
looking for new control switches for my Emcomat7 lathe
björn köling16/05/2018 10:07:55
1 forum posts
I just switched my Emcomat 7 lathe from a 3-phase 380V motor to a 220V 1-phase. My problem is that the control buttons have different wiring on 220V/380V models. Does anyone have a set of buttons for a 220V for sale or know a way of wiring up the 220V motor myself?
Kindly
Björn Köling, Sweden
JasonB16/05/2018 12:22:58
12543 forum posts
1114 photos
Did you use a 2 speed motor?
Although it is mostly aimed at the VP series lathes the Emco Yahoo Usergroup does have quite a bit of info on the Emcomat 7&8 machines, worth looking through the files there as there may be some wiring information.
Emgee16/05/2018 14:02:08
775 forum posts
155 photos
Hi Bjorn
If the buttons are acting as ON and OFF control for a contactor type starter then you will need to check the coil voltage, it may be 380v in which case you will need to replace with a 220v type.
You will also have to modify the control wiring to include a Neutral conductor to replace the coil return to the original phase connection.
The incoming 220v supply to the starter will be connected in a different form to the 3 phase 380v supply so it is best to obtain a schematic (circuit diagram) for the type of starter fitted.
Further to the above the overload (if fitted) will most likely need changing to a higher rating to suit the new motor FLC.
With the cost of a coil and overload unit it may be wise to consider a new starter to suit.
If you post some pictures of all the parts concerned it may be possible to help with positive information rather than guessing.
Emgee
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Ausee.com.au
Expo Tools July 14
Shapiro
SPG Tools October Seventeen
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
