Forum sponsored by allandale
Ten Useful Things
XD 35117/01/2018 12:35:53
823 forum posts
37 photos
Danny those wire strippers,look like something out of a horror movie ! I'm sure i have seen something similar at my doctors surgery but i was too afraid to ask what he did with it !
Ian.
Bazyle17/01/2018 14:04:49
3877 forum posts
166 photos
I thought the weller tips were iron and plated with Nickel. The wet sponge for cleaning the hot tip is oddly non-intuitive. I think rubber mats for soldering iron might give you static damage.
I made the MAP plans 'Sardine' submarine 4ft long from biscuit tins with only a 15w iron and tinman's solder stick. That plan should never have been sold - it was a disgrace.
We didn't have pcb holders at my multimillion pound defence contractor labs so to hold the pcb for my first computer in '77 I milled two slots in a piece of scrap square ali tube in line with the thicker bit on the inside. Turned out to be expensive WG17 double ridged waveguide extrusion. Still got it somewhere.
Martin Kyte17/01/2018 14:42:09
1264 forum posts
9 photos
Weller now use Bronze swarf for tip cleaning.
Martin
daveb17/01/2018 16:29:32
557 forum posts
10 photos
Posted by Neil Wyatt on 15/01/2018 22:40:03:
Posted by Richard Marks on 15/01/2018 22:21:59:
Add a retractable scalpel to your list, good for cutting, picking, scraping and other things.
Edited By Richard Marks on 15/01/2018 22:22:27
Yes, but then it would be eleven, I marginally use a needle more than a scalpel. Strictly it's a dissecting needle too
Sounds like a Borrowdale needle, used in surgery, dissection, microscopy and various prodding, cutting and poking jobs.
Neil Wyatt17/01/2018 18:42:27
13216 forum posts
571 photos
68 articles
Posted by daveb on 17/01/2018 16:29:32:
Never heard one called that before, I've found one reference to the name on Google.
daveb17/01/2018 22:20:54
557 forum posts
10 photos
Posted by Neil Wyatt on 17/01/2018 18:42:27:
I used to sell a lot of these 50 odd years ago, seem to be referred to as Dissecting needles nowadays. Daveb
StephenS17/01/2018 22:44:10
28 forum posts
What model of rework station do you have please?
I have a good Weller magnastat station and a good quality solder sucker, and some solder wick. I have not ventured into smd components yet but will have to soon.
Please can you explain the advantages of a rework station, what specifically is it, does it do, etc for me the uninitiated.
Thanks, Stephen S.
StephenS17/01/2018 22:48:57
28 forum posts
Posted by Geoff Theasby on 16/01/2018 02:13:11:
I've never needed a temp controlled iron, used an Antex X25 for decades. Rework gun? No. Soda-Wick is much cheaper.
Geoff,
Do you do smd component work with this set-up? And if so, do you find it works OK? Do you use a solder sucker at all or just solder wick?
Thanks, Stephen S.
Geoff Theasby18/01/2018 04:41:37
530 forum posts
14 photos
Hi Stephen,
Yes, I use solder wick with SM components. It works fine, Ronseal should sell it. Solder suckers often have too big a nozzle, curable by fitting a Hellermann sleeve over it to improve the suction by making a better seal with the work.
Geoff
Neil Wyatt18/01/2018 10:19:54
13216 forum posts
571 photos
68 articles
Posted by daveb on 17/01/2018 22:20:54:
That's what we called them when I was in school/uni at the beginning of the 80s
Neil Wyatt18/01/2018 10:26:47
13216 forum posts
571 photos
68 articles
Posted by StephenS on 17/01/2018 22:44:10:
Thanks, Stephen S.
Antex. It combines a temperature controlled iron with a temperature controlled precision hot-air gun you can use to solder or lift SMT components. I've found the rework gun works well for removing connectors as well.
Danny M2Z18/01/2018 10:53:05
627 forum posts
248 photos
The Weller type soldering guns were banned from my workplace due to the ESD (electrostatic discharge) capability to damage sensitive CMOS devices,as also was solder wicking braid (it could damage pcb tracks).
Given all that, they are quite adequate for home handyman use if used with care.
Also, we used a carbide tipped shear nipper to cut component leads to minimise the shock travelling up the device leads. I can dig up a photo if anybody is interested as all tools used during my course were given to the students and so have been carefully preserved.
One other useful trick that I learned is to cut the component leads to length after insertion into the board and tin the cut end before making the main joint. The above mentioned carbide cutter was handy for this as it left a consistent length of lead (about 1.2mm) projecting above the track.
* Danny M *
Geoff Theasby18/01/2018 17:27:03
530 forum posts
14 photos
pcb jig.jpgCatching up. First - strippers, whether or not Titian haired or named Tiffany.
Secondly - pcb jig as above
Tertiarily, or thirdly - heat resistant, resiliepcb jig wadding.jpgnt, pad to hold in the components when pcb is inverted. Plastikard backing, polyester foam wadding (Thanks Debs) flexible, heatproof boiler insulation. Elastic bands hold it together, and across the corners to hold it to pcb, and Robert's your aged relative! The wadding doesn't burn or support combustion, and you can make several to fit various pcbs.
Geoff
Geoff Theasby18/01/2018 17:29:28
530 forum posts
14 photos
zz strippers.jpgThese disappeared from posting above.
Geoff
Neil Wyatt18/01/2018 19:07:41
13216 forum posts
571 photos
68 articles
These work really well for small wires up to wiring a plug:
£11 on Amazon or £6 at Machine Mart.
Michael-w18/01/2018 19:13:42
2012 forum posts
49 photos
Very helpful thread, thanks Neil.
Michael W
StephenS18/01/2018 22:15:57
28 forum posts
Posted by Danny M2Z on 18/01/2018 10:53:05:
Danny,
I presume you are referring to the soldering guns where the wire tip is part of a transformer secondary, or are you meaning the Weller magnastat irons that use the Curie point principle for temperature control ?
Does anyone know if the Weller magnastat irons that use the Curie point principle for temperature control do realistically have any problems due to the switching of the element, which of course does not bother about zero-crossing as it is just a magnetically operated switch ? Do these have any ESD problems in real-life use ?
Thanks, StephenS.
Bandersnatch19/01/2018 01:21:41
991 forum posts
38 photos
Posted by Neil Wyatt on 18/01/2018 19:07:41:
Don't get the heel of your hand around the back end of those if you're using the nippers. Ask me how I know.
Personally I prefer the plain nippers of similar design
Danny M2Z19/01/2018 03:25:45
627 forum posts
248 photos
Posted by StephenS on 18/01/2018 22:15:57:
Danny,
Stephen, I am not sure what type of switching was used for the Weller soldering guns that we were prohibited from using, it was quite a few years ago. All I remember is that they had a pistol grip ,and offered 'instant heat'. I also do not remember any type of thermostatic control except the operator's trigger finger.
They were quite handy for soldering up fuel tanks for my models though!
My Aussie Royel soldering station came with grounding sockets so that a ground clip may be attached to sensitive devices and I can see no reason that any tool cannot be connected to ground with a flying lead from there to the ground track of the pcb being worked on.
Oh yeah, for Neil's list add 'Thermal Shunts'
* Danny M *
Michael Gilligan19/01/2018 09:26:51
10965 forum posts
474 photos
Posted by Danny M2Z on 19/01/2018 03:25:45:
Danny,
For info ... here is the other Weller [and an interesting little modification].
http://spritesmods.com/?art=wtcpled
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Ausee.com.au
Expo Tools July 14
Shapiro
SPG Tools October Seventeen
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
