Forum sponsored by allandale
Stanley Knife Blades
Steve Crow19/05/2017 17:57:42
34 forum posts
5 photos
On occasion, I've used old Stanley knife blades to make filing guides and gauges. After annealing on the gas cooker, they can be filed and drilled with ease.
I've enclosed some pictures of 2 pieces temp riveted either side of 6 x 2mm brass flat for filing.stanley01.jpg
My question is, does anyone know if they are a simple high-carbon steel or something more exotic? Can I harden and temper them?
Also, does any one know of any other frugal sources for flat high carbon steel? Preferably something a bit bigger and thicker than Stanley?
Cheers
Steve
Bazyle19/05/2017 18:08:51
3689 forum posts
164 photos
That's a good idea.
How about 'disposable' hand saws as now standard on building sites.
Neil Wyatt19/05/2017 18:35:44
12592 forum posts
557 photos
66 articles
If you can anneal them like that, you should also be able to harden them.
I like the Wickes bi-metal ones, cheap and they keep an edge longer, even on carpet.
Bob Stevenson19/05/2017 19:02:51
215 forum posts
3 photos
The trouble with a lot of this stuff is that it's now made from laminated steel and intended for throw-away when blunt. This has now extended to the cheap panel saws available from Wickes and similar....they cut really well but cannot be properly re-sharpened more than just alight 'touch-up' before the softer steel core is reached.
It is possible to buy 'ground flat stock', or 'guage plate' in quite thin section and I have some that is only about 1mm thick. Another good source of carbon steel is in old circular saw blades (without brazed in teeth/cutters) These can be cut using a small angle grinder with suitable disc, or a dremel and disc, and the pieces then annealed if neccessary. Remeber that the pieces WILL be softened at the cuts if the metal changes colour..this can avoided by frequent dipping in cold water during cutting.
stevetee19/05/2017 19:20:27
122 forum posts
13 photos
Leaf spring off an old car , next to nothing at a scrap yard.
Edited By stevetee on 19/05/2017 19:20:45
clogs19/05/2017 20:58:30
344 forum posts
12 photos
Steve tee,
the only thing I get cheap from the scrap yard is oily muddy boot's.......hahaha....clogs
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Ausee.com.au
Expo Tools July 14
TRANSWAVE Converters
Shapiro
SPG Tools October Seventeen
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
