Forum sponsored by allandale
boxford refurb
kevin beevers14/12/2016 11:43:33
69 forum posts
43 photos
Well nearly got the turd finnished just waiting for son inlaw to come wire it up sorry i have lost some of the photos but some are in my album i cant get them to come on here
Kevin
Bazyle14/12/2016 13:24:55
3637 forum posts
158 photos
Ah, Adept blue. Neil will approve face 23
kevin beevers19/12/2016 10:13:55
69 forum posts
43 photos
help is needed,now the boxy is up and running do i keep it and sell my other boxy or do i be greedy and keep them both how many of you folks have two lathes ?
kevin
David Standing 119/12/2016 11:14:19
802 forum posts
39 photos
Posted by kevin beevers on 19/12/2016 10:13:55:
kevin
Guilty as charged, m'lud - two lathes.........and two milling machines blush.
Ajohnw19/12/2016 11:22:36
3631 forum posts
160 photos
I try to have 2. One Boxford and one much smaller. The smaller one is often problematic.
Refurb ?? I sometimes think they should be called a repaint. Mine has a number of chips in the paint but turns well. Suppose if the turning aspect is also fixed up it becomes a recon'. The turning aspect after they have been adjusted is how I would pick which one to sell. They can be good to very very bad just like any other used lathe.
Bazyle19/12/2016 11:38:28
3637 forum posts
158 photos
Are they both model A bench (rear drive) non-slotted cross slide?
You could CNC one of convert one to metric though a bit of a waste of a capable lathe as it is since less complete ones can be used as a starting point.
Do you have all the accessories like chucks, steadies, metric changewheels, dividing, drilling milling spindle? If funds are a limitation one well equipped lathe is more use that two without the tooling you need. (I don't put QCTP into the list of necessities, just icing on the cake but let's not start a discussion on that here)
edit: and do you have the space for two?
Edited By Bazyle on 19/12/2016 11:40:06
KWIL19/12/2016 12:11:04
2831 forum posts
50 photos
Kevin, 4 lathes and 3 mills (different sizes naturally). Always useful to have a second choice!
Ajohnw19/12/2016 12:40:39
3631 forum posts
160 photos
On Boxfords it's best to wait for ones that come with as much gear as possible 'cause the costs stack up if they have to be bought even 2nd hand. I'd say a minimum for many is a 3 jaw, 4 jaw face plate and a fixed steady.
If the lathe has an imperial gearbox it can be persuaded to cut just about any standard pitch with a selection of change wheels. Not sure how this works out on the metric ones but they do come with a usable screw cutting indicator also I think an 8TPI spindle nose thread.
I would avoid the early Model A as I believe it doesn't have the feed arrangements of the later lathe that do this via a slot along the leadscrew.
Some people reckon that the ME10 is a load of crap because of the metal removed from the headstock casting. Take no notice. Your very unlikely to notice any difference and these will have a T slotted cross slide. Designs produced for myfords can simply be packed up to correct the centre height differences, then the same techniques can be used.
Early examples of the modern design can be affordable now. One size fits in exactly the same footprint as the old ones. Take care though. One I looked at had some sort of fault on the screw cutting nut arrangement. Replacement bits are expensive. Things like steadies are also expensive. The other one didn't have much gear with it. By the time I added what I mentioned cost would have been increased a lot. It also had another problem. Various versions need different numbers of change wheels for screw cutting. This one needed loads of them. Some have some additional levers that allow feeds and pitches to be selected over a limited range. These only need a few change wheels to cut the lot, imperial and metric. There also seems to be an in between model. All of them can be found at reasonable prices apart from some joker that did list on ebay. Both of the ones I looked at were under £1000 and not listed on ebay.
blushI should stick with what I have but can't help looking more to retain value after I am not around. At least that's what I tell myself. I did miss one that I might have bought subject to looking at it. It went very quickly. Just as well really.
kevin beevers19/12/2016 12:56:34
69 forum posts
43 photos
well chaps thanks for your comments i do have the space in my small 16x16 garrage but even that seems to be getting smaller,it would be nice to be able to keep everything.Kwill why on earth do you want 4 lathes?and 3 mills (think thats just greedy lol) its got me thinking that 1 decent size lathe poss harrison or on that sort of size would do even for the small work and a decent mill will have to have a good think about this but thanks for your responces
kevin
Chris Evans 619/12/2016 21:04:41
1067 forum posts
Keep both, a second lathe or mill can save hours not having to break down a set up to do secondary operations.
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
Merdienne London Show 2018
SPG Tools October Seventeen
TRANSWAVE Converters
Shapiro
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
