Forum sponsored by allandale
Arduino Rotary Table MEW 249
Corrected part Number + Discussion
Carl Wilson 403/12/2016 23:15:34
638 forum posts
48 photos
Hello All,
I am starting this thread to field questions about my Arduino Rotary Table article in the above MEW.
The first thing is an error from me - the stepper driver board should be a 6560 not 6960 as mentioned. A typo carried over from my original notes. Apologies. As my wife tells me, I'm not perfect.
Carl.
Edited By Neil Wyatt on 06/12/2016 14:03:44
Andy Holdaway03/12/2016 23:43:19
167 forum posts
15 photos
Thanks keeping this alive Carl.
Parts are ordered (including the 6560!), let chaos commence!
I've actually used Arduino's for a number of projects over the last few years (and PIC's, but that's another story) but never used stepper motors, so I'm keen to play with this and see what it will do.
Andy
Edited By Neil Wyatt on 06/12/2016 14:04:01
Neil Wyatt04/12/2016 03:22:09
13224 forum posts
571 photos
68 articles
Thanks Carl, I'll put a brief note in MEW 250.
Edited By Neil Wyatt on 06/12/2016 14:04:24
Carl Wilson 404/12/2016 04:14:59
638 forum posts
48 photos
No problem Andy. I will try to put up a video of the unit working. If anyone wants to see more pictures and a detailed description of the build, you can find it on my blog.
Google British Reaction Research and rotary table.
Carl.
Edited By Neil Wyatt on 06/12/2016 14:04:32
Michael Gilligan06/12/2016 17:15:35
10976 forum posts
474 photos
Posted by Carl Wilson 4 on 03/12/2016 23:15:34:
Hello All,
Thanks Carl ... That ^^^ is a very decent thing to do [pity about the title change]:
As yet, I have no questions, but I'm posting this just to bump your thread ... noting that the spin-off has taken a life of its own.
Edited By Michael Gilligan on 06/12/2016 17:16:02
Andy Holdaway06/12/2016 22:07:00
167 forum posts
15 photos
Carl,
First question - before my stuff gets delivered, I had a search through the drawers and found a UNO, Mega2560 and a DFRobot LCD Keypad shield.
Next step - check out the stepper software. Everything works expect the 'Right' button. I have mapped the button values and I get Right - 0, Up - 100, Down - 257, Left - 409 and Select - 639. I have checked that all buttons read, and with different sketches the buttons work, but for some reason 'Right' does't work with the stepper sketch.
Any ideas? It's not a problm as yet as I won't be using these parts, but it just seems odd that it doesn't work as expected.
Andy
EDIT - It's amazing once you write something down how the fog clears and you solve the problem straight away! I'd messed up the keypress allocation - all working now.
Edited By Andrew Holdaway on 06/12/2016 22:17:40
Garth08/01/2017 13:39:39
18 forum posts
I was wondering if anybody has noticed a possible error in Garry Liming's download software version, I could only locate version DM10.1 2015 / 06 as against DM 8.4 noted in MEW.
Maybe Carl Wilson could enlighten me .
Edited By Neil Wyatt on 08/01/2017 19:43:25
Andy Holdaway08/01/2017 13:50:43
167 forum posts
15 photos
Garth, if you download from the DM link you will find three versions of the software in the zip file. The latest (I believe) is ver 2.3. If you open the sketch in the Arduino IDE the first line gives you the version number in confirmation.
Version 2.3 works fine for me.
Andy
Edited By Neil Wyatt on 08/01/2017 19:43:31
Michael Gilligan08/01/2017 15:51:07
10976 forum posts
474 photos
Garth,
It may have been better to put your query on this thread: **LINK** which Carl so thoughtfully started.
http://www.model-engineer.co.uk/forums/postings.asp?th=122870
Edit: ... or maybe even this one: http://www.model-engineer.co.uk/forums/postings.asp?th=122870 which was 'spun-off' from it when the thread lost direction.
Edited By Michael Gilligan on 08/01/2017 15:54:27
Edited By Neil Wyatt on 08/01/2017 19:43:37
Carl Wilson 408/01/2017 16:31:51
638 forum posts
48 photos
Version 2.3 is the one you want.
Edited By Neil Wyatt on 08/01/2017 19:43:43
Carl Wilson 408/01/2017 16:33:30
638 forum posts
48 photos
Just echoing the above, throw this info in the second post mentioned above. Who knows maybe the moderators will eventually raise it to the dizzy heights of sticky-hood. Immortality beckons.
Edited By Neil Wyatt on 08/01/2017 19:43:49
Garth08/01/2017 23:26:49
18 forum posts
Am on board now , thanks for the info.
Carl Wilson 409/01/2017 06:52:03
638 forum posts
48 photos
My pleasure.
Graham Titman10/01/2017 18:00:46
50 forum posts
Hi i wonder if any one can help i have tried two Arduino Uno boards and two different DF Robot keypads and get the same result that the up and down left keypads go through the menu but pressing select makes no difference they just show the menus .I have downloaded the software on two different computers and get the same result.
john swift 110/01/2017 18:17:17
297 forum posts
170 photos
Hi Graham
from what I can see all manufactures of the LCD / keypad shields don't use the same values of resistors for the Keypad
look here at the post from sillyoldDuffer 9/12/2016 for alternative values for reading the key pressed : -
http://www.model-engineer.co.uk/forums/postings.asp?th=122792&p=4
PS
you cannot use PWM on all boards terminal  D10 to control the brightness of the LCD's backlight
some boards like the one from maplin you can use PWM as they   have a resistor between the terminal D10 and the base of the transistor that controls the back light
others don't have the resistor and the arduino will be damaged if the atmel chip is programmed to pull the D10 terminal up to +5V
PPS
in my album you will find the circuit of the linksprite / maplin board with details of the all  important resistor needed if you use PWM  backlight control
Edited By john swift 1 on 10/01/2017 18:53:25
SillyOldDuffer10/01/2017 18:17:57
2681 forum posts
554 photos
Hi Graham,
Have a look at my post dated 09/12/2016 17:02:49 in the other thread
Sounds like you have the same problem, which is fixed by altering the key voltages as described.
EngineBuilder and I both have DFRobots that needed values like this :
  • NO_KEY 1023
  • RIGHT_KEY 0
  • UP_KEY 98
  • DOWN_KEY 253
  • LEFT_KEY 408
  • SELECT_KEY 639
Cheers,
peter ravenscroft10/01/2017 18:27:16
78 forum posts
hi john
if daves dont work try
50 btn right
195 up
380 down
555 left
799 select
i had the same problem but is now ok
regards
peter
john swift 110/01/2017 19:08:41
297 forum posts
170 photos
Hi Peter
while I was looking for a LCD / button shield to buy I found links to modify some of the shields to use PWM backlight control, hence the circuit diagrams in my album
as it happens , the linkspright / maplin shield I bought workes with the software Carl Wilson linked to from digitalmachinist
PS
this is the button resistor ladder for the linksprite/maplin  board with 3 changes in red for the dr robot board
Edited By john swift 1 on 10/01/2017 19:37:47
Graham Titman10/01/2017 20:19:27
50 forum posts
Good evening thank you all for your help but you are talking a completely different language to one i understand on Johns diagram i can find the analog pin on the board i then i need a satnav my understanding of electronics is nil. I can follow a drawing the above means nothing at all.
Thanks Graham
Andy Holdaway10/01/2017 21:00:19
167 forum posts
15 photos
Graham,
Right at the end of the StepIndex23.ino sketch you will see the following lines -
if (key_in > 850) return NO_KEY;
if (key_in < 70) return RIGHT_KEY;
if (key_in < 200) return UP_KEY;
if (key_in < 350) return DOWN_KEY;
if (key_in < 500) return LEFT_KEY;
if (key_in < 680) return SELECT_KEY;
These are the values I used to get the keypresses working in my DFRobot LCD shield. If you change the numbers after key_in to either those above, or to the values Peter, John or SoD have quoted, your buttons should work. Failing that there is a small sketch that you can run to read the actual values that your board uses and use those figures, but have a go with the above first.
Andy
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
Shapiro
SPG Tools October Seventeen
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
