Forum sponsored by allandale
My workshop build
Michael Bird 114/09/2016 19:00:07
36 forum posts
I have spent the last 6 months building my workshop. I started with a 16' x 12' shed and I insulated the walls, ran electrics with 12 double sockets, and then boarded the walls and painted them.
The lighting is 4 double striplights 5 foot long. The floor is 2" bearers carrying a one inch timber floor which is insulated and then a 30mm MDF placed on top and a rubber matting on top of that.
I have built two benches, one to house the machines and the other to work at.
The whole build log can be viewed here:
Here's a few photo's.
SillyOldDuffer14/09/2016 19:05:24
2612 forum posts
539 photos
Drool!
If mine looked as good as that I would never dare use it. (Just jealous...)
Roderick Jenkins14/09/2016 19:23:21
1533 forum posts
371 photos
A Myford lathe and a Sharp mill. That man's got taste (and some space).
yes
Rod
Jeff Dayman14/09/2016 19:26:57
1151 forum posts
23 photos
Looking great Michael, well done. JD
alan ord 214/09/2016 20:49:24
61 forum posts
Great looking workshop but if you don't want problems with rust get rid of the gas heater!
Alan.
damian noble14/09/2016 21:19:30
140 forum posts
73 photos
Why the red light on the wall?
Ady114/09/2016 21:30:46
3108 forum posts
414 photos
Lovely. You could rent it out as a holiday let.
Michael Gilligan14/09/2016 21:32:29
10806 forum posts
471 photos
Posted by damian noble on 14/09/2016 21:19:30:
He's also an Astronomer
Michael Bird 114/09/2016 21:38:35
36 forum posts
Thanks guys.
Yeah the red light is so I can set the scope outside and use the workshop as a warm room. The red light protects my night vision.
Alan whats the problem with the gas heater then?
duncan webster14/09/2016 22:15:25
1408 forum posts
20 photos
firstly condensation, all the products of combustion, carbon dioxide and water, are vented into your workshop, and the water condenses on your lovely machines
secondly, when I last the sums it's actually cheaper to use electrical heaters than buying gas in bottles. Check again as prices vary
If you want to use gas get a balanced flue heater (if you can find one that runs on bottled gas), but you'll need advice on how to install it in a wodden structure.
Martin 10014/09/2016 22:31:12
227 forum posts
6 photos
The uninsulated roof is IMHO a big mistake. Insulate with 200mm of PIR and you might not need any additional heat if you can maximise winter solar gain through the windows (and reduce summer solar gain with shading / overhangs) Build a solar air heater on a south facing wall and you definitely won't need to spend anything on heating
Muzzer14/09/2016 22:34:17
2649 forum posts
435 photos
I'm on a similar journey although I think it's fair to say I am some way behind you. When I looked out there a couple of weeks ago there was a perfectly good (single) garage and an outhouse....
Garage - gone
Not content to wait for the building to be quite complete, I've already started out on the task of filling the new workshop. After all, you have to take these things seriously.
Shizuoka CNC milling machine (2.75 tonnes of it):
Homeless
Bazyle14/09/2016 22:57:10
3811 forum posts
166 photos
Wow wht looks luxurious.
Get rid of the plastic cover over the lathe. Just because it is sold by myford doesn't mean it is a good idea as it will sweat. Use a cotton sheet. Also get a dehumidifier.
Bob Youldon15/09/2016 00:05:39
169 forum posts
20 photos
Good evening Michael
Some very good advice regarding your new shop, the gas heater will turn everything brown when you turn your back, if the shop is as well insulated as you say then a simple 2kw fan heater will keep you and everything at an even temperature, put it on a clock for an hour in the early hours of the morning and about half an hour around seven in the evening and you will prevent any condensation, everything will remain above dew point.. I've a timber, well insulated workshop with a similar heating regime and I've never suffered with rust but whatever you do don't do any soldering etc inside, that'll set the dreaded rust off. I've a cover much like yours for my Myford and it's been in a cupboard for the last forty years, never on the machine!
What exactly in your new vast abode do you intending making?
Bob
thaiguzzi15/09/2016 04:27:24
359 forum posts
104 photos
Normal shed on the outside. Light and airy on the inside. Nice.
frank brown15/09/2016 06:52:57
436 forum posts
5 photos
Too late now but MDF is not right for flooring, you should have used 22mm P5 grade T&G flooring panels. The previous occupant to my house used bits of MDF for shelving in the garage, in the long term (>5 years) it bows under its own weight. Some of my shelves are spectacular in their curves. Must get round to to replacing them
Frank
Speedy Builder515/09/2016 07:50:40
1413 forum posts
95 photos
Michael - Looks like a great place you have built there and hours of pleasure to be had in it, but DO INSTALL some sort of FIRE protection. I have an Extinguisher 'bomb' which although messy if it ever went off, is non toxic and automatic. They cost about £300, but allows you to sleep at night. And it goes without saying - SECURITY.
BobH
frank brown15/09/2016 08:25:25
436 forum posts
5 photos
Shame to hear that Speedy, what caused it to do that? Not sure about their efficiency but under the bonnet CO2 systems are cheaper, too small a volume?
Frank
JasonB15/09/2016 08:41:54
12318 forum posts
1095 photos
Nice shed
Your MDF will be fine as you have floated it on the subfloor so its fully supported, just watch it around the doorway as you have not used mositure resistant MRMDF if there are a lot of wet feet going in & out.
As others have said the roof could do with insulation, Kingspan or Celotex between the purlins would be best.
JA15/09/2016 08:48:37
715 forum posts
33 photos
Posted by Speedy Builder5 on 15/09/2016 07:50:40:
BobH
Please give more details about the extinguisher bomb. I have just goggled "extinguisher bomb" and it appears to be a hand thrown device. Interesting and useful but you cannot use it in your sleep. Is there a similar device which is activated when a fire is detected (and you are asleep or watching the Antiques Roadshow)?
JA
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
SPG Tools October Seventeen
Shapiro
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
