Forum sponsored by allandale
Stewart Harts Horizontal Engine build
first run
Mike Bondarczuk27/06/2016 20:15:44
87 forum posts
6 photos
Hi all,
The video hopefully attached to this message shows the finished horizontal engine built as per the design and drawings from Stewart Hart.
It is my first non-wobbler build and there are a few cosmetic changes to the design, which are purely for personal aesthetic purposes.
I have been taking copious photographs during the build and am now in the process of compiling a build log which I hope to publish in sections quite soon.
I hope that someone enjoys the video and if has given me great personal pleasure in building this engine which will be followed by the vertical engine and finally the beam engine, thereby producing thew Trilogy from the pen of Stewart Hart.
If anyone else is contemplating building this engine then I would whole heartedly recommend this as a good first start.
Jason, if you could help with the link that would be hugely appreciated.
Edited By JasonB on 27/06/2016 20:22:36
kevin beevers27/06/2016 20:58:26
69 forum posts
43 photos
like it think i may try this looks a nice litte engine my first was woodbeam engine i have just started another but this time if i can remember to take photos of the build.nice work.
kevin
Neil Wyatt27/06/2016 22:22:54
12598 forum posts
557 photos
66 articles
Very good, it will look nice when it's painted.
But how did you get it to 'wobble' like rubber? The video was making me seasick!
Mike Bondarczuk28/06/2016 09:03:44
87 forum posts
6 photos
Neill,
The magic of a hand held digital camera running in video mode.
Unlike some on here I don't have a tripod to give a steady base, but I guess I should try for a better video when it is painted and reassembled and hopefully running again.
Ian S C29/06/2016 10:33:40
6611 forum posts
217 photos
Mike, you'll probably find that the mounting thread for a tripod on the camera is 1/4" Whitworth, it is simple to knock up a stand of some sort. Ian S C
Mike Bondarczuk29/06/2016 11:05:50
87 forum posts
6 photos
Ian,
I have a 1/4" Whitworth tap and die set so can make a stand of sorts.
Was actually thinking of one of those flexible armed "gorilla" type stands which I could then position rather more freely.
Michael Gilligan29/06/2016 11:25:35
10622 forum posts
470 photos
Posted by Ian S C on 29/06/2016 10:33:40:
... or, more likely, [to my great chagrin] 1/4" 20 UNC, to a 'sloppy-fit' tolerance specification which ensures that it will remain compatible with old 1/4" Whitworth tripod screws.
[discussed at length previously, on this forum]
Edit: Ian, you obviously know that already blush
... I've just located your post on this page.
Edited By Michael Gilligan on 29/06/2016 11:41:30
JasonB29/06/2016 11:49:59
12049 forum posts
1075 photos
It's not just camera movement that is ian issue here there is a wavyness to the video which I have noticed in a few others recently, take a look at the air connection at the start of the clip and it sways from side to side, no tripod will cure that.
There is a name and reason for it as it came up teh other day on another forum but can't find the post right now
Edit, seems like a tripod will help, from the other site
"Although it may be the G&Ts, it's actually a phenomenon called "rolling shutter". Cell phones (and some point n shoot still/video) record video one line at a time. "Real" video cameras capture the full frame all at once. Any cell phone movement creates the rubber legs on the engine. A camera support will stop the problem.
You may continue drinking with impunity. "
And the wobbly engine video in question, nice little engine.
Edited By JasonB on 29/06/2016 12:03:51
Roderick Jenkins29/06/2016 12:50:29
1492 forum posts
366 photos
It's not just the camera that needs to be still. The video of my Wyvern was taken using a Nikon D90 in video mode. The camera was mounted on a tripod well isolated from the model but the Wyvern was clamped to a rather flimsy workmate clone and, being a single, is not well balanced. I think the frequency of the subject vibrations interfere with video frequency and result in a wobble. It is particularly noticeable in close-up..
Anyway, nice model Mike - Hope to meet you at Guildford on Saturday.
Rod
Edited By Roderick Jenkins on 29/06/2016 12:53:37
Neil Wyatt29/06/2016 12:55:33
12598 forum posts
557 photos
66 articles
I suspect it's you-tube's automatic steadying software getting it wrong. It's steadying the paper sheet but not steadying all the parts of the engine correctly. If it was just a shutter issue, the edges of the paper would move as well.
After watching those two I now feel quite ill,so if MEW 244 comes out late, it's YOUR fault!
Michael Gilligan29/06/2016 13:14:41
10622 forum posts
470 photos
Posted by JasonB on 29/06/2016 11:49:59:
... it's actually a phenomenon called "rolling shutter". Cell phones (and some point n shoot still/video) record video one line at a time. "Real" video cameras capture the full frame all at once. Any cell phone movement creates the rubber legs on the engine. A camera support will stop the problem.
May I just expand upon that, Jason ?
Sensors [with their associated chipsets] come in two types "rolling shutter" is as you describe, and "global shutter" is the frame-capture type.
Doesn't add much to the present discussion, but might be useful if anyone wants to explore further.
Michael Gilligan29/06/2016 14:04:02
10622 forum posts
470 photos
Posted by Neil Wyatt on 29/06/2016 12:55:33:
I know nothing about the automatic steadying software [something to learn-about tonight], but I think that there may be a beat frequency effect, between actual and expected frame-rate. Add in the 'rolling shutter' and you have a recipe for thise wobbly legs.
Is this more commonly seen on YouTube videos originating from PAL regions ??
Roderick Jenkins29/06/2016 14:31:21
1492 forum posts
366 photos
Well, my original video is, if anything, even wobblier than the YouTube version .
Rod
Ed Duffner29/06/2016 14:45:56
662 forum posts
59 photos
The early Nikon cameras had an issue with wobbly digital video when the camera was panned.
Very smooth running engine Mike! yes
Ed.
Edited By Ed Duffner on 29/06/2016 14:50:08
Michael Gilligan29/06/2016 15:16:47
10622 forum posts
470 photos
Posted by Roderick Jenkins on 29/06/2016 14:31:21:
Thanks for that update, Rod
I may not bother trying to understand the YouTube 'steadying software' after all.
Mike Bondarczuk29/06/2016 17:03:58
87 forum posts
6 photos
Gentlemen,
Reading through the last few messages regarding the wobbling effect I do now recall that after uploading onto YouTube an option to activate the "steadying software" was accepted and in hindsight I think that this was a bad move as the original has no visible wobble, apart from the shaky human stand "me".
kevin beevers29/06/2016 18:01:19
69 forum posts
43 photos
its been pumping too much homebrew
Geoff Theasby29/06/2016 18:34:28
516 forum posts
14 photos
Mike, I notice you don't have any oil holes in the main bearings. Perhaps a 1mm drilling from the top, with a countersink to hold a drop of oil?
regards
Geoff
Geoff Theasby29/06/2016 18:34:29
516 forum posts
14 photos
regards
Geoff
Mike Bondarczuk29/06/2016 18:42:05
87 forum posts
6 photos
Geoff,
The video is of the first run and I had copiously oiled the main bearings as well as the slides and the big end bearing.
The engine is now stripped down and in the process of being prepared for painting but in the interim I had turned four oil cups, two to go on the main bearing supports and one each for the top slides.
The dimensions of the cups are such that they have a capacity of 4ml of oil and feed the bearings via 1mm diameter holes.
The idea of simple countersunk dimples to hold oil had never occurred to me and is a nice idea for the future.
The build log will show the oil cups as well as the other major components and the final video will show the finished painted engine, and I am currently busy cutting gaskets for the heads as well as the steam valve assembly.
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
TRANSWAVE Converters
SPG Tools October Seventeen
Shapiro
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
