Forum sponsored by allandale
Help with a compound slide for Sieg C1
dizzibits06/05/2016 16:17:01
21 forum posts
Hello all
I purchase a compound slide for an Axminster Model Engineer Lathe. Can someone help me how to use it? I believed going by pictures of other lathes that it rotated on its axis to give greater control of the tool, but I cant see how to make it turn?
I have had it apart trying to see what I'm missing.
Thanks for any help
This is a picture of the slide
Edited By dizzibits on 06/05/2016 16:18:46
JasonB06/05/2016 16:38:56
11901 forum posts
1058 photos
If it is anything like the other far eastern lathes then leave the 4 mounting screws loose and turn the slide to your required angle then do them up tight to lock.
The alternative would the the hex head screw set into the top of the circular scale, probably one on the opposite side too.
Edited By JasonB on 06/05/2016 16:44:19
Michael Gilligan06/05/2016 16:46:14
10488 forum posts
462 photos
Posted by dizzibits on 06/05/2016 16:17:01:
... I believed going by pictures of other lathes that it rotated on its axis to give greater control of the tool, but I cant see how to make it turn?
Going by the picture [which includes an angular scale], one would reasonably assume that it can rotate !!
Surely there must be a rotation lock, somewhere
... What did you find when you 'had it apart' ?
Edit: There's a likely-looking cap-head screw next to the 0° mark
Edited By Michael Gilligan on 06/05/2016 17:05:41
mark smith 2006/05/2016 18:04:57
563 forum posts
295 photos
From what i can see it has four t-nuts on the bottom and would have to fit on a crossslide like on this link of a C8!
The C! had a similar cross slide. So you need to bolt it to the cross slide with the crews and t nuts then the top half should swivel by loosening the screw that is on the scale , then tightening it at the angle you want.
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Lathes/Model-C1-Lathe/SIEG-C1-Lathe/SIEG-C1-Lathe
Edited By mark smith 20 on 06/05/2016 18:09:02
Robbo06/05/2016 18:36:12
1365 forum posts
122 photos
The four cap head screws in the corners of the square base hold it to the cross-slide using the T-strips underneath and are done up tight.
The four cap heads on the top of the sliding part are (obviously) for clamping the tool in place.
Each side of the sliding part, in the centre of the arc of the round base is a cap head screw recessed below the surface. Slacken off these 2 screws to rotate to the required angle, then tighten.
Assuming you have re-assembled it correctly!
dizzibits07/05/2016 11:47:01
21 forum posts
Much obliged for the replies.
I tried the front cap hex bolt by the 0° previously. I may have missed the other one. I will try it next time I'm in the mini workshop and let you know.
Ben Gordon07/01/2017 18:41:29
1 forum posts
I have been searching for this compound slide but I cannot find it anyway. Where did you purchase it?
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
TRANSWAVE Converters
SPG Tools October Seventeen
Shapiro
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
