Forum sponsored by allandale
Helping dad vertical engine
Eric Cox14/04/2015 15:40:05
464 forum posts
22 photos
Edited By Eric Cox on 14/04/2015 15:47:42
Stewart Hart14/04/2015 16:38:58
525 forum posts
250 photos
smiley
Stew
Neil Wyatt15/04/2015 14:47:54
13224 forum posts
571 photos
68 articles
Mike Bondarczuk15/04/2015 17:38:39
87 forum posts
6 photos
question
sarcastic 2
Stewart Hart15/04/2015 20:51:57
525 forum posts
250 photos
cheeky
Michael Gilligan15/04/2015 20:59:25
10976 forum posts
474 photos
Given that Eric's post was under "Drawing Errors and Corrections" ... one might reasonably assume that the "Helping dad vertical engine" is near perfect.
Stewart Hart15/04/2015 21:03:54
525 forum posts
250 photos
No I doubt it. crying
Errors always creep in some ware.
The best you can do is limit their impact.
Stew
Michael Gilligan15/04/2015 21:51:02
10976 forum posts
474 photos
Stew,
I did say 'near perfect'
... We must not ignore Eric's somewhat cryptic `
JasonB16/04/2015 07:01:18
12543 forum posts
1114 photos
Unless you got to read what he said before the post was edited, in which case you will know what its all aboutsecret
Eric Cox16/04/2015 09:21:05
464 forum posts
22 photos
My apologies, I couldn't find a way of deleting the post , however I will repost it. I won't go into the ins and outs of why I needed to remove it.
On the bill of material Item 15 Connecting rod should read 1/4" x 1/2" x 4"
Chris Gill13/06/2017 20:25:33
24 forum posts
8 photos
I'm busy making this engine at the moment and I believe I've spotted a small error on page 513 (April 2015).
I think the central portion of part 39 (the parallel shaft) should be 26mm long, which is the sum of the central portion of part 22 (14mm) and two copies of part 24 (6mm). This means the overall length of part 39 will be 46mm.
I'd also suggest making the studs (part 41) a bit longer, say 36mm, as the existing length only engages 3mm at each end. I made mine from 4mm threaded rod to save time.
Otherwise, looking forward to seeing it run
Chris
Stewart Hart14/06/2017 07:19:50
525 forum posts
250 photos
Hi Chris
Thanks for your interest in the engine and for posting the drawing errors, I hope you enjoy the rest of the build.
Cheers
Stew
Eric Cox14/06/2017 09:38:09
464 forum posts
22 photos
Bugger. Does that mean I've made them too short.
Chris Gill14/06/2017 23:37:04
24 forum posts
8 photos
Hi Eric
I didn't realise until I did a trial assembly.
If it's any consolation I had to remake a part today because I got the first one upside down for part of the marking up. Doh!
Chris
Bob Mc15/06/2017 05:59:21
80 forum posts
21 photos
Yes..... I made one of those just to see if I could make anything that actually worked..!!
...nb... only ran it on compressed air but it certainly went.Vertical engine
Stewart Hart15/06/2017 08:28:27
525 forum posts
250 photos
Posted by Bob Mc on 15/06/2017 05:59:21:
Pleased you got a runner Bob, I hope you enjoyed the build, did you make the flywheel from perspex?.
I like to experiment with different ways of making things so I designed it with a fabricated fly wheel, have any of you guys made this fly wheel ?. I was a little unsure just how people would take to the design hence I gave them a chose of fly wheel design.
Cheers
Stew
Eric Cox15/06/2017 09:33:55
464 forum posts
22 photos
I fabricated it from 5" Dia. pipe. With a paper template it was easy to hacksaw and drill.
Stewart, is the grass hopper ready for publication yet ?.
Stewart Hart15/06/2017 11:21:36
525 forum posts
250 photos
Posted by Eric Cox on 15/06/2017 09:33:55:
Hi Eric
I submitted the Grasshopper article over 12 months ago for some reason its not been published, and as it was written as a follow on from the other two engines, the passing of time has taken that link away so it will need a re-write so that it will now stand alone, I'm not sure if it will be worth my time doing this.
Any way I've sent you the drawings and a link to a drop box with the article in it.
Any problems just drop me an email.
Cheers
Stew
Bob Mc15/06/2017 11:38:43
80 forum posts
21 photos
Hi Stewart..
Yes the flywheel is thick perspex as are the bearing housings, It was the only material in my junk box and I was concerned it would not be heavy enough but it runs ok and it was an education and a pleasure for me to make this model.
I think a heavier flywheel would be more appropriate ... one tip I can give is... bolt or clamp the engine base to a good solid bench, its probably my workmanship at fault, but when running it resembles a drunken Scotsman dancing over the crossed swords....! (not a derogatory remark to Scotsmen)... I am myself related to Scotland.
Thanks Stewart.
Chris Gill31/07/2017 23:26:33
24 forum posts
8 photos
It runs! Just got to make a nice base, clean up and paint it.
The first attempt ended with a loud bang. Then I realised I'd connected to the unregulated side of the compressor and the short connecting pipe had migrated to the other side of the garage. Ho hum
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
Shapiro
SPG Tools October Seventeen
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
