Member postings for Mark Rand
Here is a list of all the postings Mark Rand has made in our forums. Click on a thread name to jump to the thread.
Thread: The Workshop Progress thread 2018
26/05/2018 14:16:04
maybe a ring shaped burner?
26/05/2018 11:49:42
Are you permitted to make a heat retaining cowl around the hot tube? Just a bit of sheet to guide the flame so that all of the tube is heated and less heat is radiated away from the tube?
Thread: Clean hands?
25/05/2018 23:57:52
I use original green Swarfega. I did discover a decade ago that I'm allergic to D-limonene, the substance used in the citrus based cleaners.
As discovered by my late father in law and verified by me:- Making a batch of pastry in the kitchen is a remarkably good way of cleaning out dirty fingernailswink.
Thread: Multi page threads.
25/05/2018 10:10:15
I, like many others in the Western Hemisphere, was taught at school to read from the top of the page to the bottom. I really can't stand top posting or anything that emulates it.
Bah Humbug!
Thread: What's the best alternative to 'loctited'
24/05/2018 03:26:31
I'm quite happy with the vernacular term 'loctited'. I'm far happier with an indication of which particular adhesive was used, and why. I quite often use Permabond 1046 for poor fits. Why? because I've got a couple of large bottles of the stuff and it's thicker than Loctite 603 or 648 smiley.
Edited By Mark Rand on 24/05/2018 03:27:28
Thread: What did you do Today 2018
23/05/2018 22:39:47
Posted by Lathejack on 23/05/2018 22:35:58:
..................The engine, complete with temporary rear axle, was then towed across the works to have the boiler flushed out with the jet wash.image.jpg
Charles Burrel rapidly rotating in his grave! wink
23/05/2018 22:36:11
I'm using ClamWin for two reasons.
1) I use it on the linux web/mail/ftp/firewall servers
2) The main two machines I use are running winders server (2008 R2 and 2012) and the likes of Avast, AVG etc. are expensive for the winders server platform.
Used to use Avast after the company stopped allowing employees to legally use the corporate Sophos license* and never had problems at the time. Clam hasn't caused problems either.
*I was in the IT dept. We had a policy, before we were taken over by another company, that we'd rather our users were protected against viruses than have them bring infected floppies into work or dial in with an infected machine.
Edited By Mark Rand on 23/05/2018 22:36:50
Thread: Discount codes and email harvesting
23/05/2018 22:07:42
So when are you going to offer a discount code that works, Ketan? cheeky
Thread: Brass bar , 55 mm - ?supplier
21/05/2018 19:55:10
Replied the same way
Thread: EDGWICK 20" SHAPER
20/05/2018 16:31:23
Much more of a machine than my 10" Royal. Mine's got vertical feed to the table, but power feed when cutting dovetails etc. is a nice touch.
If it's not too late, one word of warning that I gained from my Edgwick rotary table:- that lovely translucent green paint on the name plate is soluble in aggressive thinners, it's probably cellulose. If you want to keep it, be gentle when cleaning.
20/05/2018 16:19:11
If it's of any help, I've got some 3" CZ121 bar you could use How about £25 for 6" and £6.50 for Myhermes shipping?
Only because I had a B25 as a student laugh.
Thread: Show and Tell Event for Forum Members?
17/05/2018 21:31:47
It's a pity Rugely power station and its ME club are both history. We might have been able to wangle a tour aloing with the meet up/show and tell.
Edited By Mark Rand on 17/05/2018 21:33:14
Thread: Bent leadscrew?
17/05/2018 10:05:59
Posted by Mark Rand on 16/05/2018 21:51:55:
Posted by Paul Ainsworth on 16/05/2018 14:49:05:
<snip>
When half nuts are engaged they move the leadscrew towards the lathe bed by enough for Stevie Wonder to see it.
That definitely implies that either the saddle gib is loose or there is enough wear in the bed near the headstock that it can't be adjusted sufficiently to get free movement at the tailstock without slop at the headstock end.
Please ignore this post. I was reading it as the apron moving, not the leadscrew moving. Stupid boy!
16/05/2018 23:46:43
Or they missed it crying.
I think I'm in the Midlands, specify a where and when and I'll get off my backside and come.
Thread: Dead centre temper.
16/05/2018 21:55:04
Hard as you can get it for the dead centre. Either soft or about 30HRc for the live (headstock) centre, so you can turn it concentric when needed.
16/05/2018 21:51:55
<snip>
Thread: Jig Borer
09/05/2018 22:46:48
Posted by Raymond Sanderson 2 on 22/04/2018 05:00:31:
Mark do you have any manual etc?
I've only got some 'recent' advertising stuff that relates to the BCA MkIII. But Tony's website has some more information, plus manuals.
Thread: Weldon Shank Tool Holding
07/05/2018 22:02:58
Posted by not done it yet on 07/05/2018 13:10:57:
Posted by Ian S C on 07/05/2018 12:36:38:
David, that sounds an interesting tool holding system, how do you remove the tool once it,s in place?
Ian S C
Unless the coefficient of expansion is much greater for the holder, it won’t loosen on heating. Cryogenic cooling might help, if appropriate. Otherwise the holder would need to be removed from the tool - in chips - I would imagine.
It does work smiley. With the induction heater, you can put 10-20kW of heat into the outer 1/8" of a 1.5" diameter toolholder. The expansion of the outer layers opens the bore before the heat can transfer to the tool shank.
Marvelous things for the production shop.
Thread: sherry shelf life.
06/05/2018 23:49:08
The 2012 LBV port I've been testing tonight seems a bit young, compared with the real stuff. But I don't think it's going to be getting a lot older (long day, injured wrist, yada yada)
06/05/2018 23:42:27
Quick change Gibraltar toolpost laugh.
Email News - Join our newsletter
Love Model Engineering? Sign up to our emails for the latest news and special offers!
Expo Tools July 14
Shapiro
SPG Tools October Seventeen
TRANSWAVE Converters
Visit the Model Engineer
Exhibition website
Model Engineer Exhibition
